Some more threads concerning this. I haven't had the chance to read them yet. This questions has always made me wonder also since I have built and flown a number of pushers.
http://www.rcgroups.com/forums/showthread.php?t=76309 http://www.rcgroups.com/forums/showthread.php?t=562798 http://www.rcgroups.com/forums/showthread.php?t=642029 http://www.rcgroups.com/forums/showthread.php?t=888546 http://www.rcgroups.com/forums/showthread.php?t=908829 http://www.rcgroups.com/forums/showthread.php?t=656724 Frank |
Joined Jun 2007
don't confuse the decomposition of forces as actual forces. Vector sums are just a mathematical tool to operate calculations on complex force interactions. Some of the assumptions made do not translate directly in reality, like having all vectors attached to the same point on a rigid object. Essentially, you can put two identical motors on a rigid object, set up to pull in opposite directions. The resultant vector will turn out to have 0 length, but there will still be a force there trying to pull the object apart. As a whole it won't move, but whether it explodes is another matter
And approaching this in the opposite way, an object with no forces applied to it could be correctly represented in a vector system as <---infinite length---(object)---infinite length---> and yet it won't have any force applied to it, let alone forces with an infinite strength |
| Thread Tools | |
| Question I'm confused! Thrust angle on Pusher plane.......... | mtdoramike | Electric Plane Talk | 22 | Jul 05, 2008 07:41 AM |
| Help! Thrust Angle on Pusher plane | cjbucher | Electric Plane Talk | 10 | Feb 14, 2007 11:45 AM |
| Discussion What is the thrust angle on a Styker "C" model? | randall1959 | Flying Wings | 2 | Oct 27, 2006 08:51 AM |
| motor thrust angle on wings | Steph280 | Foamies (Kits) | 15 | Jul 08, 2003 08:48 PM |
| Thrust angle of pusher | stevem1928 | Parkflyers | 2 | Dec 09, 2002 12:31 PM |
