Old Jul 31, 2001, 11:28 PM
Yoda Dog is offline
Find More Posts by Yoda Dog
Ft.Collins Colorado U.S.A.
Joined Jul 2001
A glider for a beginner
Hi! I was just curious what would be a good glider for a beginner that will be doing hand launches(so probilly an electric glider)
And i will need a plane that is pretty small,
maybe 1-2Meters, and something not to hard to build.
Yoda Dog is offline Find More Posts by Yoda Dog
Old Aug 01, 2001, 02:27 AM
chlee is offline
Find More Posts by chlee
chlee's Avatar
Atlanta, GA
Joined May 2000
If you're looking for a powered glider to use as a primary trainer, i'd look into Darwin garrison's Push-E-cat, because it's made of EPP foam and uses a fairly standard S400 system. http://www.rc-aero.com .
I myself have not flown the push-e-cat myself, so you might do a search on ezone and read up on it.
I actually taught myself on a DAW S1-26 EPP foam glider, launching off a light hi-start. Also a very nice first glider/plane; just don't expect to contest performance out of it. Pretty darn near indestructible -- EPP is definitely the way to go!
G'luck.
Lee
[This message has been edited by chlee (edited 08-01-2001).]
chlee is offline Find More Posts by chlee
Old Aug 01, 2001, 09:09 AM
ShredAir is offline
Find More Posts by ShredAir
slope'n somewhere in the Andes
ShredAir's Avatar
Chile, Región de Coquimbo, Elqui
Joined Mar 2001
Do check out the Just from ES Composites (http://escomposites.com). It's hand-launch glider sized, and it flies as good as it packs small. See my "Just" shredding air post earlier in this forum.
Dieter
ShredAir is offline Find More Posts by ShredAir
Help! Need Entry Level, limited/no build, E Glider for beginner thecirque Electric Sailplanes 8 Mar 23, 2006 05:18 PM
Appreciate advice on e- powered glider for beginner strawcuter Sailplane Talk 9 Jul 24, 2005 06:04 PM
What would be a good thermal glider for a beginner? ChrisFeole Electric Sailplanes 11 Jun 28, 2001 12:34 AM
