Old Feb 25, 2003, 03:11 PM
Sylvain is offline
Find More Posts by Sylvain
Sylvain's Avatar
Canada, QC, Rimouski
Joined Feb 2002
HS-81 servos equivalent replacement
Hi,
I'm using HS-81 servos in my ELMH. I burned out 3 of them in the last year. I'm now looking for another brand of servos that will last longer than the HS81. Let me know wich one have a proven reliability. They need to be the same size as the HS81.
Thanks............Sylvain
Sylvain is offline Find More Posts by Sylvain
Old Feb 25, 2003, 03:20 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Did you burn them out, or just strip the gears?
There's a few servos the same size:
Hitachi HS-85
Volz Micro-Maxx
etc.
Toshi
TMorita is offline Find More Posts by TMorita
Old Feb 25, 2003, 03:37 PM
Sylvain is offline
Sylvain's Avatar
Joined Feb 2002
The little motor in the HS81 servo burn out easely. That is the problem. Maybe Futaba have an equivalent servo that will be more durable, and more expensive!! The gears are good.
Sylvain
Old Feb 25, 2003, 04:07 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
The Dymond 200BB is the same size and weight as the 81's.
A ballbearing output shaft too.
Haven't put them on a heli yet but I gave a pair a beating on my TwinStar. Durable.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Feb 25, 2003, 04:32 PM
EricWeder is offline
Find More Posts by EricWeder
Crossfield, Alberta, Canada
Joined Apr 2002
Stripped a lot of gears in the HS-81's on my Corona. I switched to JR 341's - no stripped servos anymore. Never had a motor burn out in the HS-81's either though. I've got a JR DS368 on the tail rotor now, just because! Maybe I'll try the Futaba GY401 & 9253 servo, but first I need to overhaul the tailrotor it's all bent and shakes like mad.
Eric
EricWeder is offline Find More Posts by EricWeder
Old Feb 26, 2003, 02:36 AM
Jason M is offline
Find More Posts by Jason M
20 years on RCG!
United States, IL, Champaign
Joined Dec 1996
The Futaba 3101 and 3102 are the same size as 81s.
The 3101 is about $30 with nylon gears. The 3102 is the same servo with metal gears, but its like $60!
Either one is a great choice, along with the JR 341s and even the Dymond servos.
Jason M is offline Find More Posts by Jason M
Old Feb 26, 2003, 10:25 AM
jmper is offline
Find More Posts by jmper
Corona, CA
Joined Jan 2003
HS81 equal
If your using this for the tail then the JR341 and the Futaba 3101 or 3102 are a bit on the slow side. If you are burning up the HS81 then I assume you are using heading hold. Try running your gyro in conventional not heading hold. You may also be able to try the Futaba 3103 or 3106, slightly smaller but have the same speed specs the HS 81. Haven't tried these on a heli. If you dont mind a little filing you could try the Airtronics 94145? micro high speed. Slightly bigger than HS81's but I don't think you will burn these up even using heading hold. Also if you are using the latest types of gyros make sure the frame rate is set for normal not fast unless using specific servos built for fast frame rates.
jmper is offline Find More Posts by jmper
Old Feb 26, 2003, 10:43 AM
GKurt is offline
Find More Posts by GKurt
Chicago
Joined May 2002
Sylvain
If you are burning these up only in the tail, then like jmper said, it could be the gyro over-working it. Another suggestion would be to lower the gain in HH mode.
You said you burned-up three in a year, but that could be a lot or a little, depending on how much you fly. With how much I fly right now, in the fridged Midwest, I can go a decade without burning anything up.
Greg
GKurt is offline Find More Posts by GKurt
Old Feb 26, 2003, 11:34 AM
Sylvain is offline
Sylvain's Avatar
Joined Feb 2002
Thanks for all the replys guys,
I'm not using a HH gyro, I use a cheap piezo gyro. I did burn 1 or 2 on the tail and 2 on the swashplate. Three of the four servo's damage happened while I was experimenting a lot of glitches. If we could buy replacement motors for the HS81 servos, that would be a good thing. Anyway, I'll probably stick with the Hitec servos because they are less expensive and I already have a few set of spare M gears and P gears.
Thanks...........Sylvain
Wanted WTB - Hitec HS-81 Servos - or equivalent freedomflyer Aircraft - General - Radio Equipment (FS/W) 1 Jul 10, 2006 07:35 PM
replacement motor for HS-81 servos Sylvain Electric Heli Talk 6 Dec 13, 2002 01:36 PM
WTB hitec focus 3 with receiver and hs-81 servos varnellb Aircraft - Electric - Airplanes (FS/W) 5 Oct 30, 2001 06:08 PM
!!Hitec Flash-5, with Micro 555 Receiver, 2 HS-81 Servos!! karl446 Aircraft - Electric - Airplanes (FS/W) 2 Oct 19, 2001 09:23 PM
will HS-80 gearsets work in HS-81 servos ericstac Power Systems 3 Jun 01, 2001 03:16 PM
