Old Nov 15, 2008, 05:41 AM
louy is offline
Find More Posts by louy
australia mate
Joined May 2005
jet joe auto start help!!!!!!!
can any one help me as too why my jet joe auto start does not go into start mode when i push the stick up and down???? sometimes it does and most of the time it dosent.
louy is offline Find More Posts by louy
Old Nov 15, 2008, 09:19 AM
HobbyCNC is offline
Find More Posts by HobbyCNC
HobbyCNC's Avatar
Joined May 2004
Does the manual have a trouble shooting section?
Dave
HobbyCNC is offline Find More Posts by HobbyCNC
Old Nov 15, 2008, 01:51 PM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
Send a PM to 'knobby1'. That's Brett Smith (smithy) who has some connection to Ausjets who had something to do with these engines in Oz.
http://www.ausjets.com/
What ECU are you using? A friend recently bought the same ECU as used with the JJ ,which I believe is a top quality unit, to convert his Wren 54 from manual to auto start. He commented that the start procedure was a little different to the Wren ECU.
Good luck. I have a feeling you are going to need it. - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Nov 15, 2008, 05:45 PM
starzak is offline
Find More Posts by starzak
Tye
starzak's Avatar
Chacotoma, NM
Joined Jan 2004
Make sure that your throttle trim is at high.
starzak is offline Find More Posts by starzak
Old Nov 16, 2008, 12:25 PM
bluescoobydoo is offline
Find More Posts by bluescoobydoo
bluescoobydoo's Avatar
harwich essex
Joined Sep 2004
check you glow plug connection my wren will not even attemp a start if the glow plug has blown
what happens if you leave the stick forward like a jet cat?
bluescoobydoo is offline Find More Posts by bluescoobydoo
Old Nov 16, 2008, 08:52 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
has the throttle set procedure been completed completely and properly
invertmast is offline Find More Posts by invertmast
Old Nov 17, 2008, 11:32 PM
tiny_feet is offline
Find More Posts by tiny_feet
Joined Sep 2008
Hi....Try this if you have one
learn the parameters this allows the TEMS to Memorize and store your radio's throttle settings for shutdown,Idle,and full thrust positions.this has to be done only once unless the radio is replaced.
JR Radio...Throttle ATV (travel Adjust):-100/+100;throttle trim: 50%;normal
Futaba Radio....Throttle ATV:-100/+100 ; Reversed.
tiny_feet is offline Find More Posts by tiny_feet
MP Jet 25/35 prop help mdh Power Systems 7 Sep 07, 2003 07:53 PM
Electric High Start Help PROACE Electric Sailplanes 22 Mar 22, 2002 02:08 PM
Jet Trainer To Start With FERRAN Electric Ducted Fan Jet Talk 10 Feb 22, 2002 03:37 AM
Jet designers I need help DNA Electric Ducted Fan Jet Talk 4 Jan 07, 2002 02:20 PM
