Jul 27, 2001, 10:36 AM
United States, CA, Garden Grove
Joined Oct 2000
From an old soldering instructor:
Soldering is an art and requires proper tools, materials and practice. It is also helpful to have 3 or more hands, ( have somebody help if possible)Strongly recommend practice on an old connector, etc., before attempting it on the real thing.
Use small diameter 60/40 rosin core solder and electronic soldering paste on wire and connector to promote good solder flow. Use a small soldering iron 37-47 watt, apply solder to the tip and keep wiping it on a damp sponge or damp paper towel to keep it shiny. Strip a little insulation from wire without cutting strands. Apply paste and "tin" wire by heating and flowing solder into it. Tin the connector terminal too. Slide close fitting heat shrink tubing onto wire, push it back so it doesn't get heated during soldering. Hold wire in position, soldering iron tip should touch terminal and wire ,have somebody feed small amount of solder into the junction of the iron tip next and terminal and let it flow smoothly between terminal and wire, then remove the iron tip from joint and keep wire steady while solder solidifes. Inspect carefully for smooth complete solder flow between terminal and wire. Poor solder flow can crash your plane and maybe casue injury, so be sure you get this right!!!!!If not, add a little paste and reheat, reflow the solder.
Slide heat shrink tubing over the joint and heat with a heat gun to shrink it over the connection. You can help shrink tubing with clean iron tip too.
