Old Nov 12, 2008, 12:36 AM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Check out my little prop jet (14lb Falcon 120)
Here`s a pic of my Falcon 120 wing and links to the "build thread" and a video from last weekend.
Build Thread
Video Link
Knife Liddle is offline Find More Posts by Knife Liddle
Old Nov 12, 2008, 05:49 AM
Scarey is offline
Find More Posts by Scarey
Registered EDF abuser
Scarey's Avatar
Michigan
Joined Jan 2006
I see that you went with Elevons instead of the standard set-up. Did you set-up the flaps and rudder? If so, how well did they work with that set-up?
Scarey
Scarey is offline Find More Posts by Scarey
Old Nov 12, 2008, 08:25 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
The rudders are functional. As far as the elevons I`ve tried it both ways. First I had it set up so that I could use flaps down and ailerons up a little for landing, but before I could get it dialed in I had to land with standard elevons 3 times. It turned out that it slowed down fine without flaps, even at 14lbs, so now I have all four surfaces moving together just as standard elevons.
The guys that fly the Falcon 120 at near 20lbs AUW on turbines probably need the flaps, but at 14lbs they aren`t needed.
The plane flys just like a Stryker, just bigger and faster.
Old Nov 12, 2008, 11:46 AM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Im not impressed lee. You finally through a prop on and you're only at 2 KW!?!?
Do it again, but find a motor that'll take your 10" prop up to 4 kW or more and then get back to us!!! Now THAT would be awesome!
Thekid3418 is offline Find More Posts by Thekid3418
Old Nov 12, 2008, 12:51 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
LOL LOL....Brian, first I have to find a 10 inch prop that can handle 30k, then I can do 5kw
I wanted to fly it Sunday and any more power would have probably shed blades in a dive.
I`m working on it, you can count on that .
I`ve got that 1521-1.5y that`s good to 5kw.
Check Out My Newly Updated Website HELIMANG Electric Heli Talk 0 Aug 22, 2002 07:49 PM
Rave Check out my newly updated website for RTF micro helis HELIMANG Micro Helis 2 Aug 16, 2002 11:28 AM
Check out my Video!! drbird Foamies (Kits) 20 May 09, 2002 10:59 PM
Check out my new Crazy max! JStory Parkflyers 3 Jan 23, 2002 09:51 PM
Check out my new Website. Fall Special 20% Off all building services Joe Elston Electric Plane Talk 0 Sep 05, 2001 02:55 PM
