Old Nov 09, 2008, 03:41 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Estarter recommended slow flyer power setups
I'm going to put together an Estarter for my 8 and 11 year old sons to learn on. What is a good slow flying power setup (emphasis on slow) that will give a pretty good amount of flight time?
Steve
SteveC68 is offline Find More Posts by SteveC68
Old Nov 09, 2008, 05:57 PM
Time Pilot is offline
Find More Posts by Time Pilot
Joined Jan 2004
If you want the Estarter to fly slowly, then it has to be light. You don't need a lot of power.
For example, I've been pulling 250 mAh from 2S lipos with 6 min flights on my Estarter. If my math is right, that's under 25 watts of power average. This is using the stock 350 motor system, a 500 mAh 2S lipo, and 3 Hitec HS55 servos, stock landing gear, and minimal paint/stickers on it.
It flies quite slow. If I every build another Estarter, I may put a smaller brushless motor on this one, remove the landing gear (belly land) and see just how slow this thing can go.
I only drain those small packs half way and they cost about $6 each at Hobbycity.
Time Pilot is offline Find More Posts by Time Pilot
Old Nov 09, 2008, 06:15 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
You may be able to use a 24g outrunner, 1300kv on a 2 cell if it built light enough.
I use the same motor on 2 cells, on 7-8oz Flying Wings and Boomers and 3 cells in many planes like the SuperCub, Typhoon, 55" Windrider Glider, Stryker and they all have good low speed and vertical.
Build the E-starter light, install only the servos and then weigh it. Add the weight of the motor/batt that you think will power it, then check the thrust of the motor to see if its close to the total weight. Butch
Butch777 is offline Find More Posts by Butch777
Old Nov 09, 2008, 08:52 PM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I have both of these motors that I could use.
http://www.hobbycity.com/hobbycity/s...idProduct=2069
http://www.hobbycity.com/hobbycity/s...idProduct=5354
You think 2S? I've even got a 10amp esc as well. I guess I should go with rudder and elevator only just to keep it light? And what slow fly prop would you recommend?
When I was a kid I learned to fly on a trainer .40 and my first plane was a cox sportavia with an .049.
Old Nov 09, 2008, 09:20 PM
Butch777 is offline
Livermore, CA
Joined Sep 2004
The 1300kv 24g motor will pull about 11ozs of thrust on a 10x47 prop, so you should be able to build it under 11ozs no problem. Just use 6g servos and about a 800-1000mah 2 cell. You'll need to dig out a new batt hole, but thats easy.
Rudder would be easier for a beginner to fly, but most of mine are 3ch, aileron and elevator, using only 2 servos, so the weights the same.
I built mine light, without the wing struts, landing gear and no paint or decals and they are under 12ozs with the stock 63g 350 motor and 1320mah 2 cell. Butch
Slow-flyer powerd parachute? PunkerTFC Parkflyers 40 Mar 10, 2009 03:25 PM
Discussion Recommended Slow Flyer? jmroscoe Parkflyers 11 Nov 09, 2006 11:03 AM
Alert Slow Flyer FFF Power System Help !!! RC4_LIFE Power Systems 3 Sep 07, 2004 02:55 PM
my first slow flyer Neilmgb Parkflyers 8 Jun 07, 2004 07:00 PM
Want to build a slow flyer / indoor stick plane.. FlySilent Electric Plane Talk 4 Sep 06, 2001 10:52 PM
