Old Dec 04, 2008, 02:11 PM
peskeybobcat is offline
Find More Posts by peskeybobcat
peskeybobcat's Avatar
United States, CA, Ridgecrest
Joined Aug 2007
I no I was just being a dick...Sorry..... It has terned very cold here now and I don't know when I will get to it because I have to work out side on the bench but maybe next warm day.. Right now I think I will head over to the (Cock and Plucker) for a game of Tank Battles with Conker the squirrel..
God I just Love this game...
peskeybobcat is offline Find More Posts by peskeybobcat
Old Dec 04, 2008, 03:58 PM
Blitzkrieg65 is offline
Find More Posts by Blitzkrieg65
Blitzkrieg65's Avatar
Escondido, California
Joined Apr 2007
No appoligies necessary, its all about the fun and you have a lot more to worry about with having to face that advisary, that is one tough looking squirrel!
Blitzkrieg65 is offline Find More Posts by Blitzkrieg65
Old Dec 04, 2008, 04:52 PM
Joined Aug 2007
Laser
Well after getting my butt kicked over at the cock&plucker by the big mighty Poo I thought I better grab a roll of sharman and get out when the getting was good. Anyway as you can see I did get to the Laser and as always I over did it took it completely apart and even lost some parts under the bench this is why I got 4 of them so I could see what makes it tick..I don't believe this laser is going to give me what I am looking for.
Old Dec 05, 2008, 06:53 PM
Joined Aug 2007
SD Chip sound card
Jagpanther with With EL MOD Sounds (1 min 57 sec)
OH YEAH!!! Blitz I will be going there.. That was Boss man... Bet you haven't heard that one in awhile?? Just love them sounds of reloading the main gun and the German Marching song a must for any panzer division. That gun sounded cool but I kind of have my own idea of that sound. Anyway I had been looking at that sound unit with the SD card All of my home security works on a SD Chip and I have a lot of experience with the SD cards
I can just here it now...... Entering the battlefield with a Patton echo... and him saying ( You got to hold them by the nose and kick them in the a s s Kick them so hared there gust start to bleed.) Then some more Patton echo....
I don't know what you have for the sound of the gun for your Tank but I have had the pleasure of standing next to a real Tank when it was being fired
it was a defining experience.. If you have ever seen Clint Eastwood's Movie The Good The Bad And The Ugly and herd one of the pistol shots in that movie it would be close..
I was wondering how the tank battle thing is conducted.. My concern would be that Its not a free for all out there is it?? I would not want to brake down in the field and have some one push my tank into a puddle of water or something like that.. And ruin the electronics..So is there rules of engagement??ThinkTank Blaster 2
detailed instructions for assembly and operation
Please read these instructions carefully before assembling the parts.
Scope of delivery
• ThinkTank Blaster PCB
• ThinkTank Blaster CPU PCB
• EMNet ribbon cable with four connectors (A)
• volume control cable (B)
• speaker cable (C)
• cable for optional connection with proportional receiver (D)
• SD-card
To operate the module you need a ThinkTank Booster
(firmware 1.20 or later) and a ThinkTank TLS (firmware 1.17
or later).
Functionalities
• sound module for tank models equipped with ElMod electronic parts.
• up to five independent voices.
• 22kHz Sampling-frequency, 8-bit, wav-files.
• 10-bit mixer for wide dynamic range.
• storage medium is standard SD-card.
• customizable: creating your own sets of samples is possible with a personal computer.
• supported sounds (depending on the model):
• up to ten sounds for switching on/off of the motor (shuffle play).
• determination between cold and warm start
• motor sound depending on speed
• different sounds for squieking chains which are played randomly depending on speed
• sounds for turning turret with differentiation between manual and hydraulic/electrical
turning
• sound for barrel moving
• Gun and MG shot
• up to four sounds defined by the user (when using a a six-channel proportional set)
• Connection with up to two 4 or 8 Ohm speakers
• Power: 2x 5W
• Size: 48 x 47 mm² (2” x 2“)
• E lMod-Bus system (EMNet): Simple connection with other ThinkTank-Modules
Overview of connectors
1 EMNet-connector
2 connector for volume control
3 two connectors for up to two speakers
4 connector for proportional receiver (channel 5+6)
J jumpers used for configuration of blaster
SD slot for sd-cards
L1 Power LED
L2 Busy LED
Assembly and connection
Faulty wiring may cause permanent damage to the electronics! If anything is unclear, please look
at our FAQ or write an email to us!
• Connect connector 1, all other ThinkTank modules and the BEC-supply, when existent, with
the EMNet cable A
• Connect volume control B with connector 2
• Connect the speaker with cable C to one of the two connectors 3. If you ordered the blaster
with a speaker, it will already be delivered with the cable. You can use up to two speakers with
the Blaster 2 resulting in higher loudness. In this case consider the polarity of the
loudspeakers! If the sound appears 'thinner', swap the cables of one of them.
• Leave all jumpers closed to activate the standard set of samples for the tiger tank or choose
another one by setting the jumpers accordingly to your choice. A list with all available sample
sets is included.
• When you install the circuit board in the tank, make sure that no short circuits can occur (a
second mounting hole is placed below the CPU PCB).
Initiation
It is essential for proper function of the module that the tank itself and all other modules are
installed correctly!
• Make sure all cables have been installed as described above.
• Make sure that all jumpers are put in the right position and that the SD card is well fixed.
• Put in a full charged battery and switch on the tank.
• The power LED starts blinking for a short time as soon as the connection with the other
modules is established.
Old Dec 05, 2008, 09:36 PM
Joined Apr 2007
I see you've been doing your research!
Old Dec 06, 2008, 11:07 AM
Joined Aug 2007
You no funny thing is ??Them Germans did play music like that in Battle..
Toz dayz wez fights forz theez fathzer Land!!!!! No??
Old Dec 06, 2008, 06:54 PM
Joined Aug 2007
HummmmDead day on the forum..
Old Dec 08, 2008, 10:23 AM
Joined Aug 2007
History Lesson
Time for a History lesson
Did you know that the Drug called METH was used buy the German army in WWII? It had a nickname it was called Hitler's marching dust..
((((( Nope I am not a druggie..))))))
Old Dec 11, 2008, 10:22 AM
Joined Aug 2007
Full up scale Battle Tank
I am Popeye the sailing man...I am Popeye the sailing man..... Me stinks like the dickens because me sleeps with the chickens..I am Popeye the sailing man..... Toot Toot..... Sure do like my Heng Long OOOORAAA jOE!!! As you can see I took my new R/C Tank to the park for a test run but the park authorities had a small problem with the scale.. They would not let me play on the lawn..
Old Dec 12, 2008, 08:46 AM
Joined Aug 2007
I never did say anything about that I have a step son in Iraq he is a Tank crew men for the M1A1 ABRAMS main battle TANK he is posted at FORT BENNING Ga. He is attached to the 3rd Brigade 3rd Infantry Fox 203 Infantry His rank is specialist He is a ABRAMS TANK mechanic with the 15 Regiment and has dun two tourers in Iraq and is looking at a third.. I will say they are paying him well over there.. I will post some more photos of him in full Battle dress when he sends me some and I might even get some of his Tank? I dont no...??
Old Dec 12, 2008, 10:26 AM
Joined Apr 2007
I never did say anything about that I have a step son in Iraq he is a Tank crew men for the M1A1 ABRAMS main battle TANK he has dun two tourers in Iraq and is looking at a third.. I will say they are paying them well over there..
Very Cool Pesky,
I have a nephew in the Rangers and a niece in the Airforce and my daughter is going into the Airforce!
The Blitz
Old Dec 12, 2008, 03:00 PM
Joined Aug 2007
That's cool Blitz we don't have to fight anymore let them youngsters do all the heavy work now... I payed my dues and it left me in a wheel chair off and on.... I just play now and hobby... Hey Blitz I think that dud with the problem cable needs some help Best I can tell I believe that a wire has broke off his Bord and he duns not know where it go's back on . Can you help with a photo of that Bord showing were the wire go's thanks.
Old Dec 14, 2008, 03:40 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Laser target designator.
I have had my JGSD Type 90 tank (HL) for about 3 years or so and Have had a lot of fun with it. It originally had the radio system that you could program a sequence of commands and then the tank would execute the program. I removed that radio because even though it was very cool it had short radio range. I installed that radio in a Abrams made by motor works (wall mart) and used a modified version of the Abrams tank radio in my type 90. I included a relay control for a laser. With that system I can hit a target every time now and it would be good for a tank battle. I'm posting a video here but its very poor quality and not done well but gives a decent demo of the Laser range designator...
Type 90 Tank with "Laser" target designator.. (0 min 32 sec)
Not apparant in the video but the Laser sight can be turned on\off via remote control.
modfly is offline Find More Posts by modfly
Old Dec 15, 2008, 12:25 AM
Joined Apr 2007
Originally Posted by modfly
I have had my JGSD Type 90 tank (HL) for about 3 years or so and Have had a lot of fun with it. It originally had the radio system that you could program a sequence of commands and then the tank would execute the program. I removed that radio because even though it was very cool it had short radio range. I installed that radio in a Abrams made by motor works (wall mart) and used a modified version of the Abrams tank radio in my type 90. I included a relay control for a laser. With that system I can hit a target every time now and it would be good for a tank battle. I'm posting a video here but its very poor quality and not done well but gives a decent demo of the Laser range designator... http://www.youtube.com/watch?v=EDV2V2r6R7U
Very cool modfly that will come in handy for new era battles! If you have pictures of your modifications please post I am sure that there are others that would be interested in it!
The Blitz
Old Dec 15, 2008, 12:45 AM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
the mods were quite intense as I actually changed out the circuit board and added one from a totally different Tank. I also modded the main gun so that it is bi-directional up\down or full duplex and slowed the turret movement speed down. The stock controller was too hard to modify with those push button controls. I will post more pics of this and its controller and what not..Was not going to bother if there was no interest.
I actually got this Tank Forum going last year. Some other guys started it but I got it going and I'm pleased to see all the interest in tanks here. I have been into them for 30+ years
I have tank models and experimental r/c tanks that are 30+ years old. Nice to see others finally taking an interest in them.
I also am into r\c planes but that is a recent interest compared to the Tanks but I got to tell ya..Its become a big part of my Hobby interest at this point but being this is winter in OHIO, I will have some time to spend here with some of my tank creations.
I spent about 5 minutes on that laser video..I have a better video camera now with sound and looks like this video is due for an update
Question heng long upgrade better or not? offshore1987 RC Tanks 1 Dec 30, 2007 11:12 PM
My Slope's Bigger Than Your Slope. (Video) Lavawing Slope 40 Sep 14, 2005 10:17 PM
Help! IR Prizm - Better than my servo?? bbarrus Aerial Photography 8 Nov 10, 2004 05:21 PM
Long Stick II - Better than the first? flyingtomg Sport Planes 0 Jun 10, 2004 01:17 PM
Why my plane flies better than yours... LuckyArmpit Parkflyers 12 May 13, 2003 12:37 AM
