Old Nov 25, 2008, 12:44 PM
mulikow is offline
Find More Posts by mulikow
Team Mulikow
mulikow's Avatar
Canada, ON, Frontenac County
Joined Feb 2007
Thanks flypaper! will try when i get home tonight!
mulikow is offline Find More Posts by mulikow
Old Nov 25, 2008, 01:50 PM
mulikow is offline
Team Mulikow
mulikow's Avatar
Joined Feb 2007
Yodafm1e, Ill check that gyro out!...thanks
Old Nov 25, 2008, 01:52 PM
mulikow is offline
Team Mulikow
mulikow's Avatar
Joined Feb 2007
Tonyastro...i dont know if there is...but if anyone finds any deals on the firefox ep100 can you please post....
Old Nov 25, 2008, 02:13 PM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Johnny,
Where did you get it all for that price ??.
Cheers,
MikeHRC is offline Find More Posts by MikeHRC
Old Nov 25, 2008, 02:21 PM
whilrybird is offline
Find More Posts by whilrybird
Joined Jun 2007
I didn't like the firefox parts are too brittle. Just a slight blade touch and mixing arm broke, landing gear and blade grip.
Head is a bit too loose for my taste. Not very accurate.
whilrybird is offline Find More Posts by whilrybird
Old Nov 25, 2008, 02:36 PM
mulikow is offline
Team Mulikow
mulikow's Avatar
Joined Feb 2007
I think this is the one i got it from...but ive seen it cheaper by about 20 dollars elsewhere...ill find it.
http://www.hobbycity.com/hobbycity/s...idProduct=7477
Old Nov 25, 2008, 03:01 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
That's where I got mine,HK. Not the same gyro as what they show. Mine has DY 101 on the side of it. Also the servos they sent were to wide to fit the frame. I put Blue Arrows in it that work fine. The servos that came with it are in a homade Bug type plane, but smaller, that I call the Flea. The ball links have more meat than the Hurricane and fit tighter on the balls which I like. None of these landing gears are strong enough, including the Hurricane. Mine now has a piano wire tricycle landing gear like the Sikorski Dragonfly. Doesn't weigh any more and much tougher. I need tough. The plastic frame is much tougher than the Hurri too.
Gord
flypaper 2 is online now Find More Posts by flypaper 2
Old Nov 25, 2008, 03:29 PM
mulikow is offline
Team Mulikow
mulikow's Avatar
Joined Feb 2007
From what i see...i kind of like the firefox ep100. Wouldnt mind giving that one a try.
Old Nov 25, 2008, 05:20 PM
yodafm1e is offline
Find More Posts by yodafm1e
JediBiker
Tomah, Wisconsin, USA
mulikow,..overstock sale EP-100's at BPhobbies
mulikow,
BPHobbies is overstocked on he Pixy Zap,..which is exactly a mini-zoom EP-100. Look at the link below,..and I would suggest the heli at the top,..the flight pack just below,..notice that flight pack has the pino MG servo's.
They are the only servo's that bolt right into the frame. It tells you to get the 4800kv BL system,...it is only 65.00 bucks,..however, the 3800kv is half that price with a 10amp.
That's what I ran all the time and my head speeds were consistent at 4000-4200. You do not need anything else, and the price is outstanding,..they are in NJ, USA.
I ordered 2, twenty minutes ago, only one flight pack, a 38.00 HH Gyro on there site. The heli actually comes in a box like a caring case,..and it is FULLY assembled.
Just some info for ya,...
Have fun buying stuff!!
Michael,...
http://www.bphobbies.com/view.asp?id=B2332483
yodafm1e is offline Find More Posts by yodafm1e
Old Nov 25, 2008, 05:56 PM
helifrek is offline
Find More Posts by helifrek
3D Printing Enthusiast
helifrek's Avatar
United States, TN, Clarksville
Joined Feb 2004
thanks for the info guys. I wish I didn't sell my transmitter time to get 2.4 now!
helifrek is offline Find More Posts by helifrek
Old Nov 25, 2008, 08:05 PM
mulikow is offline
Team Mulikow
mulikow's Avatar
Joined Feb 2007
Cool will check it out.
Old Nov 25, 2008, 08:47 PM
mulikow is offline
Team Mulikow
mulikow's Avatar
Joined Feb 2007
Put the gain to 150% on the Tx. Gave it a quick test in the kitchen...seems to be holding. Well give it another maiden tomorrow afternoon. Should have vid posted then.
Old Nov 25, 2008, 09:02 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
I have 3 or 4 pairs of 175mm plastic blades for EP100. I will let them go for $4 pair shipped to 48 lower.
http://www.bphobbies.com/view.asp?id...6&pid=NELE7101
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Nov 25, 2008, 09:23 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Seems a few are interested in the FF100. Firstly the better performer is the 200 due to better disk loading.
The 100 is smaller though!
My suggestion is get both!
Or a Gaui 200v1 (they are much cheaper now due to the release of the V2 and Trex250) for high performance and fine tuning of skills and the 100 for "testing" and backyard flight.
FF100 kit+motor+esc (suit 3s application) $89.00 here
FF100 kit only $64.00 (here
Also strongly suggest this lower plate for rx etc here
And I used a cut down upper strengthener as a giant washer between the motor screws and the frame to stop the motor screws from damaging the frame if overtightened. here
Gaui motor and esc work well for me with 17T pinion on 2s 15C Aplus lipos. Or outrage 25c 2s packs are better.
You will need to download a instruction booklet for the Gaui 100 plastic version as the FF100 has no build instructions. You will also need a pinion and motor/esc connectors.
These FF100 helis are great but come with no assembly. There are things that need attention and a little tweaking here or there. Like fitting a set screw to stop the boom from moving in its mount and likewise for the tailcase. Don't expect a mod free (minor) build and you won't be dissapointed.
Amp
Appropriate servos are hard to find. I use Vigor Vs9's and am happy with them for sport flying.
Ampdraw is offline Find More Posts by Ampdraw
Old Nov 25, 2008, 10:03 PM
Kelley is offline
Find More Posts by Kelley
Kelley's Avatar
Goodyear, AZ
Joined Jan 2003
mulikow, Thanks for starting this thread. I have two ELE 200's, one 95% complete and the other still in the box.
Anyway, I have a couple of questions that I hope someone can help me with. What is the size of the allen screws that hold the flybar? I have look and tried everything and can't find one that fits. Also what is a good tail servo? I am using Blue Arrow 4.3's for the colective & telebee gyro. I'll post some pictures tomorrow.
Also, does anyone know if any of the scale bodies for the Pixy Zap will work on the 200?
Euro Copter
Kelley
Kelley is offline Find More Posts by Kelley
Data Pocket Zoom (EP100-EP200) configs/crash stats salat Micro Helis 5 Jul 12, 2011 08:17 PM
Discussion firefox/ ep100 scale fuse video tkoguy Micro Helis 3 Jan 31, 2009 10:37 PM
Discussion King 2 or EP100/EP200? fretman Micro Helis 18 Mar 19, 2008 12:49 PM
Sold ELE Firefox EP100 V2 barebones kit and spares sgporc Aircraft - Electric - Helis (FS/W) 6 Feb 10, 2008 04:03 PM
Discussion looking for Gaui EP100, EP200, Pixy ZAP, etc. heli kit salat Micro Helis 4 Jan 01, 2008 01:57 PM
