Go Back   RC Groups > Aircraft - Electric - Helis > Mini Helis
Old Nov 22, 2008, 03:14 AM   #16
VTEC just kicked in, YO!
Speed Stick 3D's Avatar
Send a message via AIM to Speed Stick 3D Send a message via MSN to Speed Stick 3D Send a message via Yahoo to Speed Stick 3D
Great review Gino.... I think im going to order one
Thanks!
Speed Stick 3D is online now Find More Posts by Speed Stick 3D   Reply With Quote
Old Nov 22, 2008, 09:47 AM   #17
Jimbo45cn's Avatar
Nice flying Gino. I am sold. Bought one last night. Thanks, Jim
Jimbo45cn is offline Find More Posts by Jimbo45cn   Reply With Quote
Old Nov 22, 2008, 01:20 PM   #18
Paycheck flyer
mhills51's Avatar
I had one of the GY400 I got from the same seller. It worked well and then just went bad . No crash just started up and in rate it kept wanting to spin right and in HH kept spinning left. So I am looking for a long term test. I can't remember , but I think I only had like 6-9 flights on it when it went bad.
So please keep us informed Gino!!
mhills51 is offline Find More Posts by mhills51   Reply With Quote
Old Nov 22, 2008, 06:36 PM   #19
Team Mulikow
Gino CP's Avatar
Yes the GY400 was a dud. That was early days and there were few factory 3D fliers in China. I certainly made more than 9 flights with the G401B. So technically it is better. LOL. But I intend to keep using this to see how it goes.
Gino CP is offline Find More Posts by Gino CP   Reply With Quote
Old Nov 25, 2008, 07:25 PM   #20
Team Mulikow
Gino CP's Avatar
Just got back from the field. Practiced 15 ft flips and some grass cutting. Fabulous morning. I still haven't encountered strong winds so that part of the review is on hold.
Old Nov 28, 2008, 07:02 PM   #21
Just got my G401B from xmhobbies and I'm sad to say that my experience hasn't been quite as trouble-free as yours Gino. I've got some severe wagging issues. I'm using it on a CopterX 450 with a GWS Park HPX-F servo on the tail. I've tried different delay settings but the wag is still there. I've got the gain all the way down to 35% on both modes. It works ok in rate mode but in HH it is still unusable. Any ideas?
Pastulio132 is offline Find More Posts by Pastulio132   Reply With Quote
Old Nov 28, 2008, 07:55 PM   #22
Jimbo45cn's Avatar
I have mine hooked up to my Belt CP but have not tried it yet. Anyway, what you can do is keep going down on the gain or up on the delay until the wag stops. I was playing around with the gain settings on mine tonight and it did not go out of HH mode until It was at zero. So anything above that is HH, and 35% may be too much. Just a guess. Jim
Old Nov 28, 2008, 08:33 PM   #23
Team Compass USA
brian94066's Avatar
Send a message via AIM to brian94066 Send a message via MSN to brian94066
just ordered 2
brian94066 is offline Find More Posts by brian94066   Reply With Quote
Old Nov 28, 2008, 11:50 PM   #24
Team Mulikow
Gino CP's Avatar
Use delay to eliminated bounce when stopping a piro abruptly. It is not used to remove wag in a steady tail on pitch pumps.
Start with zero delay. Keep that tail in midstick. Do pitch pumps and slow turns. If there is wag, dial down the gain. If you get this right, then you can proceed with delay. For that do quick left and right turn stabs. If the tail bounces (small wags on each end), increase delay.
Old Nov 29, 2008, 12:25 AM   #25
Jimbo45cn's Avatar
Start with zero delay. That keep tail in midstick. Do pitch pumps and slow turns. If there is wag, dial down the gain. If you get this right, then you can proceed with delay. For that do quicke left and right turn stabs. If the tail bounces (small wags on each end), increase delay.
Right in the Futaba 401 manual(401B is an exact copy) you DO use the delay with a non digital servo to get rid of wag.
Old Nov 29, 2008, 02:42 AM   #26
Team Mulikow
Gino CP's Avatar
Ok.Thanks for the heads up.
Old Nov 29, 2008, 12:27 PM   #27
Jimbo45cn's Avatar
No problem Gino. Thanks to you for giving me the heads up on this gyro. Tried it out on my Belt CP this morning and after some adjustments on my radio and on the delay, got it to working, and it works very well!! Was getting gusty out this morning ( about 15mph ) and it held fine. Just need to do a little mechanical centering, and all should be well. No drift ( as the Eskys do) and very good hold, I dare say as well as the GY 401. The ONLY thing I noticed that was funny is that the piros are quicker one way than the other, and again, that might be solved with me mechanically centering the tail. Will keep all posted. Jim
Old Nov 29, 2008, 01:07 PM   #28
Sqwash Plate!
murdnunoc's Avatar
Running as short a servo arm position as possible will also allow you to run higher gain without wagging. I position mine only long enough to allow full pitch slider travel.
murdnunoc is offline Find More Posts by murdnunoc   Reply With Quote
Old Nov 29, 2008, 01:13 PM   #29
Sqwash Plate!
murdnunoc's Avatar
I just received my 401B yesterday and stuck it on my Trex 450.
WOW.
I haven't flown a 401, so I can't compare it to that, but I've been flying the Trex on a Logictech 2100.
The 401B doesn't seem like it's strung out on caffeine like the 2100. Very, very solid. It didn't look like it was struggling at all in high speed reverse flight, and pitch pumps didn't show a hint of the tail moving.
Haven't had strong winds or extreme temmperatures yet to test it against.
I did wind up increasing the Delay to about 30%, even with a JR 3400G digi servo, to get rid of bounce after a piro.
Old Nov 29, 2008, 01:35 PM   #30
Jimbo45cn's Avatar
Good call murd, I am all the way out on the end of the servo arm. Going to try movining it in a hole. Thanks, Jim
Align HH gyro on Trex-need help w/setup atrr Mini Helis 27 Feb 13, 2009 04:56 AM
Which rated ESC's on DF 2004 with HH gyro Willard Micro Helis 2 Oct 07, 2004 02:06 PM
need input on what HH gyro to buy! birdie_in_texas Micro Helis 14 May 27, 2004 09:05 AM
Question Going separates w/HH gyro on HB luvhelis Micro Helis 4 Mar 23, 2004 10:07 PM
How HH gyro behaves on Hummingbird. GoodHeli Micro Helis 2 Sep 12, 2003 08:42 PM
Bored? Want to fight?
Join the RCGroups clan!
