This thread is privately moderated by Happymcc, who may elect to delete unwanted replies.
Old Nov 10, 2012, 01:17 PM
SRQFlyer is offline
Find More Posts by SRQFlyer
Master re-kitter
SRQFlyer's Avatar
Sarasota, Florida
Joined Dec 2005
Tartan twin - glow
Hi folks,
Does anyone have a manual for one of the Tartan engines - specifically the twin, glow version?
Thanks in advance!
Jim
SRQFlyer is offline Find More Posts by SRQFlyer
Old Nov 10, 2012, 06:43 PM
SRQFlyer is offline
Master re-kitter
SRQFlyer's Avatar
Sarasota, Florida
Joined Dec 2005
Tartan twin - glow
To answer my own question - I found some copies of the "manual" - here you go:
Old Nov 17, 2012, 07:24 PM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
Enya .099 - .25 ABC Engine Manual, Circa Early 1980's
Originally Posted by Happymcc View Post
Post your out of print or discontinued manuals here and I will link them through this post by model number.
I've attached PDF scans of this venerable Fuji ABC engine instructions for .099 to .25 engines. It also has data and prop sizes up to .40 engines.
I am not an engine expert by any means. I gather that the Fuji 099S-II, from where the instructions came from, is a rare engine in that it is an ABC baffle piston engine. It has the same horsepower as the Enya 09-III and 09-IV baffle piston engines of .16 HP, but it has a lower compression of 5.5:1 whereas the Enya has 7.5:1. Maximum RPM is listed as 12,500. In contrast, the Enyas have a compression ratio of 7.5:1 and maximum RPM at 13,000, which lends me to believe the compression value is correct (hand flipping reveals lower compression than my Enya 09-III TV and OS Max .10 R/C), and that it is not Schneurle ported. In contrast, the OS .10LA ABN has .27 HP, the AP Hornet .09 has .25 HP. Attached are several pictures of this engine.
30-Nov-2012 - There is a typographical error in the instructions. Where it states, 3) Open the needle valve as follows according to the engine size. 099 engine - Full turns, this should be Four (4) turns.
OkiThumper is offline Find More Posts by OkiThumper
Last edited by OkiThumper; Nov 30, 2012 at 04:53 AM. Reason: Correct instructions typo.
Old Nov 29, 2012, 12:32 PM
buzz007 is offline
Find More Posts by buzz007
german sweets
Joined Nov 2012
thank you
buzz007 is offline Find More Posts by buzz007
Old Nov 30, 2012, 04:55 AM
Closed Account
Joined Feb 2006
Your welcome
Old Nov 30, 2012, 04:32 PM
Freewheelinwheel is offline
Find More Posts by Freewheelinwheel
Joined Nov 2012
Hey Guys,I am new to this site ,not to sure how to get to proper area about prop sizes,maybe yall can help me. I have an 40 size cessna with a os 50 on it.I am trying to slow it down a little with a prop,i had a 12 - 8 on it.What is the best prop size to fly this plane with not so fast but still have the power up front? HELP.
Freewheelinwheel is offline Find More Posts by Freewheelinwheel
Old Nov 30, 2012, 10:41 PM
Closed Account
Joined Feb 2006
OS Max-50SX Ring; FX Series 40,46,61,&91 Engine Manual
Originally Posted by Freewheelinwheel View Post
Hey Guys,I am new to this site ,not to sure how to get to proper area about prop sizes,maybe yall can help me. I have an 40 size cessna with a os 50 on it.I am trying to slow it down a little with a prop, I had a 12 - 8 on it.What is the best prop size to fly this plane with not so fast but still have the power up front? HELP.
You could simply mount the prop backwards. That reduces its efficiency so it won't develop as much thrust.
Is your engine the OS 50SX Ring? Per manual (attached), standard prop sizes are Sport: 11✕6~10,12✕6; Aerobatic: 12✕7~9
You have it set up for aerobatics. Smallest sport prop is an 11x6. I don't know if that will help to tame it to your liking but it's worth a try.
Last edited by OkiThumper; Nov 30, 2012 at 10:43 PM. Reason: Correct manual description.
Old Dec 02, 2012, 01:52 AM
Roguedog is offline
Find More Posts by Roguedog
Roguedog's Avatar
United States, CA, Norco
Joined Feb 2007
You did not say where it was to fast so I'll speculate that it's to fast on the ground.
If that's the case you can use a 12 x 5 or 12 x 6. I really think that a 12 x 8 is too much prop for a 40 sized Cessna. I would think that you should be using 11inch props on that bird even with the 50 sized engine.
If it's to fast in the air - throttle back. You don't have to run the plane a full throttle the entire flight.
Roguedog is offline Find More Posts by Roguedog
Old Dec 03, 2012, 06:52 PM
Closed Account
Joined Feb 2006
Gilbert 074 and 11 Thunderhead Instruction Manual
Attached are the instructions for both the A.C. Gilbert Thunderhead .074 and .11 engines. Although the instructions contain labeling for the .11, the instructions cover both. (I have the .074 one also, and it has the same instructions.) I have attached scans in both color and black & white. For those with limited Internet bandwidth, the BW one is less than 100 kb.
Old Dec 03, 2012, 06:55 PM
Closed Account
Joined Feb 2006
Originally Posted by Roguedog View Post
You did not say where it was to fast so I'll speculate that it's to fast on the ground. If that's the case you can use a 12 x 5 or 12 x 6. I really think that a 12 x 8 is too much prop for a 40 sized Cessna. I would think that you should be using 11inch props on that bird even with the 50 sized engine.
I'm thinking that the throttling range may be too sensitive for him, then the 11x6 prop would be the better choice. That is a common prop for the 40's/46's.
Old Dec 04, 2012, 06:10 PM
Closed Account
Joined Feb 2006
OS Max-10RC Engine Manual
Attached is the manual for the OS Max .10 R/C baffle piston engine. This predates the Schneurle OS Max 10's.
Old Jan 20, 2013, 10:27 AM
sdad is offline
Find More Posts by sdad
United States, MI, Grand Ledge
Joined Jan 2013
OS fs 40
Though mentioned a number of times, I have yet to find a manual for the OS FS 40 -- pre Surpass. I am trying to not use Hobbico unless absolutely necessary. If I find one through a source other than here, I will post a copy on this thread so that others can access.
sdad is offline Find More Posts by sdad
Old Jan 21, 2013, 06:42 AM
DPlumpe is online now
Find More Posts by DPlumpe
AMA 8711, FCC K4WZA
DPlumpe's Avatar
Salem, SC
Joined Mar 2003
OS FS40 non-Surpass
Here 'tis, sdad. Could use some cleaning up, but readable.
-Dave Plumpe
DPlumpe is online now Find More Posts by DPlumpe
Old Jan 21, 2013, 07:15 AM
sdad is offline
Joined Jan 2013
os fs 40
Thanks so much, Dave.
Old Jan 22, 2013, 04:01 PM
Enginery is offline
Find More Posts by Enginery
Joined Sep 2011
abc
Enginery is offline Find More Posts by Enginery
