I have to say...... That looks really nice!!!!
Ron |
Latest blog entry: Weak Signals Toledo 2012
I'm so excited about your plane. My wife said that the LG looks like a bow as well, and it does. How did you mount it to the stick?
I like the lite ply or balsa bow on the wing LE. Did you glue it in place? Looks better than the tape holding the CF that's on mine. The more I look at your plane the more I see. You have really made a lot of improvements. Dalton |
I do like seeing those plans put to such good use! Ron |
Thank you guys! I've simply taken a very good design and "tweaked" it a little bit to satisfy the artist in me.
The trike gear kinda gives it a fighter plane look, don't you think? It cries out for a red and white carrier arresting hook, but perhaps that's just my imagination running wild. That happens a lot. I'm attaching some close-up photo's of the steerable nose wheel arrangement. To make it, I drilled a vertical hole through the stick and CA'd in a piece of brass tubing. A short piece of wire rod runs down through that, and wheel collars top and bottom keep it in place. A servo arm was press fit (very tight) onto the wire for rotational control. It is not glued, so that it acts as a servo-saver in the event that the nose wheel strikes something on the ground. The lower end of the steel rod is CA'd into a piece of carbon tube. At the lower end of the carbon tube I've glued in another piece of steel rod which was bent to shape. The whole strut could be done with one piece of steel rod, but I wanted to save some weight with the carbon. I'm considering a shock absorber spring inside the tube, but that'll be for later, after she flys. The upper steel rod has a slight forward angle bent into it. It causes the nose wheel to tilt a little when turned, improving the ground handling. Those Dubro wheels/tires are way too heavy for electric use, but I'm still waiting for my new wheels and servos to arrive from Hong Kong. I can't claim much credit for the artwork. I made it up using Printshop 21. It was inkjet printed onto a piece of tissue paper (taped to a carrier sheet) and placed on the wing. I then covered the entire wing with a piece of .75 oz FG and spread West Systems epoxy into it. The resin causes the glass cloth and the tissue paper to disappear, leaving only the printed image. I spread the resin with a piece of cardboard cut from a cereal box or one of those promotional credit cards that we often receive as junk mail. After filling the weave, I scrape off as much of the resin as I can to save weight. My Dollar Store foam wing was too wimpy anyway. Using contact cement, I glued a piece of carbon to the leading edge and glued the balsa over that. I believe that a radius on the LE tames the stall a wee bit on these flat plate wings. The main gear is through-bolted to the stick with the same #6 bolts that I bought for the axles. The axles are 12 degrees aft of the designed CG. The shape of the main gear was carefully made to follow the bow design concept. Thom |
He is a good builder. Can't wait to see it finished and flying. It's a real high to see one of your designs built by someone else. |
I took my BowStick out today and flew it for quite awhile. Made many landings. I love to fly that plane! Thanks for all the info. I will have to get some .75 oz Fiber Glass. Any recommendations on where to buy? |
I'm happy to hear that you were able to fly today. I'm eager to do so myself. Of course, that'll have to wait until I can actually see the ground. It's covered with several feet of "that white stuff" at the moment.
I found my .75 glass cloth in a 100 yd roll for something like 10 bucks on ebay. Z-poxy finishing resin will work for this application. I usually do my finish glass work with Minwax Polycrylic because; a. It's water based, B. I'm not allergic to it, and C; Because it's much lighter than epoxy resin. However, it doesn't make the tissue paper disappear quite like the epoxy resin does. I gotta go figure out those arresting cables. I'm thinking of outlining a carrier deck on the pavement and mock up a carrier "island" with an loose stack of 2" thick blue foam blocks. Thom |
Are you building and how is your progress? Would love to know how you're doing. Keep in touch! Dalton
Ron PS......FYI One of our RCG'ers has suffered a huge loss. http://www.rcgroups.com/forums/showthread.php?t=1009597 |
| Thread Tools | |
| Build Log AX my new glider, easy to build, easy to fly. Photos &Videos | Cebola | Electric Sailplanes | 33 | Dec 03, 2009 06:46 AM |
| Discussion Simple, quick build...but will it fly? | LLoo | Foamies (Kits) | 9 | Jan 28, 2006 09:45 AM |
| QuickFlick - design, build and hopefully fly thread | PLD | Hand Launch | 61 | Feb 07, 2005 12:39 AM |
| Need an easy to fly plane (scratch build) | tim_j-rome | Parkflyers | 11 | May 16, 2002 08:46 PM |
| Question PB Fly Speed 400 Fun Fly ARF | skyz | Parkflyers | 0 | Mar 02, 2002 02:17 PM |
