Go Back   RC Groups > Aircraft - General > DIY Electronics
Old Nov 14, 2008, 12:29 AM   #1
USMC
ov10mech's Avatar
Send a message via MSN to ov10mech
Made my own 12V Supply and it sucks
I bought a brand new 450W computer power supply thinking I would save some money. Its not the best brand (echostar) but its rated for 450W Max /14A at 12V.
http://tekgems.com/Products/et-11182...star-450-n.htm
I wired it up and hooked up my Electrify Polycharge 4. Basically I crossed a green and black to get it to stay on all the time then took a yellow and black lead for my positive and negative.
If I put a load on the thing any more than 2A, the low voltage alarm goes off and the PS voltage drops in the 10V range. Is this just a crap supply or do you think I did something wrong?
ov10mech is offline Find More Posts by ov10mech   Reply With Quote
Old Nov 14, 2008, 12:39 AM   #2
RCalldayLong
yangster's Avatar
Must be a crappy power supply. I did the same to an old 300 watt power supply I have and it works super. I'm able to power up and easily charge up to 5amps (max of my charger) just fine. I have 2 extra power supplies (I use to be a computer geek). PM me and I'll see if I can send you one.
yangster is offline Find More Posts by yangster   Reply With Quote
Old Nov 14, 2008, 12:39 AM   #3
CamLight Systems
Typically, you need to add a load to the 5V line to get the 12V line to regulate. Without that load, the 12V line can drop in voltage when it's used. Do a search in this forum and you'll find lots of examples of power supplies being modified for use with a charger. Some great tips there!
John
JohnMuchow is offline Find More Posts by JohnMuchow   Reply With Quote
Old Nov 14, 2008, 12:42 AM   #4
"Simplify, then add lightness"
On PC supplies, you generally need to put a load on the +5v wires to get good regulation on the other voltages. Not sure how much load you will need, but you can use power resistors or light bulbs.
PS seems like John is faster on the keyboard than I am.
jeffs555 is offline Find More Posts by jeffs555   Reply With Quote
Old Nov 14, 2008, 12:54 AM   #5
CamLight Systems
Nah, I probably just got the msg a bit earlier.
Old Nov 14, 2008, 12:57 AM   #6
CamLight Systems
You didn't add a load to the +5V line? Almost every computer power supply I've seen requires that for good regulation on the +12V line, no matter how how high quality the unit is. Perhaps older units don't require it?
IMHO, ov10mech's power supply is plenty good enough to get the job done and just needs that load.
John
Old Nov 14, 2008, 01:03 AM   #7
Say when.....
quigley257's Avatar
Location: Two Harbors, Minnesota. On the shores of Gitche Gumee
Try checking your wiring setup against the suggested wiring and resistor setup shown here... http://web2.murraystate.edu/andy.bat...OWERSUPPLY.HTM
--quigley
quigley257 is online now Find More Posts by quigley257   Reply With Quote
Old Nov 14, 2008, 01:06 AM   #8
USMC
ov10mech's Avatar
Thanks!
Thanks guys. Found an auto brake light bulb here in the basement and wired that into a the 5v wires (red/black). I have 3 lipos charging right now @ 2a each. It chokes on the 4th lipo port but 3 should be ok. Voltage is maintaining around 11.41 with a 6A load.
I can see the power trying supply kicking back up the voltage now on the volt meter when a new pack is added. This bulb is kind of big and runs hot and will have to find something else to put a load on it. What do I tell the rat shack guy I need as far as a resister?
Old Nov 14, 2008, 01:08 AM   #9
USMC
ov10mech's Avatar
Never mind.. the link sent explains the resistor
Old Nov 14, 2008, 01:09 AM   #10
Poli's Avatar
Hallo. Sorry for bad english buth you need (10 Ohm\ 10W) resistor or automotiv bulb. Buth I think then this is just crapy supply.. And main problem is low 12 Volts when in load about 11,45 - 11,75V.
http://www.flyinggiants.com/forums/f...er-supply.html
http://web2.murraystate.edu/andy.bat...Y.HTM#POWER_OK
http://www.wikihow.com/Convert-a-Com...b-Power-Supply
Good luck. Bye
Poli is offline Find More Posts by Poli   Reply With Quote
Old Nov 14, 2008, 01:11 AM   #11
Poli's Avatar
Ohh im too slow.
Old Nov 14, 2008, 01:17 AM   #12
CamLight Systems
ov10mech,
If your supply still drops down to that 11.4V under a 6A load, be sure to try a second resistor (or bulb) to see if that "stiffens up" the 12V line a bit more. Sometimes you have to increase the load on the 5V line to get the 12V line to maintain its voltage well enough. That 0.6V drop is a bit large IMHO and can be reduced....hopefully.
John
Old Nov 14, 2008, 01:20 AM   #13
USMC
ov10mech's Avatar
I'll hit the shack tommorow and pick up a couple of those sandbars and report back! Then maybe I can change the thread title to "Made my own power supply and it works!"
Originally Posted by JohnMuchow
ov10mech,
John
Old Nov 14, 2008, 02:37 PM   #14
Send a message via AIM to HoaRC
http://www.youtube.com/watch?v=2Uxp6Vn2KdA
HoaRC is offline Find More Posts by HoaRC   Reply With Quote
Old Nov 14, 2008, 04:10 PM   #15
USMC
ov10mech's Avatar
Update
I wired in two 10-Ohm / 10watt resistors today.
I pretty much have the same voltage drop after a couple of amps of load. I appreciate all the suggestions. The supply will be useful, just not for high draw applications.
I made my own EDF fan ssyed Electric Ducted Fan Jet Talk 8 Jun 22, 2006 01:04 AM
Made my own stand lorenzo_MiniGP Motorcycles 10 Mar 19, 2005 01:11 PM
Made my own 3ch aileron/elevator plane! It works!!!!!!! pics lift off Foamies (Kits) 5 Jun 18, 2004 08:39 PM
made my own blades! Yukonho Micro Helis 17 Oct 23, 2003 10:56 PM
Made my own brushless outrunner for a micro heli... Eco8gator Electric Heli Talk 16 Nov 21, 2002 10:17 AM
Congratulations SimpleM!
