Old Nov 17, 2008, 05:32 PM
flyguide7 is offline
Find More Posts by flyguide7
Planes, need more planes
flyguide7's Avatar
United States, MO, Chesterfield
Joined Feb 2006
Falcon 120 EDF Conversion
I recently bought a Falcon 120 from nitroplanes with the intent to convert it to an EDF. I have seen some threads on converting this airframe to a wing but nothing specific to an EDF conversion on the stock airframe.
Here is my set-up:
120 E turbax fan
Castle 110hv ESC
Neu Motors 1521
12s 8000 lipo
Anyway If anyone knows of a build thread for this beast or can give me some advice please drop a line on this thread.
flyguide7 is offline Find More Posts by flyguide7
Old Nov 17, 2008, 05:59 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
See this thread post #197
http://www.rcgroups.com/forums/showt...ighlight=beast
I can answer most of your questions since it was my aircraft and EDF Fan
Clay
racer1 is offline Find More Posts by racer1
Old Nov 17, 2008, 06:14 PM
flyguide7's Avatar
Joined Feb 2006
Thanks for your reply Clay.
First of all how did you attach your fan to the fuse?
Where did you place your batteries?
Which servos did you use?
Which retract set did you use?
Old Nov 17, 2008, 07:58 PM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
Robart 520W1 Tri Gear 90 Deg
Futaba S3002 for tail or Hitec HS-225MG
DS821 Digital Sport High Torque Servo by JR for wings and flaps
Reciever Battery 5 cell 2000 ma pack.
Batteries were 12s 5000ma placed on where the servos mounted later I made a plate to side them more toward the rear. (nose heavy, still fly’s great). 8000 ma packs will require you to shift back your batteries even more.
I custom made a aluminum bracket to hold the fan,, it helped push the fan back. The width of the back of the Falcon matched the width of the Dynamax. I mocked it out of card board first then bent it up, and used screws to attach it to the base of the Falcon.
I took my fan unit and turned into a nacelle so that it had an intake ring and thrust tube.
It made the plane look right plus it is functional.
The ESC was mounted under the fan unit in the open air.
See if this helps
Clay
Old Nov 18, 2008, 07:37 AM
flyguide7's Avatar
Joined Feb 2006
Awesome Clay! Great looking plane. I love that fan mount. Do you know what gauge the sheet metal was that you used?
Also what did you use for the nacelle?
And finally where did you locate your C.G.?
Thanks.
Ed
Old Nov 19, 2008, 11:00 PM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
CG Factory settings 13 inches from leading edge
Fan mount made from 60 thou aluminum sheet bent to shape
Nacelle made intake ring of thin ply molded round and 1 1/2 inch out from the front of the fan , thrust tube made of mylar, blue foam covered, shaped then glassed.
Clay
Old Nov 28, 2008, 08:04 AM
flyguide7's Avatar
Joined Feb 2006
Well I met a guy on the plane home the other day who services Jet Joe turbines so I bought one tested and balanced for what i have in my lipos E-Turbax / Neumotors set-up so I decided to sell the e-set up and go turbine instead.
Video Falcon 120 flying wing conversion with a pusher prop Knife Liddle Electric Plane Talk 2 Nov 11, 2008 09:55 AM
Sold Nitroplanes Falcon 120 flying wing conversion Knife Liddle Aircraft - Electric - Jets (FS/W) 0 Nov 09, 2008 09:09 PM
Video Falcon 120 edf at TEAM 08 darren jakel Electric Plane Talk 1 Oct 27, 2008 06:35 PM
Discussion Falcon 25 Twin EDF conversion flyguide7 Electric Ducted Fan Jet Talk 0 Aug 11, 2008 04:10 PM
Twinjet edf conversion Pete Taylor Electric Ducted Fan Jet Talk 9 Jul 04, 2001 12:29 AM
