Go Back   RC Groups > Vendors > Hobby Lobby
Old Apr 14, 2009, 06:08 PM   #46
Yea, The fairing instillation looks really good. When you paint the heads to match the covering, it will be the cats meow. I want one of these 108's real bad, but HL is going to have to put them on sale before I can afford one.
Scott Morgan is offline Find More Posts by Scott Morgan   Reply With Quote
Old May 04, 2009, 10:24 PM   #47
Test Flight
Well the weather and my health finally got together and I got the first two test flights in today. All in all, it flies as good as it looks. I'm going to love this plane.
Fred
fsheplavy is offline Find More Posts by fsheplavy   Reply With Quote
Old May 05, 2009, 06:11 PM   #48
Lift - reasons for ...
Fred
Way to go Fred. Glad to hear it.
Tim Green is offline Find More Posts by Tim Green   Reply With Quote
Old Nov 03, 2009, 06:39 PM   #49
I know this thread is old but I was hoping someone would tell me what the field set up process is? Any flight reports?
Borabora22 is offline Find More Posts by Borabora22   Reply With Quote
Old Nov 04, 2009, 12:21 AM   #50
1. Install the wings
2. Slid the wing strut stud through the landing gear
3. Snug the retaining nut onto the strut stud
4. Install and tighten the strut to wing screws
5. Tighten the strut stud nut
Go flying
The plane is quite honest in its flight characteristics. The only caution is with landing. The plane is a bit slow to react to elevator when you want to flare out. Also the plane is a bit bouncy on landing.
Good luck.
Fred
Old Nov 06, 2009, 10:15 AM   #51
fsheplavy
I'm really glad that you are enjoying the big Stinson, it is one of my favorite flyers.
I like all of the work that you did on your Stinson, very nice job.
In your last post you mentioned slow elevator response at landing speed and the tendency to bounce on landing. Both of these traits are indicative of a slightly nose heavy condition. When nose heavy the elevator response at low speed will degrade and the result will be a too hard gear hit. You might try moving the CG slightly aft in small incriments and see if you improve your results.
I have been flying the plane for about 2 years now and I have certainly bounced my share of landings, but as you can see in the HL video the plane can be easily flared to a smooth landing.
Again, really love what you did with yours and hope that you continue to enjoy the model.
All the best,
Mike Hines
Hiflyer is offline Find More Posts by Hiflyer   Reply With Quote
Old Nov 16, 2009, 11:25 PM   #52
Originally Posted by Hiflyer View Post
fsheplavy
Hines
If you get a chance, I'd appreciate if you could check your CG and let me know the location
Fred
Old Nov 20, 2009, 09:29 PM   #53
fsheplavy,
I just purchased one of these and am having one devil of a time getting the engine box out. How did you manage it? I thought about leaving it in and adding another box and or stand off but that seems to be kinda of defeating the purpose. I am wondering if it is that hard to get out will I ever get it in again before the glue sets Thanks
Old Nov 21, 2009, 10:45 AM   #54
fsheplavy,
I used a palette knife to slide in between the box and the fuse structure. Just slip it in and work it around and eventually the box should loosen. After that a little sanding will loosen the fit and allow easy assembly.
Fred
Old Nov 21, 2009, 11:26 AM   #55
Thanks, I appreciate your help! That is a good idea! I will look around for something ultra thin and give it a try. I have been trying to tap it out with a board and a hammer on the backside of the firewall. I was almost convinced this thing was glued in. But if yours came out mine should also.
Unread Yesterday, 08:13 PM   #56
Ok maybe I am slow but how exactly do the flaps work? There are a total of 5 control horns in the kit. There are no slots cut for a control horn in the actual flap like the other surfaces. It appears that the push rod goes on the inside of the wing thru a cross piece. There is a hole drilled into the trailing edge and the flap that line up similiar to one you would drill if you were installing a robart hinge point. Am I missing something here?
I have not started to build yet. Still trying to figure out which control horns go where.
I am logging a few key points on RCU regarding this aircraft so others do not have similar problems. I finally got the engine box out. Turns out there was a drop of glue holding it.
Thanks for any help
Unread Yesterday, 11:01 PM   #57
Thanks for any help
I'll try to get a photo posted tomorrow that will show the set up. You are on the right track. Read my wing assembly tips on pages 1 & 2. It will save you some time.
Fred
Unread Yesterday, 11:53 PM   #58
Originally Posted by fsheplavy View Post
Shim up the leading edge till the surface at the trailing edge is flat on the table. Install the push rod attachment pin into the flap.
Fred
I must be getting old. I read this thread before I purchased it and do not remember the statement above or the knife suggestion. Sorry. A picture would be great. Not sure I get how this is going to work and have sufficent integrity.
I finally got the darn box out!. I had to put plane on the nose supported by blocks and dropped a 3 LB weight several times to finally break the motor box loose. The last drop it just popped out. Thanks for your help
Unread Today, 08:22 AM   #59
What motor or eng are you going to power it with?
skypan12 is offline Find More Posts by skypan12   Reply With Quote
Unread Today, 10:01 AM   #60
I am going electric with a Hacker A60-18L with 14s2p A123 batteries.
Article Great Planes Giant Scale Super Sportster ARF RichN Giant Scale Airplanes 12 Aug 21, 2007 10:50 AM
Discussion What servos for giant-scale Stinson? dk944s2 Radios 1 Dec 26, 2006 01:56 PM
Discussion Which Servos for Giant scale Stinson SR9 Ground Hugger The Builders Workshop 0 Oct 01, 2006 07:39 AM
Article Great Planes Performance Series Giant Scale Cap 3D ARF Review w/ OS 160 Steve H. RCPowermag Archive 6 Jun 28, 2006 03:56 PM
Converting a Top-Flite Giant Scale P-51 ARF [Propwash] Sport Planes 3 Jul 03, 2004 04:44 PM
Bored? Want to fight?
Join the RCGroups clan!
