Old Feb 25, 2003, 03:41 PM
Dampy is offline
Find More Posts by Dampy
honey... anOTHER PLANE!
Dampy's Avatar
Cedar Park, TX
Joined Aug 2002
Suggestions for EPP/Tuff plane, 3-4ch Ail/Elev/Rud aprox 48 to 60” span
Wondering if you guys can help me, I’m looking for an EPP (or durable) plane to step up from my combat wing. I like the DAW 1-26 2M, but don’t think I can get it in my car (wing not removable), I’ve also looked at ‘Mad Highlander’ but span is too big. There’s a lot of combat warbirds that get my juices flowing but I need a ship primarily for lighter to medium lift with options for more ballast weight in stronger conditions.
Requirements:
1. Aprox. 48 to 60” wingspan, a little longer if wing is removable
2. 3 to 5 channel, must have Ailerons, Rudder & Elevator. (Flaps OK but not essential)
3. Durable, EPP or similar, I’m sure I’m going to beat it up!
4. Must fly in light lift 5mph or so.
5. Primarily for slope, bungee launchable would be a plus
6. Needs to be faster and more exciting than my old combat wing!
The DAW 2M 1-26 would be perfect, has anyone modifed it for a removable wing?
Ahh just read a thread pointing out the planes at http://bowmanshobbies.com/ That ‘Commanche’ looks pretty quick & slick? Anyone?
Any suggestions as always would be greatly appreciated.
Thanks guys,
Neil
Dampy is offline Find More Posts by Dampy
Old Feb 25, 2003, 04:18 PM
dcairns is offline
Find More Posts by dcairns
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
You would probably find the Highlander boring. It is good for a beginner, but if you know your way around flying a wing, then the Highlander will be slow and heavy. You might want to checkout some of the higher performance foam planks out there (Bluto, Moth, Gulp etc). Some of them can be built light enough to work on light days and ballast up for serious wind. Isn't there a 60" gulp out now? That might work depending on the weight.
If you can compromise on the light lift requirement, then some of the warbirds can be a possibility if built light.
Bowman makes good planes. I have a JW that I built heavy, it is a blast when I have strong lift.
dcairns is offline Find More Posts by dcairns
Old Feb 25, 2003, 04:32 PM
bjaffee is offline
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
It doesn't have a rudder, but the Cobra seems to fit your other categories...
http://www.magnum-models.com/new_page_2.htm
I think the Comanche would work too, though I don't know how much faster then a wing it is.
bjaffee is offline Find More Posts by bjaffee
Old Feb 25, 2003, 07:20 PM
scififlyer is offline
Find More Posts by scififlyer
Registered Useless
scififlyer's Avatar
United States, TN, Knoxville
Joined Feb 2003
Sounds like you want a lightly-built ODR plane with a rudder, there are a few EPP 60" racers to choose from. One-Fun, Foam-One, Cobra, Enigma, etc. Check out some reviews at slopeflyer.com for more info. And I am the reviewer for the Cobra; even at 20 ounces it really needed at least 10 mph winds to fly without worries on an inland slope. Your flyage may vary.
scififlyer is offline Find More Posts by scififlyer
Old Feb 25, 2003, 09:17 PM
stegre is offline
Find More Posts by stegre
CaliforniaSailplanes.com
stegre's Avatar
So California
Joined Dec 2002
Epp plane
A shameless plug here. I import the Canterbury Sailplanes line from New Zealand.
A rudder is not very effective on a EPP slope plane, they just seem to make to nose wiggle.
Their plane, the Eraser, is a GREAT trainer in addition to being very aerobatic if you want it to be. The quality is superb, nice dense EPP, Computer cut, cut outs already completed for radio gear. The kit also has several items not included by any other manufacturer, the glue, reinforcing tape and covering tape.
When you are ready to move on, they also have an F-20 Tigershark, P-51, etc.
There are several flying videos of the planes on my site....
Also... there is a complete satisfaction money-back guarantee
Please take a look, I'll add the link below
Sailplane Steve
californiasailplanes.com
stegre is offline Find More Posts by stegre
Old Feb 25, 2003, 09:41 PM
Vinnya42 is offline
Find More Posts by Vinnya42
Lifes 2 short, go sloping
colorado @ 5500feet
Joined Sep 2001
I have a 1-26 clone I copied from the dave's kit and I made my wing removeable and made it into two pieces. It flew great and it really was a blast to fly.
I had a friend who bought the daves 1-26 kit and make the wing removeable, he just slid it in to place a used some tape to hold it. He could do some increadable tricks and fly-bys that were so fast... it was a great plane. I put the tape then I put 2 tiny screwdrivers (with the swivel heads) in the front and back all the way through the top of the fuselage, then the wing and through the bottom of fuselage. I just reenforced the holes with fiber tape and it has worked fine even in the toughest crashes or cartwheels.
It worked great for two of us it could work for you too
Vinnya42 is offline Find More Posts by Vinnya42
Old Feb 25, 2003, 09:53 PM
mlcleary is offline
Find More Posts by mlcleary
Danville, CA
Joined Jan 2003
When I built my DAW 1-26 it was designed to have the wing removable. This is a very fun plane in light to moderate lift. Get a JW type for higher wind. These are not as 'cool' as molded planes but the price/fun ratio is a no brainer. Save your money until you have your landings wired.
mlcleary is offline Find More Posts by mlcleary
Old Feb 26, 2003, 02:37 AM
webguyjv is offline
Find More Posts by webguyjv
Int'l Slope Observer
webguyjv's Avatar
Fremont, CA
Joined Oct 2001
DAW 1-26 2M? I Now Have Two ;-)
I loved my first one so much, I bought a second kit, as my first one had gone through hell (still flying though).
On the first, I built the one-piece 2-meter wing, and I always simply slid it in place at the slope site. I NEVER had a problem with the wing sliding out of place. There are instructions in the manual for this eventiuality that involve a light spraying of 3M-77 in the wing saddle (to tighten up the slide-in mouting of the wing).
On my new 1-26 2-meter, I bashed it using some recommendations from fellow EZoners. There were at least two threads I found with an RCGroups search, and I sent these nice folks e-mail messages. Some repliued with URLs for detailed instructive Web pages they created.
I made this new wing as a two-piece wing, with some drilled plywood blocks epoxied to the spars. These blocks are approx. .75"h x .62"w x 4.00" l, with a long ~.31" holde drille in on a slight angle. Then a brass tube is epoxied inside the hole. Then I purchased a solid piece of CF rod and another brass tube that was sized to fit inside the tube epoxie into the blocks. I eopxied the 8" long CF rod into the 8" long brass tube and a wing joiner was born!
I also bashed the empennage to have a bolt-on horizontal stab. This makes the whole plane pack into a MUCH smaller package AND if you ever need to adjustthe decalage, you can simply loosen the nylon screws on the stab, and place shims under the surface until you're happy with the angle of incidence.
I LOVE the DAW 1-26 2-meter! That being said, you DID mention 48" to 60" span. Why not consider in stea, the DAW 1-26 HLG. This baby has a 60" span and it flies quite a bit lighter than the 2-meter, and I've seen MANY on the slope. It's a really nice plane as wel.
Happy Flying ;-)
Webguyjv
webguyjv is offline Find More Posts by webguyjv
Old Feb 26, 2003, 12:25 PM
ACM is offline
ACM
Find More Posts by ACM
ACM
slopetrash wannabe
Belly of the Beast/NorCal
Joined Feb 2003
Check out ackermanaircraft.com 48 or 60 v-tail epp sloper
ACM is offline Find More Posts by ACM
Old Feb 26, 2003, 01:32 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Re: DAW 1-26 2M? I Now Have Two ;-)
John:
You and I are gonna have a chat soon's I get around to hauling my 1-26 kit outta the box, k?
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Feb 26, 2003, 02:51 PM
Dampy is offline
Dampy's Avatar
Cedar Park, TX
Joined Aug 2002
Great info guys!
Now I'm wondering how beneficial is it to have a rudder on an EPP slope ship as pointed out a few posts up, or if I even need one? I've flown 4 channel gas planes & wouldn't fly one today without a Rudder!
I'm really looking to pick up speed, manuverability, control and start dancing!
Bluto / Moth / JW etc. these planes look like their built for speed allright, but I imagine they are similar to my combat wings? Am I Wrong? Still awsome looking though, may have to get one anyway!
Bowmans, Ackerman and this plane
http://www.magnum-models.com/new_page_2.htm (thanks bjaffee)
Ah I don't know, so many options.......
Looks like I'm going to end up with 3 planes instead on 1
1. DAW I-26 2M
2. JW
3. Ummmmmm.....
My wife is going to have a COW!
Anyone have suggestions how to hide/disguise slope planes in the house so the missis won't find them?
Marriage counceling suggestions anyone?
Old Feb 26, 2003, 03:49 PM
bjaffee is offline
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
On a small slope plane (60" and under) you definitely do NOT need rudder at all. It's fun for doing certain aerobatics, but as far as tearing around the slopes goes, it just isn't needed, and most small slopers don't use them. A lot of smaller v-tail slopers do have rudders, but I think that's just because it's so easy to setup (since they already have two control surfaces on the tail anyway).
Old Feb 27, 2003, 10:13 AM
Dampy is offline
Dampy's Avatar
Cedar Park, TX
Joined Aug 2002
Then the Rudder is GONE!
Thanks BJAFFEE,
I'll forget the rudder for now, since my main intentions are to pickup the speed but keep the ship light!
The DAW 1-26 will have to wait for now.... that magnum models ODR or Moth/Bluto/JW/Gulp?? plank I think will do the job.
Any preferences for lighter lift when it comes to the Moth, Bluto, JW or Gulp ? I wonder if the larger span would use light lift better or would it just be heavier?
thanks for your input
Neil
Old Feb 27, 2003, 01:58 PM
bjaffee is offline
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
For light lift, I think the Moth is probably the best of those choices. Definitely not the JW! Not sure about the others.
Old Feb 27, 2003, 02:53 PM
McGrrr is offline
Find More Posts by McGrrr
McGrrr's Avatar
Cedar Park, Texas, United States
Joined Jul 2002
Not the Bluto.
McGrrr is offline Find More Posts by McGrrr
Question Propeller suggestions for Mega 16/15/3 Please schwartzy Power Systems 18 Jul 30, 2004 10:09 AM
Motor/battery suggestions for EPP Turbo Porter 60" wingspan / 45oz. AUW surfimp Power Systems 14 Jan 27, 2004 11:14 PM
Suggestions For First Balsa Plane ArcherAce Parkflyers 28 Jul 10, 2003 06:10 PM
Suggestions for a SP 400 plane Zoom_b5 Electric Sailplanes 1 Jun 07, 2003 12:25 AM
48"+, EPP, ail/elev/rud/ speed 500, 8 cell super FUN-FLY Arf-that's what I want Balin Foamies (Kits) 0 Jul 22, 2001 10:46 AM
