Old Nov 24, 2008, 08:24 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Need help with 257" B-36
All,
I need some help. I have read about 10 seprate threads on how long my wires can be and there seems to be zero 110% sure answers. I will be using 6 AXI 5320/34 with 8 cell lipo's. The planes CG can be met if I have the packs in the fuse and leading edge of the wing. I would like to have 16" battery to ESC leads and 30" ESC to motor. I posted this question on my thread, but then was told to ask this here. i need the batteries up front as much as I can to hit 55 pounds.
My thread:
http://www.rcgroups.com/forums/showthread.php?t=933242
Thanks all,
DAG
dag214 is offline Find More Posts by dag214
Old Nov 24, 2008, 10:12 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
^I think you would get better answers in the "Electric Motor Design and Construction" forum.
But I think you should be fine with wires that long, as long as you aren't looking for stellar performance, with vertical climbs.
Xpress.. is offline Find More Posts by Xpress..
Old Nov 24, 2008, 10:49 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Thanks, didn't even think of that place.
DAG
Old Nov 24, 2008, 12:24 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Might be worth having a read of this thread, if you haven't already -
Long battery leads will kill esc
eflightray is offline Find More Posts by eflightray
Old Nov 24, 2008, 01:41 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
I think I would look at my construction of the airframe. The motors are behind the CG, but not by much. The CG looks pretty close to mid-fuselage. Can you put a lifting tail on your model? That will allow the CG to move back some more (old FF trick). Will your cells physically fit within the nacelle area of the wing? They would come pretty close to offsetting the motors.
Another thing you could do is put a longer driveshaft on the motor, moving the motor body up toward the CG. The bearings you need are easily available from Boca, and the couplers for motor-to-driveshaft should be pretty easy to obtain in the model boat market. If you're below 350W per motor, you can use a Graupner flex coupler which would allow you a little alignment error and still have a very good power transfer. Need to watch the prop rotation though to keep from unwinding the coupler.
Just a few ideas.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 24, 2008, 01:45 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Just a few ideas.
Andy
Thanks Andy,
Look at my renderings my motors are ahead of the CG and they are all driven on .5" shafts held in bearings.
DAG
Old Nov 24, 2008, 02:47 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I think the lengths you're suggesting are reasonable with one caveat: make sure the ESCs (and therefore their input capacitors) are rated for at least a few volts more than the batteries you are going to use. Using good quality ESCs (comparable to the motors) is also a good thing.
I've always wanted to do a B-36, but not one quite that big!
BEC is offline Find More Posts by BEC
Discussion Need help with Balancer plug for Imax B-5 and EVO battery. SoarinJohn Batteries and Chargers 0 Jun 26, 2008 09:26 PM
Discussion Newbie Need help with S&B models Guest99 Australia 27 Jul 07, 2007 10:11 PM
Discussion Need help with Komodo 257 eletrified_flyer Electric Motor Design and Construction 13 Dec 09, 2006 10:49 PM
Discussion Need help with CP2 B/H Head BLRustler Micro Helis 6 Oct 06, 2006 03:54 PM
still need help with B-2 wab25 GWS (Grand Wing Servo) 4 Mar 11, 2005 02:33 PM
