Old Nov 15, 2008, 03:58 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Alert
Metal Motor Mount May Steal Your Mojo!
Today I tested a Keda A22-20L outrunner. Unfortunately the results were a bit disappointing. No-load current draw was quite high, and when propped up it also drew a bit more current and produced slightly lower rpm than expected . Did I get a dud, or was something else going on?
This motor has a very thin bell which is not very effective at containing the field from its magnets. In fact the external magnetic field is so powerful that the motor can easily suspend a 150g (5oz) pair of pliers by the pointy end! So I thought, What if the rotating bell was inducing eddy currents in my aluminium motor mount? Could that be causing the high no-load current and poor performance?
I re-mounted the motor in reverse and repeated the test. This produced much lower Io and better performance . I then tried holding a sheet of aluminium close to the bell, and Io jumped back up to its previous value. Finally, to prove that metal was the problem, I also tried a sheet of balsa - which had no effect.
Results:-
Io:- Reverse Mount = 1.08A, Front Mount = 1.58A (+0.5A, 46% higher).
HD8060:- Reverse Mount = 9731rpm @ 13.3A, Front Mount = 9647rpm @ 13.8A (84rpm lower, 0.5A higher).
According to Motocalc, the metal mount caused a 4% reduction in peak efficiency.
Several Aluminium stick mounts are available which have clearances similar to my thrust stand (eg. Hyperion Z22-MNTSTIK-AL, GWS EMM28A) although since they are shorter the effect may be less. If you are making your own metal mount for use with this motor (or others of similar construction, eg. KDA20-XX series, Turnigy 22XX series) try to maintain a large clearance between the motor bell and the mount!
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Nov 15, 2008, 12:18 PM
landru is offline
Find More Posts by landru
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Very neat discovery!
Along similar lines, I wonder how much motor performance is diminished by eddy currents induced in the aluminum bearing tubes which typically run through outrunner stators. Those tubes can get quite hot. Is all of that heat just radiated from the stator?
landru is offline Find More Posts by landru
Old Nov 15, 2008, 04:22 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
That can be a problem is with stator designs that are not done right. If the motor is designed well you should nearly all the flux contained with in the motor. With outrunners if you have steel objects sticking to the case there is clearly too thin of steel behind the magnets. If the core heats up from the eddy currents then again the stator does not have enough "back iron" between the teeth at the base. The problem is pretty common.
Steve
sneu is offline Find More Posts by sneu
Old Nov 15, 2008, 10:35 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Very interesting - I Currently have ali motor mounts in most of my planes...
jackosmeister is online now Find More Posts by jackosmeister
Old Nov 16, 2008, 01:15 AM
Skycruiser is offline
Find More Posts by Skycruiser
I eat only vegetarian beef
Skycruiser's Avatar
Fairlie, New Zealand
Joined Nov 2006
That does it. Only balsawood motor mounts for me from now on.
Actually I mounted one of these motors last week, and noticed the same strong magnetic field. Strong enough that it can be a struggle stopping the screwdriver from sticking to it.
Skycruiser is offline Find More Posts by Skycruiser
Old Nov 16, 2008, 02:09 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Originally Posted by sneu
... With outrunners if you have steel objects sticking to the case there is clearly too thin of steel behind the magnets. If the core heats up from the eddy currents then again the stator does not have enough "back iron" between the teeth at the base. The problem is pretty common.
Steve,
Yes, definitely a common problem from what I've seen.
How much back iron is enough? I suppose the pros use FEMM to optimize back iron thickness. The rest of us often use the 'paper clip test'. My experience has been that increasing the flux ring thickness beyond the 'paper clip' threshold can significantly extend the power range of a motor. The cost is a smidgen knocked off the peak efficiency.
It's no so easy to play with different stator designs!
Regards,
Andrew
Old Nov 16, 2008, 02:45 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
Steve,
Regards,
Andrew
FEMM is fun to play with --it is sort of a trial and error process to come up with a good design--but given that the tool for a stator die costs $$$ it is worth a few hours of cad work with FEEM making cool pictures of the flux lines. I have some plots saved at work that I will post if I can dig them up.
Steve
Old Nov 16, 2008, 02:47 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Sure, post them. Did you teach yourself FEMM?
Old Mar 15, 2009, 04:12 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
... I have some plots saved at work that I will post if I can dig them up. ...
Have you found them Steve? Would not mind adding to this "animations and simulations" compilation:
http://www.rcgroups.com/forums/showthread.php?t=216928
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 15, 2009, 04:46 PM
Joined Feb 2001
... This motor has a very thin bell which is not very effective at containing the field from its magnets. In fact the external magnetic field is so powerful that the motor can easily suspend a 150g (5oz) pair of pliers by the pointy end! ...
All the information is available, and still some manage to produce cr*p This has nothing to do with cost-shaving, it's just plain stupid.
Old Mar 15, 2009, 05:06 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
It's very poor engineering, that's for sure.
I wouldn't be surprised, though, if some people haven't made lots of money by selling such efforts.
Old Mar 15, 2009, 05:49 PM
Martin_G is offline
Find More Posts by Martin_G
Martin_G's Avatar
Joined Feb 2008
Hi,
I'm quite sure you can design an efficient motor with a lot of flux outside...
Just remember: eddie currents come from flux density variation. Saturated iron varies much less than not-saturated iron...
But for sure it should not be the prefered way.
servus,
Martin
Martin_G is offline Find More Posts by Martin_G
Old Mar 15, 2009, 06:58 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Forget the paper-clip test - Littlescreamers have no trouble holding 150g, but I managed to beat that the other day - I was able to suspend a 305g hammer from a Dynam/KDA A22-20L look-alike (we can't quite figure out its origin)!!!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Discussion Fed up breaking your motor mount/nose on your depron 3d ship? mr_wood 3D Flying 12 Jan 24, 2006 12:01 PM
Help! Metal motor mount snakeX2 Power Systems 5 Jul 22, 2005 06:36 AM
3 gram motor mount riser for your A/P pusher CactusJackSlade Aerial Photography 2 Jun 18, 2005 11:19 PM
Help! metal motor mount? jameschen072 GWS (Grand Wing Servo) 3 Oct 17, 2004 02:09 PM
Hoppy, can you post the link to your coroplast motor mount? Mike C Foamies (Kits) 14 Jul 16, 2001 02:07 PM
