And once it releases, I will have all the altitude I need to throttle up and deal with any trim issues. The most important thing is my pitch and roll sensitivities. You want to keep some up elevator throughout the process and relax it once the bungee has reached it's max altitude. From there the ring slides off the hook and you're on your own. I won't need the full 250 feet altitude of course. I will cut the string and bungee to accommodate roughly 100 feet altitude which should be more than enough to launch the SR-71 successfully (assuming my CG and throws are correct). |
Latest blog entry: My Build Review of the FMS V3 1400MM...
OK guys dug out my SR71 kit :-)
Latest blog entry: Wicked Powered Tech One Neptune EDF!
Yes it requires any grass field or dirt surface that you can hammer a spike into the ground easily. Here's the link for the High Start:
http://www3.towerhobbies.com/cgi-bin...?&I=LXYXK4&P=7 Here's a quick demo I made tonight of the SR-71 Blackbird that comes with the Expansion 7 pack for my RC sim RealFlight 6. Notice the scale stab/rudders and whale tail that acts as the elevators while the elevons are for aileron control only. I wonder how our birds would fly if these were the mods we did to them.
The servo horn on the whale tail end of the pushrod is a wheel collar that I soldered a brass horn to...this was to make it adjustable with the little setscrew. I would do that a lttle different...epoxy a ply horn instead, it can't slip, more simple, less weight and it really doesn't need to be adjustable, which can be made at the servo end of the pushrod. The way mine is now, I'll have to cut two hatches if either end slips. Joe
Rudder mods...this is a easy way for rudders, but not scale.
Scale... full floating/flying rudders would be a awesome mod. I was concerned about going in the 100mph region with these kind of rudders...it's all that rudder in front of the hinge point that gives me pause. Example, a small board held edgewise in front of you going 90 is tougher to hold than letting it trail behind you. One of you guys should try it, just make sure there's video so we can assess the... Joe
Speed sensor...this would be almost the same with a telemetry model...you don't have to be as particular where the sensor goes on that kind of set-up, but the pitot tube install would be the same.
Joe
Fantastic mods redlite. I'm going to copy your single servo whale tail mod. That pitot tube is sick! |
Joined Feb 2012
Joe,
those are some awesome mods mate! love what you did to the amazing bird, have you flew it yet? Can you please kindly add the links for the parts you used for mate? i have trouble finding them online. The hinges looks good! And guys, any idea where can i get the programming card for this ESC? - http://www.hobbyking.com/hobbyking/s..._100A_ESC.html Thanks guys! |
I embedded thin CF rods around the nose later after a couple on 'hits' during transport that softened the foam. Lay them parallel with the centerline in a radial fashion. They were thin and about an inch long, I think there were two or three on top and the bottom. Really stiffened the nose area up. Filled with lightweight spackle, let dry and sand to finish surface, then soaked the spackle in thin CA to harden up, sand again, prime and paint... You have mentioned a couple of good points above, so study the pics and it's really an easy mod. Joe |
I didn't buy any special parts for the whale tail mod, just bits and pieces as you can see in the pics. Hinges are GWS paper hinges...I found something better, FedEx envelope paper, impossible to tear and takes CA very well. I looked at your link for the ESC and it states that this unit is a plug and play and has limited programmability. Joe |
| Thread Tools | |
| SR-71 for EDF 50 (Closer than we might think) | Thomas B | Electric Ducted Fan Jet Talk | 187 | Feb 22, 2011 10:56 PM |
| SR-71 anyone? | steve neill | Electric Ducted Fan Jet Talk | 71 | Oct 08, 2007 07:34 AM |
| hobbylab sr 71 | bushpilotx1 | Sport Planes | 7 | Mar 06, 2002 12:53 AM |
| Electrics that can outperform the SR-71? | SchiessCo | Electric Plane Talk | 4 | Jul 30, 2001 08:44 PM |
