Go Back   RC Groups > Aircraft - Electric - Helis > Mini Helis
Old Nov 29, 2008, 04:30 PM   #31
Team Mulikow
Gino CP's Avatar
Got some wind yesterday and I took the Black Angel out for a spin. The heli was doing great funnels, hurricanes, and low inverted. The G401B with Fusonic digital servo did better than my GY401 with a digitized Hitec HS56HB. You can hear struggling with the latter. With the G401B and Fusonic, I only get an occasional very very small wag as an oops situation. Otherwise no struggling at all. I think I can dial that out with some more tx and gyro adjustments. But to be honest, I don't think I will. Heli handles fine.
I got a scare when I got some wags on the last minute of a succeeding flight. But when I replaced with a better lipo, things were back to normal. Head speed is very important to my setup as it seems. Or perhaps the digital servo was underpowered no thanks to the weak lipo. So if you have weak lipos, time your flights shorter for optimum power.
Gino CP is offline Find More Posts by Gino CP   Reply With Quote
Old Nov 29, 2008, 05:12 PM   #32
Moved the ball one hole in to the innermost hole. The wag has decreased but it is still not really flyable. I think I may need a better servo on the tail. The GWS is plenty fast but I guess it just isn't accurate enough to be a tail servo. The problem may also be the tape I'm using. Just using plain double-sided foam tape from the hardware store. Perhaps some quality gyro tape will help.
Pastulio132 is offline Find More Posts by Pastulio132   Reply With Quote
Old Nov 29, 2008, 05:40 PM   #33
Team Mulikow
Gino CP's Avatar
Ordinary foam tape works for me.
• Check your main rotor balance? Remove gears and seesaw on its side.
• Check your tail pulley for too much play in the tail housing
• Check belt tension
• Check both pulleys if they are slipping on shafts
• Try a different tail servo
• Select correct gyro setting for analog or digital
Old Nov 29, 2008, 10:02 PM   #34
Jimbo45cn's Avatar
I am running GWS Naros HP BB servos all around on my Belt CP. This is the heli I have the 401 B installed on. I just adjusted the gain and the delay and my last flight today was pretty darn good. No wag and holds well. Jim
Jimbo45cn is offline Find More Posts by Jimbo45cn   Reply With Quote
Old Nov 29, 2008, 11:28 PM   #35
I just ordered one of these to try with a hxt900 for now and if it holds well I am going to change all my gyros to these, except my 250 with the gp750. I also want to switch all my tail servos to ds290g's.
ForceFedDSM is offline Find More Posts by ForceFedDSM   Reply With Quote
Old Nov 29, 2008, 11:29 PM   #36
Team Compass USA
brian94066's Avatar
Send a message via AIM to brian94066 Send a message via MSN to brian94066
the GP750 is equivalent to the spartan
it holds great
brian94066 is offline Find More Posts by brian94066   Reply With Quote
Old Nov 29, 2008, 11:57 PM   #37
it holds great
I think you are confusing it with the pg800, the gp750 is an align gyro that seems a lot like a 2100t.
Old Nov 29, 2008, 11:58 PM   #38
Team Compass USA
brian94066's Avatar
GP700
oops, the GP700 is like the spartan
Old Nov 30, 2008, 01:34 PM   #39
Blusaber's Avatar
Gyro
Ok Gino
Based on your experience and your vid I just ordered one of these. The only gyro I have used is the 2100t (Mini Titian and Trex se).
I ordered a Dragonus from HobbyLobby on the black Friday sale and this is the bird I'll put the Gyro in I am looking forward to trying something different and intend to go cheap on electrics for the DRAG at first so this fits the bill perfect.
Thank you for the review great timing for me
However if I'm unhappy I know where ya live and we will talk
Oh wait I'm only 15 miles from XMseler I'll have my talk with THEM
Thanks again Gino
Gary
Blusaber is offline Find More Posts by Blusaber   Reply With Quote
Old Nov 30, 2008, 07:27 PM   #40
Team Mulikow
Gino CP's Avatar
Ha ha. I'll set my head speed at 4000rpm and I will be waiting
Old Nov 30, 2008, 08:02 PM   #41
Blusaber's Avatar
Oh Oh
Watch that head speed you might start a Hurricane
Gary
Old Nov 30, 2008, 08:04 PM   #42
Team Mulikow
Gino CP's Avatar
I do hurricanes
Old Nov 30, 2008, 11:04 PM   #43
BeeZaur 480
BowerR64's Avatar
I ordered 3 of them, a few of those black cnc head blocks and a couple black cnc seesaw lever units. I keep breaking those little things when i carash and ive depleted my parts stash.
BowerR64 is offline Find More Posts by BowerR64   Reply With Quote
Old Dec 01, 2008, 12:11 AM   #44
Paycheck flyer
mhills51's Avatar
Bower I don't think you will need them with the weather we got.
mhills51 is offline Find More Posts by mhills51   Reply With Quote
Old Dec 01, 2008, 03:04 AM   #45
trx
I'm getting one of this for the dragonus that I ordered. .
Gino - why are setting your headspeed at 4000rpm?, is this just to test the gyro?
trx is offline Find More Posts by trx   Reply With Quote
Align HH gyro on Trex-need help w/setup atrr Mini Helis 27 Feb 13, 2009 04:56 AM
Which rated ESC's on DF 2004 with HH gyro Willard Micro Helis 2 Oct 07, 2004 02:06 PM
need input on what HH gyro to buy! birdie_in_texas Micro Helis 14 May 27, 2004 09:05 AM
Question Going separates w/HH gyro on HB luvhelis Micro Helis 4 Mar 23, 2004 10:07 PM
How HH gyro behaves on Hummingbird. GoodHeli Micro Helis 2 Sep 12, 2003 08:42 PM
Bored? Want to fight?
Join the RCGroups clan!
