Old Aug 04, 2011, 08:54 AM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Check out my blog here on the RC groups!
bighead93 is offline Find More Posts by bighead93
Old Aug 06, 2011, 01:25 PM
hackdroot is offline
Find More Posts by hackdroot
hackdroot's Avatar
USA, CA, Oakley
Joined Aug 2008
Whats the best way to test balance in the air on this thing? Seems like mine wants to pitch up when coming off the throttle. I'm currently balancing it at the rear of the receiver cage on the ground.
I've also removed the retracts after a few collapses on landings. Seems to fly better without all that added weight. Landings are a real challenge now as it glides far and fast coming in.
hackdroot is offline Find More Posts by hackdroot
Old Aug 06, 2011, 01:53 PM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
I've had issues landing mine (sans gear) as the nose wants to tip high once the throttle is chopped right before the flare point. I keep a little down elevator on my final approach to offset this nose-tip tendency. I'd rather deal with a hard landing on the belly then a vertical orientation on flare, landing very unceremoniously on the elevons! (Happened twice!)
This is a tricky bird to get down on all phases due to its very unique elongated fuse and short delta configuration. Once you get the CG just right, and understand precisely how to fly her, she will reward you like no other plane in your arsenal.
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Aug 06, 2011, 02:32 PM
rowdyjoe is offline
Find More Posts by rowdyjoe
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
Roll it inverted to find out how much forward stick is required to hold it level. It shouldn't take more than about 1/4 stick. If it takes more, it's too nose heavy. If it's neutral, it's balanced just right. If you have to pull back stick, it's tail heavy.
RJ
rowdyjoe is offline Find More Posts by rowdyjoe
Old Aug 06, 2011, 02:59 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
there could also be a thrust line issue. If cutting power makes the nose rise, it's entirely possible that an alteration of the exit point of the thrust tubes needs to be looked at. (raised). If the exit is placed too low, it pushes the nose down under power and typically someone trims the plane based on that. Then when the power is cut, the nose rises. The opposite can hold true as well. If the exit is too high, cutting power makes the nose drop as under thust the nose is being pushed up (tail being pushed down). A little experimentation might be in order to determine if engine power on /off affects pitch.
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 14, 2011, 08:53 AM
bmg50 is offline
Find More Posts by bmg50
bmg50's Avatar
DTW suburbs
Joined Nov 2009
2nd flight video
finally got the SR71 up and on video,
http://www.youtube.com/user/skeeterz...14/c4qcrEtypjg
bmg50 is offline Find More Posts by bmg50
Old Aug 14, 2011, 09:03 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Nice.
Old Aug 14, 2011, 10:32 AM
Maple Valley, WA
Joined Apr 2006
Nice job. Looks like you have a good understanding on how she's meant to be flown. Minimal wing rock, nose forward, goose that throttle on low passes...Very smooth liftoff and landings. Love the orange orientation trim as well!
Site Sponsor
Old Aug 14, 2011, 01:16 PM
dLdV is offline
Find More Posts by dLdV
On the Edge of Space
dLdV's Avatar
Exit 4, South Jersey, USA
Joined Dec 2007
Decent!
dLdV is offline Find More Posts by dLdV
Old Aug 14, 2011, 01:33 PM
rowdyjoe is offline
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
I'm morning the demise of my SR71. I crashed it again on Friday and this time I think it's terminal. It ended up in 3 large pieces and several smaller ones. Haven't inspected the electrics yet but, they "look" OK (fans still have all of their teeth, etc.).
Takeoff was much better than the first attempt. More power and authority ...she climbed out well at full throttle. However, I again had the nose-heavy issue even though she balanced out fine on the machine.
I remember thinking that she lacked the speed. I must have done something wrong during the rebuild ...probably a mistake in the thrust tubes. Handling was twitchy but, not unmanageable. I was trying to fly her and trim the nose up at the same time and on my 3rd lap around the field I lost control at low altitude. Totally my fault. If I had more altitude I think I could have saved it.
I haven't decided if I'll order another airframe. It was a fun project and a good learning experience but, I think I'll leave this Blackbird too better pilots.
RJ
Old Aug 14, 2011, 01:38 PM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
It's funny on this one. A lot of times it seems the maiden goes OK but it's the subsequent flights that do you in.
Old Aug 14, 2011, 02:25 PM
bmg50 is offline
bmg50's Avatar
DTW suburbs
Joined Nov 2009
its stock BH ESC/fan power set up but the tray area was carved way open length and width to fit a large 3700 3S pak and keep the cg right. That helps a lot i think, plus all the info this thread provides, the whale tail mixed in with elevon plus rudders i think help this plane.
Old Aug 14, 2011, 02:46 PM
Maple Valley, WA
Joined Apr 2006
I don't know what you guys are complaining about. I've only gone through six airframes.
Site Sponsor
Old Aug 15, 2011, 09:47 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Well done! Nice job on the landing!
Old Aug 18, 2011, 04:09 PM
redlite is offline
Find More Posts by redlite
Build'm,Fly'm,Crash'm
redlite's Avatar
Sacramento CA
Joined Oct 2009
Great flying and landing! Typical long roll-out on this plane as landing speeds are a bit higher than normal. And nothing cooler than taxiing back to the hanger after a successful mission...
Joe
redlite is offline Find More Posts by redlite
SR-71 for EDF 50 (Closer than we might think) Thomas B Electric Ducted Fan Jet Talk 187 Feb 22, 2011 10:56 PM
SR-71 anyone? steve neill Electric Ducted Fan Jet Talk 71 Oct 08, 2007 07:34 AM
hobbylab sr 71 bushpilotx1 Sport Planes 7 Mar 06, 2002 12:53 AM
Electrics that can outperform the SR-71? SchiessCo Electric Plane Talk 4 Jul 30, 2001 08:44 PM
