Old Nov 20, 2008, 03:46 PM
eliworm is online now
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
F-104 Quickbuild
Here is a F104 that I have been working on for a few weeks. Test flight was this morning and it was successful enough I think that I can let the plans out for people to play with. It took a little to get to the success part. The test flight was crazy. It was not like anything that I expected. I thought it would be twitchy in the roll axis but it is rock solid there. I was way off in guessing the CG. I put it at the leading edge of the wingtip. Steve gave me a hand launch and it was crazy from there. Nose straight up climb and totally out of control. I got it up about 100 feet and fed in all the down trim and that didn't help. After hanging on the prop for about 30 seconds I throttled back and things got worst. I ended up behind everyone about 5 feet off the deck inverted, I rolled it around just as I flew into the sun and dumped it at that point. Landed hard but level and all was OK. The prop was running when I landed so I ended up spinning the prop nut off and loosing it. I installed a new nut and moved the CG forward. Steve launched again and it was night and day, smooth and controllable. I landed and adjusted again and all is good. Fast with a very fast but smooth roll rate. I need to explore the stall some more as it seems to be very deep when you get there, maybe play with the CG some more. Overall it seems very flyable. Landings are a surprise as well, slow with good flare authority. So, three flights made and coming home in one piece. On Friday I'll run it through some more tests. I have it setup with flaperons so I'd like to see how they work although I really don't need to slow it down anymore for landing.
Specs:
Wingspan 18 3/8 inches.
Length 43 inches
Motor Scorpion HK 2208-28
Prop 4.5 x 4.1
Battery used 1000 and 1300 X-caliber 3 cell
Material 6 mm depron
Edit: Added the tiled plans for download. Thanks Pat for the tiling the plans.
Jim
eliworm is online now Find More Posts by eliworm
Old Nov 20, 2008, 04:58 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Excellent. I've sometimes wondered if this plane might be differcult to make fly due to short wings, but obviously this is not the case.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Nov 20, 2008, 05:07 PM
Sixter is offline
Find More Posts by Sixter
Flying Models for 52 Years!
Sixter's Avatar
Georgia, United States
Joined Oct 2002
COOL Pictures and a Video would be nice
Bobby
Sixter is offline Find More Posts by Sixter
Old Nov 20, 2008, 05:32 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
One of my all time favorite planes. Thanks for posting it.
rmgmag is offline Find More Posts by rmgmag
Old Nov 20, 2008, 07:16 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
wow thats cool! and look its free!
GreenAce92 is offline Find More Posts by GreenAce92
Old Nov 20, 2008, 08:08 PM
ededge2002 is offline
Find More Posts by ededge2002
ededge2002's Avatar
Newmarket,Ontario, Canada
Joined Dec 2002
very nice design of a wonderful airplane. man would that look good with some scale paint! always loved the tiny winged 104. do you know the weight made from 6mm? wonder if a 3mm lightweight could fly indoors......
ededge2002 is offline Find More Posts by ededge2002
Old Nov 21, 2008, 07:24 AM
eliworm's Avatar
Arizona
Joined Jun 2002
Thanks everyone. I tend to get lazy with paint and such especially if I'm not sure the plane will fly the way I like. I think it's time to search the web and find a good color scheme.
The weight ready to fly without battery is 7.1oz. We'll see how much that goes up with color.
Jim
Old Nov 21, 2008, 08:34 AM
kwinters is offline
Find More Posts by kwinters
Autryville, NC
Joined Dec 2006
Looks good - 'bout time we see a new eliworm design!!
KW
kwinters is offline Find More Posts by kwinters
Old Nov 21, 2008, 09:12 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Eli, that's pretty COOL Dude!!!!!!
gpw is offline Find More Posts by gpw
Old Nov 21, 2008, 06:20 PM
eliworm's Avatar
Arizona
Joined Jun 2002
More flights today but not much in the way of photos. It likes big wide turns, loops were surprisingly tight though. I wanted to play with slow flight but for some reason my motor kept cutting out at the worst times. I dropped full flaps one time and she would come down at about a 45 degree angle but it was controllable. Just as I advanced the throttle it cut out. I tried to get it to run again but no go. Not the best glide with the tiny wing but I got her down but with minor damage to the tail. A little ca and I was back in business for another flight. I hope I can keep her flying so i can explore the flying characteristics more. So far it's been fun and a attention grabber.
Jim
Old Nov 21, 2008, 07:55 PM
BDOG1 is online now
Find More Posts by BDOG1
Held by Grace
BDOG1's Avatar
Upstate New York
Joined Apr 2006
104 Star fighter
Very Nice Eli !
Are you using elevator ? I only see 2 servo's
BDOG1 is online now Find More Posts by BDOG1
Old Nov 21, 2008, 08:51 PM
SPITFACED is offline
Find More Posts by SPITFACED
Joined Nov 2006
Hello, great looking little jet Eli, May I ask what KV is the motor you are using, Thankyou Rod
SPITFACED is offline Find More Posts by SPITFACED
Old Nov 21, 2008, 09:02 PM
eliworm's Avatar
Arizona
Joined Jun 2002
Thanks for the kind words.
3 servos, the elevator servo is behind the motor with an extension for the servo leads around the prop.
KV is 3125
Jim
Old Nov 22, 2008, 09:50 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Jim,
Looks like another winner! Are you going to be out Friday at Nichols (day after Thanksgiving?), or the Wingnutz field on Saturday? I really want to see this thing in person!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Nov 23, 2008, 02:57 AM
MiyagawaYutaka is offline
Find More Posts by MiyagawaYutaka
Yokohama_Japan
Joined Dec 2003
wow amazing!! wonderful design
MiyagawaYutaka is offline Find More Posts by MiyagawaYutaka
F-104 - Wemotec micro design U812 Electric Ducted Fan Jet Talk 517 Oct 14, 2012 11:26 PM
My F-104 Starfighter terje s Electric Ducted Fan Jet Talk 55 Nov 01, 2008 12:08 PM
F-104 flies U812 Electric Ducted Fan Jet Talk 157 Dec 07, 2004 07:47 AM
Wanting to make a F 104 starfighter kushal_22 Electric Ducted Fan Jet Talk 4 Dec 23, 2002 12:08 PM
F-104 Starfighter for EDF-50, is it possible ? Rudi Electric Ducted Fan Jet Talk 48 Nov 15, 2002 07:03 PM
