Old Nov 12, 2008, 03:23 AM
motiganot is offline
Find More Posts by motiganot
motiganot's Avatar
Israel
Joined Jun 2008
Which RC system go more far away ???
Hello to you all.
2.4 system or 72 system.
some friends told me that the 2.4 system
not reliable beyond the 1 Km .
The 72 system can go beyond 2 Km with no problems.
It is true ???
motiganot is offline Find More Posts by motiganot
Old Nov 12, 2008, 03:36 AM
thomasscherrer is offline
Find More Posts by thomasscherrer
thomasscherrer's Avatar
Danmark, Hovedstaden, Ballerup
Joined May 2007
all conventional RC systems are designed for VISUAL range,
so that means how far can the users normally see their planes,
and then they have designed a bit of margin in there.
when you want to fly FPV you have the possibility to fly much futher away,
this uses all the safety margin they have designed into the RC range, and then you get into trouble.
normally I would expect a 72MHz system to perform longer than a 2.4Ghz stock system, but achived range depends on many factors, so the same person needs to make several installations and test flights to really tell what perform the best.
if your goal is long range FPV I suggest you think different, and dont use stock radios
like this system:
http://www.rcgroups.com/forums/showthread.php?t=905915
but again, why not start with your stock radio and perfect the video link
and perfect your FPV skils first, then later come back and look on my long range system, it can be connected to large antennas and big and strong poweramplifiers cheaply available to give you any range you can dream of, 10km 50km 100km what do you want, we have it.
thomasscherrer is offline Find More Posts by thomasscherrer
Old Nov 12, 2008, 04:25 AM
motiganot's Avatar
Israel
Joined Jun 2008
Hello thomasscherrer
This is a video of my latest flight :
http://www.vimeo.com/2127409
I do not think that my FPV skills present any problem …
Now I use futaba 9CHP 72 system and I thinking to
Convert it to the 2.4 model.
thanks for your response
Old Nov 12, 2008, 08:00 AM
Joined May 2007
I am sorry, that was not my intention to let you think like that,
I just think that normal (short) radio range can still be funny and a challenging,
but you are way pass that level :-) and now you seek more range to make it more funny, cool, I will be here, when you need me..
Old Nov 12, 2008, 10:46 AM
sokiii is offline
Find More Posts by sokiii
sokiii's Avatar
Chicago, IL
72 MHz radio is better than 2.4 GHz for long range FPV. With good antenna range is >8km.
8km FPV flight (7 min 38 sec)
sokiii is offline Find More Posts by sokiii
Old Nov 12, 2008, 04:36 PM
motiganot's Avatar
Israel
Joined Jun 2008
futaba 72
Sokii good one…
Thomasscherrer. noting to be sorry.
Can you suggest me how can I make
My system to reach 2 Km with no interference !
Old Nov 12, 2008, 06:49 PM
glassfox is offline
Find More Posts by glassfox
glassfox's Avatar
Tianjin, China
yeah, my 72mhz futaba FF9C +319dps rx also reached 2km, little noise on control ,but still ok.
glassfox is offline Find More Posts by glassfox
Site Sponsor
Old Nov 13, 2008, 04:17 AM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
good antenna? what are you using?
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Nov 13, 2008, 11:30 AM
sokiii is offline
sokiii's Avatar
Chicago, IL
59" vertical antenna on the plane
Old Nov 13, 2008, 01:19 PM
mpluis is offline
Find More Posts by mpluis
Portugal
Joined Mar 2007
Hi sokiii,
Is that double lenght or more? how lenght is important to the rx?
mpluis is offline Find More Posts by mpluis
Old Nov 13, 2008, 01:26 PM
sokiii is offline
sokiii's Avatar
Chicago, IL
Originally Posted by mpluis
Hi sokiii,
It's close to 3/8 wavelength. Read http://www.rc-cam.com/ant_exp.htm
Old Nov 13, 2008, 02:01 PM
igorp is offline
Find More Posts by igorp
FPV Crash Dummy
igorp's Avatar
United States, CT, Bloomfield
Joined Aug 2007
I doubled the length on my antenna also and noticed a huge increase in range. I use a Futaba r138dp pcm rx. I have my antenna pointing straight down though.
igorp is offline Find More Posts by igorp
Old Nov 13, 2008, 03:09 PM
mpluis is offline
Portugal
Joined Mar 2007
Ok, thanks for the link sokiii, I will double too and maybe do a mast with a
very fine carbon tube and two string stays.
Old Nov 13, 2008, 04:58 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
as initial lenght to start the experiments, canyou suggest somthing for the Futaba R-149DP in 35mhz?
Thanks!
edit:
antenna lenght calculator... interesting:
http://www.qsl.net/kd4sai/antencal.html
do I need any special cable to do an antenna or any electric cable is ok?
Old Nov 13, 2008, 05:20 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
--- added above ---
Discussion Seeking opinion on which geared system is more versatile noobee Power Systems 5 Jul 21, 2007 10:12 AM
Discussion Which power system to use? Lighter or more powerful? Hellbore Electric Sailplanes 4 Mar 28, 2007 07:34 PM
My DLG folds up into its own box so can go to far away competions treehog Hand Launch 3 Mar 03, 2005 05:36 PM
Futaba 6XAS Computer Controlled RC system frizz0 Aircraft - Electric - Airplanes (FS/W) 3 May 13, 2004 10:15 PM
Which URL to go for AF010 with Variable ESC? jas_Qfix Electric Plane Talk 6 May 14, 2001 08:45 AM
