Go Back   RC Groups > Aircraft - General > Radios
This thread is privately moderated by hilgert, who may elect to delete unwanted replies.
Old Dec 30, 2008, 10:02 PM   #46
$$$ Cash for RC Carnage!
Bronze Member
flazo's Avatar
I need this mod!!!
flazo is offline Find More Posts by flazo   Reply With Quote
Old Dec 30, 2008, 10:02 PM   #47
ahh, good point. I guess I do to, forgot about the timer. Anyway to split the output? The beeper mods sounds cool, how long till you have that tested?
How are the leds coming? Does the EL panels look to be the better way to go? It looks like factory which is important to me. I am guessing the 12X uses an EL panel as well?
DWS6 is offline Find More Posts by DWS6   Reply With Quote
Old Dec 30, 2008, 10:23 PM   #48
I think a timer keyed by the beeper is the PERFECT factory look and feel solution!
And 10 seconds or less the right time cause if your making any changes the timer will restart....... off 5 or 10 seconds after last activity!
Dave
superdave01tx is offline Find More Posts by superdave01tx   Reply With Quote
Old Dec 30, 2008, 10:38 PM   #49
Buyin', Tryin' and Flyin'
Bronze Member
hilgert's Avatar
Not sure if Tanners carrys EL panels or drivers - might have to take a run down there on Wednesday if they are open.
However, the LED solution will be the way to go on this - I have a few other things to do some prototyping on and then it should be good to go.
-Hilgert
hilgert is offline Find More Posts by hilgert   Reply With Quote
Old Dec 30, 2008, 10:47 PM   #50
Please post pix and opinion when done.
Dave
Old Jan 02, 2009, 04:35 AM   #51
Hilgert,
Any progress on the LED lighting?
I have EL parts on the way ........ already had timer parts.
Dave
Old Jan 02, 2009, 01:26 PM   #52
Bronze Member
hilgert's Avatar
Originally Posted by superdave01tx
Hilgert,
Dave
No so good. I think it would work fine if you wanted to remove the LCD panel (you have to go to some work to realign the TINY pins on the LCD - ask me how I know )., peel off the foil backing (without damaging anything else), and then reassemble the panel. However, I wanted a mod that most anyone could do that would be 100% reversable, with minimal to no modificaitons required (perhaps just two taps of solder for power from the swtich, etc.).
So, for now I am sticking with the EL mod, and I am getting some other material that might work for the LED version.
-Hilgert
Old Jan 03, 2009, 08:48 PM   #53
I just got my EL stuff in the mail from allelectronics, I hope the inverters are smal enough....... should have a working non perfected version going in a few hours..... timer added after that..... I think maybe a 555 and a and gate between the beeper and the 555 for trigger......
I like this kinda playing..... Hilgert, thanks for the help and insiration!
Old Jan 03, 2009, 09:31 PM   #54
Hilgert,
Im testing the parts and the 5x1 EL panle is only drawing about 20 ma or less.... is it possible my meter is off that much? I rarely use the 500ma setting so not sure myself, Ill test with another meter once im home at my work bench.
I think these inverters will easily fit insdie a radio too and this one makes NO noise that i can hear.
More testing results soon.....
Dave
Old Jan 03, 2009, 09:45 PM   #55
Bronze Member
hilgert's Avatar
How bright is the panel? From the current numbers you have I am concerned about the brightness.
What voltage is the inverter?
-Hilgert
Old Jan 03, 2009, 09:47 PM   #56
The inverter is a 5v version driven bt a 4.8 v rec pack, I assume its charged sufficently, will check.
As far as brightness its normal bring i think..... im fixing to test a 5x3 panel.....
Old Jan 03, 2009, 09:57 PM   #57
the inverter is inv-204 number on it is inv-th-204(2) 5v and its 1.25 wide, 13-16th tall and .5 inch thick, pins stick out a tad bit more but could easily be shortened to fit insuide them dimensions, Will install in a radio after a bit.
Old Jan 03, 2009, 10:10 PM   #58
ok with the EL panel on the voltage is 5.25..... so thats good....
now using a different meter set on 200 ma range its shows 31.5 ma..... so ONE of the meters is off but either value very acceptable to me.
Old Jan 03, 2009, 10:13 PM   #59
Bronze Member
hilgert's Avatar
Are you around on Sunday? I could drop by if it's okay to take a look. I'll bring my 9303 so we can compare.
-Hilgert
Old Jan 03, 2009, 10:50 PM   #60
Just tetsed the 5x3 panel, its glows white/lite pink .... currents shows 42 ma on it.....
Ill be around sunday but not sure where, probally could meet you somewhere, if weather is good your welcome to fly at the field as my guest, flew last 2 days, wonderful!
Im goig to open up my jt x9303 and install the white panel for a real test.... post again soon....
Mounting the Sony 5" LCD panel to your 8UAF Canada Goose Aerial Photography 4 Dec 11, 2008 08:39 PM
Wanted GOOD Micro Rx in exchange for an IBM Laptop LCD panel heli_ebook Aircraft - General - Radio Equipment (FS/W) 0 Oct 24, 2008 07:30 PM
Discussion Seagull LCD Panel, funny audio signal aeropics Eagle Tree Systems 0 Aug 25, 2008 07:46 AM
New Product New gyro w/ advanced LCD panel ricky_p Radios 0 Jul 22, 2008 01:32 PM
Question Broken LCD panel on a Futaba 9C zolo Radios 3 Jun 30, 2008 12:34 PM
Bored? Want to fight?
Join the RCGroups clan!
