Old Sep 11, 2009, 09:50 AM
tornadorc is offline
Find More Posts by tornadorc
Frequent Flyer
tornadorc's Avatar
Australia, Melbourne
Joined Jun 2009
cool thanks mav
tornadorc is offline Find More Posts by tornadorc
Old Sep 11, 2009, 10:33 AM
MakMov is offline
Find More Posts by MakMov
Excellence is Expected
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Originally Posted by tornadorc
cool thanks mav
Not a problem. I have been through these Gaui's forwards backwards upside down and have come across just about every problem with them so if you have any question feel free to ask.
I still have an ornery 100
MakMov is offline Find More Posts by MakMov
Old Sep 11, 2009, 06:32 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
I have had some success with my FF200 and rather like it although it does take some tinkering to get it to fly relitively nicely ans still no Gaui but excellent value imo. FF100 is a waste of time....the frame is garbage. If you want a 100 the FF FG frame is the go as Makmov suggested.
Re the FF head. I'm using all FF200 parts with the Gaui short main shaft. A few things that need addressing. The washout arms come out of the washout base pretty easily due to thread depth in the plastic. Also the washout base binds a little on the two pin guides in the head. I fitted the gaui cnc washout base http://www.gaui.com.tw/parts/203581.jpg with appropriate metal thread screws I had lying around as well as the Gaui cnc swash http://www.gaui.com.tw/parts/203570.jpg and a Gaui links set http://www.gaui.com.tw/parts/203211.jpg as well as Gaui plastic mixers. Also using the Gaui one way main gear. Alot of Gaui parts when I start adding it all up!
On the tail end I use the Gaui plastic double bearing slider and the Gaui 100 plastic grips and it flys pretty decently. Crashes usually require a main shaft blade grip screws and occasionally a link. Once I broke a blade grip where the mixer connects.
Btw mounting the motor in the FF200 plastic frame is a pita. The sides of the frame angle in and encroach on access to the mounting screws. I fitted allen head machine screws to overcome this.
Good heli after lots of work! Once I add it all up maybe a 2nd hand Gaui would be the better option!!
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Sep 11, 2009, 07:49 PM
Frequent Flyer
tornadorc's Avatar
Joined Jun 2009
Amp
Well a I have a couple of theses ff200, I think I'll just use them for learning and once one of them go, I'll just buy a gaui or a t250. they are both dropping in prices something savagely. And I reckon they should, it's way over priced for a small heli (super combo in my LHS $700 AU). I can buy a 450 pro for that price. So here's the answer
http://shop.eflypower.com/shop/views.asp?hw_id=1964
my next one!
or this one
http://aerialhobby.com/index.php?mai...roducts_id=306
I'm just so confused on which one to get. which one would you get?
Paul
Old Sep 11, 2009, 07:52 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
my next one!
or this one
Paul
The Gaui, no question.
The Trex clone is good, the Gaui is better and much more versitile
Old Sep 11, 2009, 07:54 PM
Frequent Flyer
tornadorc's Avatar
Joined Jun 2009
done. thank you mak
Old Sep 11, 2009, 08:03 PM
Ampdraw is offline
Joined May 2008
Gaui v2. No silly tail "gear box" for starters. Much better bird imo. Seems you must be in Aus. Here's a good supplier for parts cheaper than 250 parts in most cases;
http://www.rctoysaustralia.com/index...id=76&Itemid=1
Amp
Old Sep 11, 2009, 10:23 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
I put a shaft drive on my EX V2 and it's awesome with a 2100T.
Old Sep 11, 2009, 10:28 PM
MakMov is offline
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
I think my 100 pro is done... too much twist in the frame It's worn out and doesn't stay tight.
If you grab the tail in one hand and the frame in the other there is about an inch of play.back and forth.
Data Pocket Zoom (EP100-EP200) configs/crash stats salat Micro Helis 5 Jul 12, 2011 08:17 PM
Discussion firefox/ ep100 scale fuse video tkoguy Micro Helis 3 Jan 31, 2009 10:37 PM
Discussion King 2 or EP100/EP200? fretman Micro Helis 18 Mar 19, 2008 12:49 PM
Sold ELE Firefox EP100 V2 barebones kit and spares sgporc Aircraft - Electric - Helis (FS/W) 6 Feb 10, 2008 04:03 PM
Discussion looking for Gaui EP100, EP200, Pixy ZAP, etc. heli kit salat Micro Helis 4 Jan 01, 2008 01:57 PM
