Old Nov 10, 2008, 07:20 PM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Update: new Sharkface from B&Q Floormaster foam. Plus video (see post #21)
Anyone remember Eric Clutton's "Sharkface"?
I just finished this one, entirely from B&Q Floormaster 6mm insulation, to the outline & dimensions of the original 1965 plan (thanks Vintage1!).
My last Sharkface was around 1970 and with single channel radio it weighed 3 times as much as this new one, my Cox Babe-Bee could hardly lift it.
Flying weight is 6oz, on rudder/elevator/throttle, 350mah 3S lipo & a Typhoon micro 3/3D.
Entirely covered & decorated with coloured parcel tape which added just over half an ounce.
Not flown yet, weather has been appalling for weeks now, just need a calm, dry day...
Cheers
Phil
edit: video added in post 21.
phil_g is offline Find More Posts by phil_g
Old Nov 10, 2008, 11:47 PM
Tripod333 is offline
Find More Posts by Tripod333
Joined Jun 2008
I like it!
Tell me more about that foam. I looks like FFF.
Also, I know you have not had a flight yet but... one thing that sticks out to me is the horizontal stab is quite a bit below the thrust line. Might this add and odd characteristics?(just for the record i'm quite new to the hobby and i'm tossing arround terms i don't know alot about, but thats how we learn right?) The main wing does not look flat, is that an angle or a curve?
This plane reminds me of the Electric Orange J3 Cub(my first build and flight).
Cheers and Good Luck on the maiden!
Tripod333 is offline Find More Posts by Tripod333
Old Nov 11, 2008, 04:08 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
The only odd characteristic is it rips off in hard landings.
Old Nov 11, 2008, 06:05 AM
phil_g is offline
phil_g's Avatar
Joined Jul 2007
The foam has been used by a few people here (search for Floormaster), its used to insulate & support laminate flooring. Its very much like depron but has one surface very slightly harder, like a thin skin effect. Unfortunately this means that bigger pieces do tend to warp a bit.
The foam comes in a pack of 10 1.2m x 0.5m x 6mm sheets for 11 so its economical stuff to play with. Cuts easily with a fresh blade and glues ok with Cyano/kicker, hot-glue or Por. The Sharkie used about 3/4 of a sheet including the obligatory 'make two left-hand fus sides' Doh!
Yes I recall the regular tailplane repairs... but it wouldnt be a sharkface if you changed it!
Cheers
Phil
Old Nov 11, 2008, 09:10 AM
frank48 is online now
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Nice one Phil
Repairs easy aswell, bit of hot glue works wonders....
I like the finish, where did you get the tape from?
Cheers,
Frank
frank48 is online now Find More Posts by frank48
Old Nov 11, 2008, 09:29 AM
phil_g is offline
phil_g's Avatar
Joined Jul 2007
From ebay, http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=310090306169
Its nice & glossy but unforch shows the overlaps a bit... I should have been more careful trimming it. I got quite a few creases in there too, I'm sure a solarfilm master would do a much better job! But the tape is cheap, quick, easy & light - ideal for foamies!
Edit: I just discovered that if you're careful, the packing tape shrinks with the covering iron, so you can get some of the wrinkles out!
Cheers
Phil
Old Nov 11, 2008, 09:44 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Brilliant that Phil - Sharkface is a legendary airframe and a new version in high faluting new tech materials is a real laugh.
That B & Q depron is good stuff too. I use a lot of it for my Cub Scouts building sessions - the last one was about three weeks ago - where they build what I call the 3p Zagi - a free flight flying wing ballasted with a two pence piece and a penny taped to the nose and trimmable 2mm depron elevons and winglets.. They all have to perform a distance flight in the scout hut - one named manouver and then a mass lauch, before they spilt up and start combatting.
It's the first flying model aeroplane a lot of the lads (and now girls too ) have ever built and they really get into it.
My Little MO often gets mistakenly identified as a Sharkface and is just as mental, but I'm defo going to have a go at a foamy Sharkface though now that I've seen yours.
leccyflyer is offline Find More Posts by leccyflyer
Old Nov 11, 2008, 10:33 AM
phil_g is offline
phil_g's Avatar
Joined Jul 2007
Hey we need to see the 3p Zagi plans! did you put radio in one yet?
The only change to the sharky is that I continued the line of the upper rear fus to the 'spar' position, where the wing is cracked & undercambered by 1/2", then from the 'apex' where the spar would be it tapers down to the original fus outline. There is no spar as such, but I added a 1/4" preformed balsa Leading Edge with Por.
Phil
Old Nov 11, 2008, 10:46 AM
Raymond-leflyr is online now
Find More Posts by Raymond-leflyr
Hey, watch this!
Raymond-leflyr's Avatar
United States, NC, Garner
Joined Feb 2005
My Sharkface
I met Eric and had my photo taken with him at one of the Toledo, Ohio shows. He's as much fun as the airplane is.
For what its worth, Sharkface took first and second place in the largest Carolina 1/2A Crew's Reedie Race a couple of years ago. My updated version is called Sheetface. Guess what the wing's made of?
Raymond-leflyr is online now Find More Posts by Raymond-leflyr
Old Nov 11, 2008, 11:27 AM
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
The only change to the sharky is that I continued the line of the upper rear fus to the 'spar' position, where the wing is cracked & undercambered by 1/2", then from the 'apex' where the spar would be it tapers down to the original fus outline. There is no spar as such, but I added some 1/4" preformed Leading Edge balsa with Por.
Phil
Thanks for the link Phil.
Re your spa - this 3M tape adds fantastic strength to a wing, tape from tip to tip top and bottom, I've never had one fold yet
http://cgi.ebay.co.uk/1-x-3M-SCOTCH-...742.m153.l1262
Cheers,
Frank
Old Nov 11, 2008, 11:38 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Doesn't look like a sheet wing on the stick and tissue Sharkface. Ray
dekan is offline Find More Posts by dekan
Old Nov 11, 2008, 01:59 PM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
Phil,
Remember the plan ?
I have an original 'pink'? copy ( free in July 65 Aeromodeller magazine ) somewhere...!
Your model is a fantastic example of the huge difference that modern technology has made to flying models.
Electric powered and with proportional radio control - yet still much lighter than the original model...
Excellent...!
I have been told that B&Q are selling "some sort of depron for 12 a pack" and I am now inspired to go and get some !
added comment:
Impressive Pendelfin collection ! ! !
Keven.
keven64 is offline Find More Posts by keven64
Old Nov 12, 2008, 06:29 AM
Hey, watch this!
Joined Feb 2005
You had to ask . . .
Old Nov 12, 2008, 06:34 AM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
Well...So that's what you think of the question? ....but is there any need to poke your tongue out....Hahhah
Old Nov 12, 2008, 08:23 AM
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Reckon its gotta be "three sheets to the wind"
Discussion UK Foam - anyone tried floormaster foam board from B&Q RJPIoW Foamies (Scratchbuilt) 22 Oct 03, 2008 04:49 PM
Discussion New plane from Jason Noll/Fancy Foam Azarr Indoor Pattern/F3P 176 Mar 10, 2008 05:19 PM
new project from foam please look reznikvova Foamies (Kits) 3 Dec 21, 2001 05:29 PM
New Guy from Lubbock Introduction radix2 Electric Plane Talk 6 Jul 15, 2001 07:01 AM
new antenna from www.Azarr.com Fred Bronk Parkflyers 8 May 05, 2001 03:21 PM
