Power system for big 3D plane
I would like to get everyone's input on a power system for my giant 3D plane pictured below.
Plane specs.. Wing span 87" Wing area approx. 1600 Length 76" from firewall to tip of rudder. Weight as pictured with all radio gear, receiver battery, control linkages etc.. 2004 grams or 70.69 oz. or 4.418 lbs I would like to use 20-24 cells and swing an APC prop in the range of 20X8 to 24X12. That's a Hangar 9 Pizazz in the picture for reference, although it really doesn't represent the size that well. More pictures and info in the Large 3D Plane thread in sport planes. http://www.rcgroups.com/forums/showt...threadid=94391 Thanks, Bill |
Thanks Wim !
I'm aware of that sight and have seen this example of the Funtana. I would like to use 30 cells like the Funtanas that are flying in the US. The Actro 40-5 should work but I'm trying to figure out which Torcman would also work. I suspect the 430-30-?. They say that 10 poles is required for over 24 cells as well. I would like to know how they compare to the Actro outrunners. |
Oak Harbor, Washington, United States
Joined Jan 2001
I'm running my Actro 40-5 on 32 cells at 60 amps fresh off the charger. APC-E 18x10 prop, Actronic 70-32 ESC. Never a hiccup.
Another option if you want to run 30 cells is the Maxcim "Y" wind. Tom's web site probably still says 28 cells, but he now has a controller that supports 30 cells on the "Y" wind. This would be around a 1500 watt system, and it's available now, not some vague distant date. If this interests you, I'd call him or email him with your requirements. www.maxcim.com Norm |
I've been looking at Motocalc and come up with this.
Hacker B50 11XL, 6.7:1 drive, 22X10 APC, 20 sanyo 2400's This setup shows a WOT thrust of 215 oz, 40mph PS, at 45 amps, 930 watts. This looks good, but I wonder how close this will be to what the actual motor does. Also, on everything I ran it said that the Battery temp was too high. Bill |
the temperature thing in motocalc bugs me lot too. If it were correct, i'd be burning up a battery pack every flight on most everything I fly
You can of course turn the temperature numbers off.APC now has 22X12 and 24X12, so you might want to go a bit larger on the prop and up a wind or two in motor. Or, just up to the 22X12. Current is usually a touch higher than motocalc predicts, but for 3D flying with lots of throttle usage, 50 amps isn't too much on those motors. Even a bit higher is Ok. Remember, you'll be using throttle a lot, so static current has almost no bearing on flight time. I've even found that some higher static-current setups have given more flight time than lower current setups because they're more efficient in the air, so for a given level of performance, the throttle is much further back, and on average you draw lower current during flight. Motocalc is an invaluable tool, but it isn't the final word, it just serves to get you in the right ballpark. Once you're flying a given setup, and know the performance level, motocalc is great for comparing different paramaters though, like changing props and cellcounts and comparing the performance to what you actually see with a single setup to see if it looks like it will be better or worse, without expending the calories and time to try everything available. |
Thanks for the tips, Gary
One thing that suprised me was the difference between RC 2400 cells and the CP 2400 cells on the same power system. I expected some difference, but not as much as it showed. I think I'm going to work around the 22 X 10 APC prop. I wonder if APC is going to make any other pitch sizes in this same dia. I've got some concerns about the gyro forces of the 22-24" props, and also the performance of the 10-12" pitch sizes. It seems that pitch sizes lower than 10" have worked the best on other 3D planes. If I remember correctly the 20X8 worked best on the Funtana, and the 14X7 worked well on the E3D. Please correct me if I'm wrong on this. Bill |
Bill, it's not the actual pitch that's the problem, it's the pitch to diameter ratio. You want to be somewhere between 2 to 1 and 1.5 to 1,..i.e. 12X6 to 12X8, 20X10 to 20X12.6,.. etc etc. the 20X8 on the funtana is actually a bit low in pitch speed, but the right wind motor coupled with the right gear ratio just wasn't found for the 20X10/11/13 props. The current setup on aero-models' funtana (and will be on mine if UPS ever gets it here) is 6.7 ratio on the 14XL with the 22X12 (yes, they have 12 pitch on the 22 inch prop now). Keep in mind we're using 30 cells, though, so you'd need a bit "hotter" motor for lower cellcount. Back to the p/d ratio thing. Unless you're actually flying right at pitch speed (where the entire prop is at the same angle of attack), some portion of the prop is at a very high angle of attack (the root), so as you go down in pitch/dia ratio, more of the prop near the hub is actually working in hover, and not stalled. The downfall is that the prop stops making thrust sooner as speed increases. The higher the p/d ratio, the less prop you have working in hover (the root angle of attack deams that part of the prop stalled and only the very tips are working), but,.. the more thrust you have at higher speeds, since the angle of attack of the entire blade is higher, although now below stall angle of attack since you have pitch. I really think that for 3D type flying, we need some progressive pitch electric props like zinger has with some of their wood props (18X6X10, etc).
| Thread Tools | |
| Power system for 13 pound plane | Steve H. | Power Systems | 4 | Aug 18, 2005 01:23 PM |
| Help with power system for 3D Plane | joystix | 3D Flying | 4 | Mar 16, 2005 07:58 PM |
| Yippee! GWS EPSD power system for 3D. | GWS4CEO | 3D Flying | 18 | Jun 15, 2004 03:25 PM |
| Power system for a 5-6lb plane, 8-9lb plane? | sizam | Power Systems | 5 | Jun 11, 2004 05:13 AM |
| best gws power system for 3d planes | easy2fly | Power Systems | 2 | Nov 05, 2003 02:24 PM |
