Old Aug 30, 2009, 06:03 AM
dLdV is offline
Find More Posts by dLdV
On the Edge of Space
dLdV's Avatar
Exit 4, South Jersey, USA
Joined Dec 2007
Pentium ESC Question
Thrust tubes and fan motors mounted. Don, I ordered a pair of Pentium 60A ESC's. If they are hardwired to a single Dean's plug in a Y harness, can they be programmed simultaneously by throttle stick to run 5400 Kv's?
dLdV is offline Find More Posts by dLdV
Old Aug 30, 2009, 06:22 AM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
As long as they are powered up at the same time they will program at the same time. However you MUST disable one of the BECs by removing the red wire on one ESC servo lead. The Pentium 60s have a switching BEC and you can not join two switching BECs together because one BEC will burn out. Also on a twin you will want to synchronize the ESCs. To do this, you want to put the throttle stick to full up then plug in the lipo, the motors will beep two times, then quickly go to full down throttle, then it will beep again then arm. This synchronizes the two ESC to have the same exact throttle range.
Don
The Don is offline Find More Posts by The Don
Old Aug 30, 2009, 09:08 AM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
Will synchronization be needed every power up or just once?
Old Aug 30, 2009, 10:15 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Just once.
Don
Old Sep 05, 2009, 07:57 PM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
Hey Don, the speeders got here Friday and flew on Saturday. It seemed from the booklet everything was defaulted to run the 5400 Kv's p&p, in any case thats what happened. The first flight the plane got in a flat spin after a few laps & I couldn't get out. It kind of helicoptered to the ground from like 100 yards. Not sure if I flew it into a spin or what, but it was freaky to watch a Blackbird do that. Glued up the amazingly little damage and flew again. Second flight was normal. I can't even guess what the speed is but it did make our little field seem even smaller than usual, that's for sure.
Joe, (fh64_lucky) you still flying yours? The only difference here is 4AH instead of 4.5AH batt.s, otherwise its a copy of yours. This'll be a blast when its all tweaked up.
Old Sep 05, 2009, 08:10 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
I had mine up just yesterday. I was doing stupid things with it and thought I would intentionally get it into a flat spin. I must have done 5 or 6 turns before I punched out of it. Thrust did it's job, I'm just darned lucky I didn't drop a wing from the notorious SR-71 wing rock.
Love the way an SR-71 looks in the air, but I do wish for full floating rudders for more scale banking fly bys.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 05, 2009, 08:26 PM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
Hey Joe 1320, I was wondering if you had flown yours yet. Full flying vert's would be cool! How do you like the plane overall? Your version was going to be a 1100W?
Old Sep 15, 2009, 07:02 PM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
A Sickening Thud
Dumped it in the woods two weeks ago, just plain lost track of which way it was headed. Fixed it up and flew twice on Sunday past, flew OK. Made manila folder tubes for the inlet side to block those cheater holes from the inside. It makes a nice whooshing sound when it goes by now.
Old Oct 04, 2009, 06:57 PM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
Couple photos. Its more fun than it is ugly, and that's saying something! Everybody agrees it sounds good though.
Old Oct 05, 2009, 07:02 AM
rwmson is online now
Find More Posts by rwmson
Uniblab
rwmson's Avatar
Cherry Hill, NJ
The plane's bottom was beaten with a MUCH LARGER ugly stick, but we don't have a photo.
rwmson is online now Find More Posts by rwmson
Old Oct 06, 2009, 10:55 AM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
Sometimes you gotta SPANK the airplane, show it who's boss.
Old Oct 06, 2009, 11:44 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
If it is 200 feet away you don't see anything wrong with it There is a lady who has a hot dog stand nearby and she is best viewed from about 200 feet as well
Old Oct 21, 2009, 07:22 PM
redlite is offline
Find More Posts by redlite
Build'm,Fly'm,Crash'm
redlite's Avatar
Sacramento CA
Joined Oct 2009
Hello Don;
Just ordered a pair of 4800's and pentium 40's. I'm looking at 2100mAH TP Pro-lites V-2 that are rated @ 42 amps/cont. and 84 amps/burst. Do you feel these are up to the job, say 3 minute flights at various throttle settings (mostly WOT for 2/3's of the flight). I just like the combined weight of 10.3 oz's. I checked the 'battery' thread and couldn't find a clear response, though a lot of useful info is there. Like all the fires caused by Lipo's! Had one explode like an M80 on my bench, but no fire. I have a few balsa/tissue planes hanging above the bench and the shrappnel wrecked two! I was sitting nearby, but not a scratch. Huh, did you say something? Ringgggggg for two days!
Cheers
Joe
redlite is offline Find More Posts by redlite
Old Oct 21, 2009, 07:25 PM
RemE is offline
Find More Posts by RemE
Tweaker
RemE's Avatar
Corona Del Mar
Joined Sep 2005
What caused the explosion??
RemE is offline Find More Posts by RemE
Old Oct 21, 2009, 07:38 PM
redlite is offline
redlite's Avatar
Sacramento CA
Joined Oct 2009
I caused it. This was a few years ago when they were new and were lithium/ion's. I used the wrong charger, but got away with it for a few times. Learned early (the hard way!) they weren't bullet-proof ni-cads. Remember the abuse? The good old days. I had a ni-cad in Lindbergs' Blue-devil DD for more than 15 years, same one.
SR-71 for EDF 50 (Closer than we might think) Thomas B Electric Ducted Fan Jet Talk 187 Feb 22, 2011 10:56 PM
SR-71 anyone? steve neill Electric Ducted Fan Jet Talk 71 Oct 08, 2007 07:34 AM
hobbylab sr 71 bushpilotx1 Sport Planes 7 Mar 06, 2002 12:53 AM
Electrics that can outperform the SR-71? SchiessCo Electric Plane Talk 4 Jul 30, 2001 08:44 PM
