Go Back   RC Groups > Aircraft - Electric - Helis > Electric Heli Talk
Old Nov 11, 2008, 08:12 PM   #1
X-Era Motors
DavidB.'s Avatar
Send a message via AIM to DavidB.
X-Era preorder list
www.xeramotors.com
Hey guys. We're ready to start winding motors. Just tell me what motor you would like to purchase so I can get an idea of what is in demand. If you are on this list you will be assured a motor before anyone else. But if you decide not to buy, it's not a problem.
I can do 4turns in the other sizes, just haven't determined if there is a market for such low Kv motors. The 4035/4y is very efficient on 12s at 1500w which is good for those guys flying camera ships. However it will bog a lot at high powers, so it would not make a good 3D motor. Other than that, just go by the numbers you see below.
Motor--------Kv------Rm---Io(10v)-Io(30v)-Weight---Price
4020/2y----1000----0.008----1.9----NA-----346----$170.00
4025/2y-----830----0.011----1.5----3.3-----385----$180.00
4025/2.5y---667----0.017----1.1----2.2
4025/3y-----560----0.019----0.9----1.6
4030/2y-----706----0.012----1.4----2.7-----440----$190.00
4030/2.5y---564----0.018----1.1----2.0
4030/3y-----468----0.023----0.8----1.4
4035/2y-----602----0.013----1.3----2.3-----485----$200.00
4035/2.5y---480----0.020----1.0----1.7
4035/3y-----401----0.023----0.8----1.2
4035/4y-----300----0.043----0.5----0.8
4035/5y-----240----0.070----0.3----0.5
Edit: removed irrelevant information and added more data, added my website URL
  • Name: DSC00493.jpg
DavidB. is offline Find More Posts by DavidB.   Reply With Quote
Old Nov 11, 2008, 08:39 PM   #2
Pain? I know pain!
What would you recommend for a Rapter e620 blown up to a e710 running 710mm V-blades at 1900 rpm? It has 111 main gear and and I have pinions from 9 to 14 teeth. I'm running 10s2p a123s and has a weight of right under 10lbs. The Orbit 30-12 I'm running right now is bogging on stationary flips, read loosing head speed but I still get about 7 mins sport flight time at 1900 rpms. It's time to upgrade. I had kinda decided on a Scorpion 4035-630 but would entertain the thought of a newer motor fresh on the market.
Tom
litespeed is offline Find More Posts by litespeed   Reply With Quote
Old Nov 11, 2008, 08:59 PM   #3
X-Era Motors
DavidB.'s Avatar
I would use the 4030/2y with the 10t assuming 30V under load. The A123's have huge voltage drops, so I wouldn't really blame your motor just yet. Last thing I want is for you to install my motor, and not notice a difference. You're also gonna pull huge amps with this motor at such low voltage, so make sure you have a hefty ESC.
Old Nov 11, 2008, 10:05 PM   #4
Pain? I know pain!
Yea voltage does drop but then it stays pretty constant. I would guess it drops to around 28 volt but then stays there pretty much or so till the end of the flight.
I run a CC85HV.
Tom
Old Nov 11, 2008, 10:09 PM   #5
rdespins's Avatar
10S A123 is not enough to run on a 600 let alone a 700mm machine. I would go no less than 14S or preferably 16-17S with a Power Jazz ESC. I run my logo 600 with a scorpion 4035-630 with 14S a123 and it is very powerful. I am thinking about going 14S2P or 16S2P and running 690 blades, It should do quite well and still weigh in the low 10 Lbs.
rdespins is offline Find More Posts by rdespins   Reply With Quote
Old Nov 12, 2008, 03:02 AM   #6
TeamTP,Minicopter,Spartan
Silver Member
misskimo's Avatar
Location: Mississippi 31 years , Now Kotzebue , Alaska 12
hey, Well Great!
Should be a fun next year forsure. Great Work David, Jin and your workers
misskimo is offline Find More Posts by misskimo   Reply With Quote
Old Nov 12, 2008, 10:17 AM   #7
scratchbuilder
Hi all,
I've been running a 4030 3Y prototype now for a couple of weeks. It's running in a 700 size heli, on 12s, geared 10.9:1. I have about an hour running time. It runs like a watch, with delta T on the windings is around 40F, and power is at least as good as an Actro 32-3. No problems of any kind, I like it a lot.
Ben
MRBEN is offline Find More Posts by MRBEN   Reply With Quote
Old Nov 12, 2008, 05:15 PM   #8
Convert!
rroback's Avatar
Send a message via AIM to rroback
What do you think for a 12s (a123) ship spinning 800's? The actro 32-4 gets fairly warm (while on 12s lipo, it's cool).
Rhett
rroback is offline Find More Posts by rroback   Reply With Quote
Old Nov 12, 2008, 05:21 PM   #9
X-Era Motors
DavidB.'s Avatar
Rhett I think the 4035/3y would be perfect. Should be a direct replacement with less than half the Rm. You can even go with the 4y but I'm not sure you can gear for that. The motor would be clocking over around 10,000rpm. Would be really quiet.
Old Nov 12, 2008, 05:24 PM   #10
Convert!
rroback's Avatar
Do you have 8mm shafts?
Old Nov 12, 2008, 05:39 PM   #11
---------Speed!!---------
Oh, Man, I could go about a dozen different directions with that quote.
David, the motor pic looks great. I am looking forward to mine!
Matt
Heli Mod Man is offline Find More Posts by Heli Mod Man   Reply With Quote
Old Nov 12, 2008, 05:57 PM   #12
X-Era Motors
DavidB.'s Avatar
Yeah, I'm getting some 8mm shafts so that's no problem.
It'll be in the mail same day I receive it
Old Nov 12, 2008, 07:41 PM   #13
You are too kind.
Matt
Old Nov 12, 2008, 11:13 PM   #14
Pain? I know pain!
Just for the record......and the reason I went this route is.......
http://www.youtube.com/watch?v=tO-UTFaePGs
You now stand corrected sir! Drop and give me twenty!
Tom
Old Nov 12, 2008, 11:18 PM   #15
rdespins's Avatar
Very good pilot! It flies quite well for 10S2P. However that thing doesn't have half the climb-out /power that my 600 has.
Congratulations SimpleM!
