This thread is privately moderated by jadamian75, who may elect to delete unwanted replies.
Old Nov 20, 2008, 06:27 PM
jadamian75 is offline
Find More Posts by jadamian75
Trader Rating: 23
jadamian75's Avatar
Fort Collins Colorado USA
Joined Oct 2007
Trader Rating: 23
Sold
Scorpion S-3014-22
Scorpion S-3014-22 Used only a 4 times.
$37 shipped in the USA Paypal required
Scorpion 3014-22
[S-3014-22T]
Scorpion 3014-22
Scorpion Competition Series Brushless Motors are built from the best materials available, and are designed to provide both quality and performance at an affordable price. Scorpion starts with high quality aluminum alloy parts that are produced on the latest CNC milling machines. These parts are then gold anodized to provide a beautiful, long-lasting finish. The stators are made with 0.2mm laminations to give maximum efficiency, and minimum Eddy current losses. The stators are epoxy coated to prevent shorts, and are wound with wire that is rated at 180 degrees C (356 F). The magnets used in Scorpion Motors are N-50EH style, which are rated for operation at 200 degrees C (392 F), making a motor that is virtually impossible to burn up in normal use.
All Scorpion 30mm motors come with 3.5mm male Bullet style connectors already attached, and include a complete hardware package that contains the following: 3 matching female Bullet connectors for your speed controller, a cross style backplate mount with 4 screws, and a 6mm threaded shaft prop adapter.
Scorpion Motors are built to last, and are backed with a 2-Year warranty against defects in materials or workmanship. For the best overall combination of quality, performance, and value, give Scorpion Motors a try!
Specifications
Stator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ........................... 14.0 mm (0.551 in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 14
Motor Wind ........................................... 22 Turn Delta
Motor Wire ...................... 14-Strand 0.19mm (32 AWG)
Motor Kv ............................................. 892 RPM / Volt
No-Load Current (Io) ................................. 1.22 Amps
Motor Resistance (Rm) ............................. 0.062 Ohms
Max Continuous Current ............................... 30 Amps
Max Continuous Power ................................ 550 Watts
Weight ...................................... 122.1 Grams (4.31 oz)
Outside Diameter ......................... 37.50 mm (1.476 in)
Shaft Diameter .............................. 4.97 mm (0.197 in)
Body Length .................................. 31.9 mm (1.256 in)
Overall Shaft Length ....................... 70.5 mm (2.776 in)
jadamian75 is offline Find More Posts by jadamian75
Old Nov 20, 2008, 09:37 PM
efarmflyer is offline
Find More Posts by efarmflyer
Trader Rating: 54
Monticello, Indiana
Joined Sep 2008
Trader Rating: 54
PM sent.
efarmflyer is offline Find More Posts by efarmflyer
Old Nov 20, 2008, 11:28 PM
Trader Rating: 54
Monticello, Indiana
Joined Sep 2008
Trader Rating: 54
I'll take it!
For Sale Neu 1107H, Kontronik 400, Scorpion 3014-22, JGF 500xt huantran Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2008 09:23 PM
For Sale Scorpion 3014-22 Brushless Outrunner! avi8freak Aircraft - Electric - Power Systems (FS/W) 6 Jun 14, 2008 05:22 PM
Sold SCORPION S-3014-18 Outrunner punkindrublik Aircraft - Electric - Power Systems (FS/W) 4 Dec 16, 2007 04:33 PM
F/S Mega 22/30/3 w/ SuperBox + extra's MailOrderGuy Aircraft - Electric - Airplanes (FS/W) 1 Sep 19, 2003 03:13 PM
