Old Nov 10, 2008, 10:02 PM
Stu :) is offline
Find More Posts by Stu :)
1855-1921 Naval Fan
Stu :)'s Avatar
Auckland, New Zealand
Joined Sep 2006
Idea
Here's a way to couple a prop to a motor
Found this while doing some research into building a reef aquarium...
http://www.nano-reef.com/forums/lofi...p/t123668.html
...might even work for the rudder as well
Stu
Stu :) is offline Find More Posts by Stu :)
Old Nov 10, 2008, 11:37 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
The sub guys do that with their servo connections.
The magnets are on the ends of the rods that exit the WTC.
They connect to the control hardware mounted to the submarine.
The magnets allow them to install and remove their WTCs for
matenance, or to move the WTC and use it in another sub.
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Nov 11, 2008, 06:27 AM
pkboo is offline
Find More Posts by pkboo
Is life for real?
pkboo's Avatar
Almere The Netherlands
Joined Sep 2006
Wow, thatīs a powerful hold, aquarium pumps are mostly of this type however I didnīt know they held that well. Great heads up Stu, thanx! Boo
pkboo is offline Find More Posts by pkboo
Old Nov 11, 2008, 07:41 AM
DaveMainzone is offline
Find More Posts by DaveMainzone
DaveMainzone's Avatar
Framingham, MA
Joined Feb 2008
Where are do they sell the parts to make up these couplings? How are the magnets attached?
DaveMainzone is offline Find More Posts by DaveMainzone
Old Nov 11, 2008, 08:08 AM
fgroza is offline
Find More Posts by fgroza
USA, OH, cambridge
Joined Sep 2001
Check for Degauss magnets. They sell all types/shapes. Great service. Attach with JB weld or marine epoxy.
Frank
fgroza is offline Find More Posts by fgroza
Old Nov 11, 2008, 12:56 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
D&E makes them, and they are distributed through Caswell Inc.
http://www.caswellplating.com/models/klikons.html
The couplings appear to be a threaded nylon or polyurethane which
attaches to a threaded brass rod. The brass piece is soldered to your
connecting rod.
Slow Stick thrust mod - here's another way Lance42 Parkflyers 2 Jun 02, 2008 12:16 AM
Slow Stick thrust mod - here's another way Lance42 Beginner Training Area (Aircraft-Electric) 6 Jul 01, 2005 05:13 PM
How do you fit Thunder Power LiPos on a RappE? Here's one way :) Jason M Electric Heli Talk 19 May 18, 2003 12:34 AM
Yippee! T6XA Super: Twin motor, throttle-rudder mix (here's how it's done) Zeuser Radios 2 Jan 22, 2003 06:29 PM
Here's a poser for you- motor runs with model switched off. leccyflyer Power Systems 4 May 06, 2002 12:13 PM
