Old Nov 24, 2008, 10:31 PM
jingjingjing is offline
Find More Posts by jingjingjing
I love my ID.
Fairfax VA
Joined Aug 2004
13 inch wingspan full fuse Shinden canard pusher
I haven't flown or built Canard or pusher before. This was a unique experience for me.
Shinden was WW2 Japanese fighter plane. It was built and flown at the end of the war.
spec:
Wingspan: 13"
AUW: 21.3g (with 6mm Cessna power system) ,22.6g (with GWJ 7mm Red power system)
Wingloading: 3.36 oz/sqft
Control: A/E/T 3 channel
Prop: GWS 40x40
Material used: 2mm depron frame and 0.025" Durobatics
Power system: 6mm Cessna gearbox (tested), 7mm GWJ Red (not yet tested)
Here is the link to the video:
http://www.rcgroups.com/forums/showt...3#post11021148
I can take any constructive criticism. Thanks for visiting.
jingjingjing is offline Find More Posts by jingjingjing
Old Nov 24, 2008, 10:35 PM
Conehead is offline
Find More Posts by Conehead
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
You should post this in the Canard forum under Electric Plane Talk. Canard Addict started the thread and your build would be appreciated.
link, I hope. Canard Forum: Show,Discuss, Learn ( Multi-page thread 1 2 3 4 5 ... Last Page
To me, your build looks very good.
Conehead
Orrin Eldred
Honor, MI.
Conehead is offline Find More Posts by Conehead
Last edited by Conehead; Nov 24, 2008 at 10:37 PM. Reason: link added, I hope, also correct name of forum
Old Nov 25, 2008, 05:21 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Nicely done! It looks great.
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 25, 2008, 05:58 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
looks great! it`s seriously small too, what is the wingarea you have ? Wingloading will be quite high i guess?
meatbomber is offline Find More Posts by meatbomber
Old Nov 25, 2008, 07:37 AM
canard addict is offline
Find More Posts by canard addict
Joined Jun 2005
Well done, JJJ, I know you are proud of it. Charles
canard addict is offline Find More Posts by canard addict
Old Nov 25, 2008, 10:00 AM
I love my ID.
Fairfax VA
Joined Aug 2004
Wingloading turn out to be 3.36 oz/sqft. For a comparison Parkzone cessna wingloading is about 2.2 oz/sqft.
I didn't want my Shinden to be a slow flyer. Aileron wouldn't work properly if it flys too slowly.
With 6mm motor It flies about 2 min. After that 2 min, it doesn't wants to climb at all. Now I changed the motor to GWJ 7mm, but haven't been tested yet. By changing the motor to GWJ 7mm, I added 1.3g on the back of the plane. It will affect the CG. I might add 1g of weight on the nose according to the test result.
Yes I am proud of the 'look' at this moment. It flew fine with 6mm motor although it feels little under powered. I will have to see how it handles 7mm motor.
I will post the video later on.
Old Nov 25, 2008, 01:49 PM
customminatures is offline
Find More Posts by customminatures
foamanologist
customminatures's Avatar
United States, FL, Sarasota
Joined Apr 2006
looks very good. Hope the 7mm works out ok for you!
Matt
customminatures is offline Find More Posts by customminatures
Old Nov 25, 2008, 02:29 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
That plane is nice, Good subject. Looks ripe for a 2 gm brushless (with .65 gm BL ESC and B-B converter) for a power system weight of about 3 gm and add about 1 gm more for a 130 mAH LiPo
Will you paint it? If so, what will you use. I recommend light mist coats of Design Master floral foam-safe spray paint - very light and many colors
356Jim is offline Find More Posts by 356Jim
Old Nov 25, 2008, 02:41 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
I bought Dave Deils' Shinden kit so I could build along with Nate Sturman, shortly before he died from cancer. I built mine as an EDF using one of Mike Cross's 30 mm inrunner fan units, and I built it as a profile foamy to test out control options before doing the balsa model.
Since there no information available regarding how the controls were on the real aircraft, I flew it in a number of control configurations - Elevons only, ailerons with canard elevator, and mixed elevons/canard. It seemed to fly best with ailerons and canard elevator. I made my canards 'full-flying', and as a result, wound up replacing the CF rods that acted as hinges on a regular basis (guess which part lands first).
CG was located about the bottom of the fuselage inlet duct and in front of the wing. CG was not a critical factor, as it would fly with the CG forward or back - it didn't seem to care that much. What was apparent was that the canard needs to be set-up with 6 degrees positive incidence in relation to the wing.
Mike Taylor is offline Find More Posts by Mike Taylor
Old Nov 27, 2008, 12:28 PM
I love my ID.
Fairfax VA
Joined Aug 2004
Here is the link to the video.
7mm motor worked out fine. More weight on the tail seems to increase the sensitivity of the aileron. I can maintain level flight at 75% throttle.
My Shinden have 0 degree incidence on canard. The symmetrical main wing airfoil seems to eliminate the need for the positive incidence.
Old Nov 29, 2008, 10:12 AM
I love my ID.
Fairfax VA
Joined Aug 2004
Good suggestion, 356jim. I will try that option when the funds are available.
Old Nov 29, 2008, 12:28 PM
I love my ID.
Fairfax VA
Joined Aug 2004
What is the B-B converter? Is it same as Steve's converter?
By the way, I have seen 130mah 1 cell battery with Parkzone connector advertised on the banner but I lost the link. Can anybody direct me to the vendor?
Old Nov 29, 2008, 01:10 PM
Richard Cox is offline
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
The Hobby City 100 mAH cells are pretty good.
Richard Cox is offline Find More Posts by Richard Cox
Discussion Despretz J1-31 canard/elevon full-fuse foamie magic612 Foamies (Scratchbuilt) 6 Nov 18, 2013 06:23 AM
Discussion 5.5 inch wingspan full fuse plane my first attempt/build log 3dFlyer88 Scratchbuilt Indoor and Micro Models 1 Sep 08, 2007 03:21 PM
New Pico Cub full fuse AND GWS Tigermoth! Jason M Parkflyers 9 May 15, 2001 10:43 PM
What's better Regular Litestick of Full Fuse Lite Stick? mrebman Parkflyers 1 Apr 27, 2001 01:23 AM
modifying Full Fuse lite stik for Ailerons PunkerTFC Parkflyers 5 Apr 21, 2001 02:34 PM
