Old Nov 19, 2008, 09:52 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Build Log
Mooney Mite from BB tribute contest
Finally finished the tiled pdf of major panels for the Mite, so here goes with a build guide:
This plane is based on the M-18 Mite, the first plane that Mooney produced back in 1946. It was originally powered by a Crosley engine, but typically either a 65hp Lycoming or Continental. Only 540lb empty weight. Lots of info on the Mite owners site: http://www.mooneymite.com/
As built, it has a 40" span and 13.15oz auw including a BM2410-09 motor and 2s mystery 900mah pack. She is a smooth flier, not quite as forgiving as her ancestor BluBaby, but still can be a relaxing flight. Haven't tried 3s yet, but I expect that would spice it up a bit. Wing is removeable, rubberbanded on, and provides access to the battery bay. I also made the canopy removeable as I hope to make a heat formed pop bottle clear one.
Below you will see the original plane, and a few pics of the model.
Here's a link to the video of the maiden (pre- paint and gear): http://www.rcgroups.com/forums/showthread.php?t=946714
and here with gear and paint: http://www.rcgroups.com/forums/showthread.php?t=949165
springer is online now Find More Posts by springer
Old Nov 19, 2008, 10:22 PM
treefinder
springer's Avatar
SE MI
Sketchup model information
Here's the sketchup model I made from the three view I found on the mite site.
Also included is a tiled pdf of the major panels.
Old Nov 20, 2008, 12:08 AM
7up is offline
7up
Find More Posts by 7up
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
@springer,
Congrats! Nice design, thanks for the SU file.
7up is offline Find More Posts by 7up
Old Nov 20, 2008, 04:50 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
It's a BEAUTY!!! Spring!!!!
gpw is offline Find More Posts by gpw
Old Nov 20, 2008, 06:48 AM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Nice design Mike.
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old Nov 20, 2008, 08:28 AM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
Definitely your best work Mike!
What is next? A Swift? That would be an easy mod to this.
SGTalon is offline Find More Posts by SGTalon
Old Nov 20, 2008, 10:03 AM
treefinder
springer's Avatar
SE MI
Dennis: funny you say that, one of the guys I have breakfast with on tues has a Swift, unfortunately it's in pieces and unlikely to get flyable any time soon, but I could get an up close look at one (as compared to the Mite which I've only seen in pictures)
Old Nov 20, 2008, 12:32 PM
dz1sfb is online now
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Really a great looking model Mike. Echoing SGTalon's words "your best work yet". Congratulations!
Ken
dz1sfb is online now Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Dec 09, 2008, 04:18 PM
treefinder
springer's Avatar
SE MI
build log continued Main landing gear assembly
Finally getting to make dwgs of the main gear parts. First two pictures show the base plate with clips glued to the bottom of wing. Next are jpegs of the parts, and last a sketchup file of them.
The slot in the clips has to be sized to the wire you use plus the thickness of the base plate. I used 5/64th music wire. Test fit the clips in their slots in baseplates, as the 1/16" ply will also affect the slot size. Final filing should be done after it's all glued to the wing, of course. I used a round riffle file to finish the slots, and it created a rounded pocket that the wire snaps into nicely.
after making the wood parts, place the baseplates on the wing, and mark, then cut slots in the wing to receive the clips. I traced around the baseplates and removed the skin of Blucor for improved adhesion of the Gorilla glue. Put the clips in their respective slots (outboard clips face slot forward, center one faces aft) with glue then slip the base plates over clips and glue them down. (I think I actually put the outboard clips in the base plates and then glued them down, Center one pretty much has to go into wing first.)
The wire was an interesting exercise. I started in the center and bent it outwards each direction. The only criteria other than sizing the actual axle portions to the width of your wheels, is that I set angles of the vertical portions so axles are about 1/4" aft of the base leg in the side view. It made the gear trail nicely, and the bend in the vertical legs provides a little bit of shock absorption (not as good as a spring coil obviously) and looks a bit like the real gear. I didn't add the gear cover that would sit on outboard side of each vertical leg, but one could do that for more realism.
Old Dec 09, 2008, 04:21 PM
treefinder
springer's Avatar
SE MI
Here's the sketchup file of the gear, change the extension to .skp
Old Dec 09, 2008, 04:29 PM
treefinder
springer's Avatar
SE MI
Nose gear wasn't specially made, was a tail wheel kit I found on Hobby King, and adapted. I did glue a reinforcement to the nose to take the 4 screws that hold it in. Originally I let it swivel, but it made the plane track very wobbly at slow speeds, so I tightened it up, doesn't steer as well, but tracks and takes off and lands much nicer.
Old Dec 09, 2008, 04:32 PM
treefinder
springer's Avatar
SE MI
I think that's it. I'll try to answer any questions for those interested in building her
Old Feb 15, 2009, 07:39 AM
tr3kilroy is offline
Find More Posts by tr3kilroy
Joined Dec 2005
Amazed
I love this little airplane! I stumbled on this from a different thread and then searched it out. I've always loved Mooney design and think that your version does great credit to the style of these great little planes.
I'm down for a few weeks from having surgery but as soon as I'm able to build again I'll be putting this on the top of my list!
Thanks so much for publishing these plans. There are so many great airplanes floating around that no one ever sees and this is definitely on of the better I've seen in a long time.
tr3kilroy is offline Find More Posts by tr3kilroy
Video BB tribute Mooney Mite with Gear! springer Electric Plane Talk 7 Nov 12, 2008 10:20 AM
Video Mooney Mite Maiden (BB tribute contest) springer Electric Plane Talk 8 Nov 04, 2008 06:32 PM
Super Mite from Superfly RC scantech Electric Ducted Fan Jet Talk 12 Sep 22, 2005 11:58 PM
Mini-Review The simultaneously fun and craptacular: Silverlit X-Plane (from BB&B) Smokescreen38 Parkflyers 3 Sep 15, 2005 08:44 PM
