Old Nov 19, 2008, 09:01 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Contest
Funbuild II Contest Hawker Typhoon adapted from Brian Taylor Plans
Here is my thread for the Brian Taylor Hawker Typhoon. WS is 52" built primarily from foam. Bob
Foamenator is offline Find More Posts by Foamenator
Old Nov 20, 2008, 04:00 PM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Bob,
Very good subject . What is the projected size for your Typhoon ?
Got you added to the build entries
Good luck , and thanks for your participation
-John
jofrost is offline Find More Posts by jofrost
Old Dec 08, 2008, 08:11 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Originally Posted by jofrost
Bob,
-John
Hey John... I'm finally getting started. The Typhoon 1A will be approximately 1/10th scale. The wingspan is 52" and length will be 40". I plan to have retracts, flaps and bomb drop. Primary construction will be Depron foam. Bob
Old Dec 12, 2008, 06:01 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
First Pics....
Have all the parts for the fuse cut out. I'm using 5mm cellfoam for the top and horizontal spines and the formers forward of the cockpit. I'll use 3mm cellfoam aft of the cockpit.The modified monobloc will carry all stresses of the motor, electronics, and wing. and contains the battery and electronics. Tail section will be reinforced with carbon fiber in the area of the tailwheel
Power will be a 2836-10, 30 amp esc. and 2200 mah 3s lipo. The motor should provide about 50. oz of thrust. Battery is mounted vertically directly behind the motor. All other electronics and four servos will be forward of the cg which is indicated by the red line in the pictures. That's all for now. Bob
Old Dec 13, 2008, 08:08 AM
xterarc is offline
Find More Posts by xterarc
frenzyscot
Dundee, Scotland
the more the merrier
Obiously love the subject, want to see how this foam birds is going to look finished, what are you planning the cover with/finish
cheers and good luck
xterarc is offline Find More Posts by xterarc
Old Dec 14, 2008, 07:59 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Xterarc... I plan to reinforce stress areas internally with lightweight glass and p/u and some carbon fiber. I plan to seal the visible surfaces with p/u and baby powder mixture and sanded off. Bob
Old Dec 14, 2008, 09:48 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Progress on the cowling
Worked my way along the nose. I figure this is going to take more time than anything. Of course the nose makes the aircraft ing this case. Forward cowling will be held in place by magnets and bamboo pin guides.
Redline reflects balance point. The straw is glued in place to allow me to use a wire to accurately check the balance point at any time.
I will have to form a spinner, 3.25" in diameter. Attached is a Varioprop adjustable pitch propellor. I don't know if I will use it, but it looks cool. Bob
Old Dec 16, 2008, 01:05 PM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Wow Foamenator nice project. I will be watching with interest! Where did you get the plans? Is this the one from the european magazine?
Kevin.
RCDad is offline Find More Posts by RCDad
Old Dec 16, 2008, 02:04 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Kevin.
Hey Kevin... Thanks for checking in on the build. I had the plans in my library. They are Brian Taylor plans originally which had a 72" w.s. These plans are reduced down to 52" w.s. I notice the original plans were drawn in 1990. It is still a good sized model. Bob
Old Dec 29, 2008, 08:20 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Making a Little Progress-Need a Little Help
Pretty much finished the tail feathers. The rudder is supposed to be fabric covered. I'm not sure about the stabilizer.
It looks like all the electronics will have to be within 4" of the firewall. At least cooling won't be a problem.
Does any one know if the elevator was fabric covered? I know the fin and stabilizer are metal covered. Any help will be greatly appreciated. Bob
Old Dec 30, 2008, 12:34 PM
Ron Daniels is offline
Find More Posts by Ron Daniels
Ron Daniels's Avatar
Kitchener, Ontario, Canada
Joined Jan 2001
Everything was metal, except for the rudder.
Ron Daniels
Ron Daniels is offline Find More Posts by Ron Daniels
Old Dec 30, 2008, 08:46 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Ron Daniels
Thanks Ron.... I've looked everywhere for that. Bob
Old Jan 02, 2009, 02:51 PM
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Some Tailfeather Details
Tail feathers are 3mm depron with 1/4 " balsa leading edges and spars. Glue is UHU T&G with hot glue tacks to hold things in place. All controls will be concealed a la the original. Stabilizer has a span of 16.25" and weighs 6.5 grams. Bob
Old Jan 02, 2009, 05:40 PM
jofrost is offline
jofrost's Avatar
Joined Jul 2004
Foamenator ,
Coming along very nicely !
-John
Discussion Kit/Plane fun build contest-Hawker Typhoon beta build baldguy Scale Kit/Scratch Built 268 Oct 07, 2009 11:58 PM
For Sale brian taylor plans available theplansguy Aircraft - Fuel - Airplanes (FS/W) 0 Jun 03, 2008 01:47 AM
Discussion Brian Taylor plans Spitfire. kkw Fuel Warbirds 1 Sep 20, 2007 10:24 PM
Question Contact for Brian Taylor Plans pgleesonuk The Builders Workshop 4 Sep 13, 2006 09:48 AM
FS: 69" P-51 Brian Taylor plans and Parts Ken Lapointe Aircraft - Electric - Airplanes (FS/W) 1 Feb 05, 2003 06:57 PM
