Old May 26, 2009, 10:33 PM
jp.electrik is offline
Find More Posts by jp.electrik
PunchDrunk ex-Pug try'n fly'n
jp.electrik's Avatar
Joined Jan 2009
Originally Posted by Lee
I decided for fun to set one as a flying wing and fly with elevons and a fixed tail.
Lee, Mine flew well until I had to change the motor and consequently the CG. I never found the new CG with the lighter motor. I am dying to hear where yours ends up. jp
jp.electrik is offline Find More Posts by jp.electrik
Old May 26, 2009, 11:46 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
By my calculations the CG won't change even though i am flying with elevons rather than elevator ailerons. Only test flying will tell.
Lee is offline Find More Posts by Lee
Old May 27, 2009, 03:12 PM
derJuF is offline
Find More Posts by derJuF
derJuF's Avatar
Lahr / Germany
Joined Jul 2006
Originally Posted by bluefalconhollan
You made a really nice movable tail! Today I added a video of the flight of the bald eagle:
http://vimeo.com/4841183
..thank You I love your flapping Bald eagle!
The first testflight of mine was sucessful, after locating the right cg i can steer perfect up/down/left an right.
One of my next projects will be a ornithopter model (...perhaps a bat with 80cm Wingspan and red glowing eyes for confusing my neighbours ) but first i have to finish the current bird and make a video of it.
greetings juergen
derJuF is offline Find More Posts by derJuF
Old May 27, 2009, 10:52 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Here is proof of concept.
The EPP Peregrine flies well without the elevator.
The advantages are....
The elevator servo is no longer needed. This saves weight and cost.
The elevator servo has had high the highest stress and had the biggest likelihood of broken horns and gears.
The plane is easier to fly and tends to be more gentle. I handed the transmitter to a 1 month flyer who said it was easier to fly than his flying wing.
Disadvantages ???
Harder to get the tail glued in the exact position for flying. I might make it adjustable like the Q-Planes
The separate elevator looked cool.
Some of the extreme stunts that came from the big tail will not be possible.
Note.... I made a typo in the video. Crashtesthobby is @gmail.com not @gmail.org.
The video is a little overexposed and the bird appears white. The paint on the Peregrine looks great with the multi-tone paint. Wish it showed up better.
Peregrine with Elevons 5-09 (4 min 10 sec)
Old May 28, 2009, 04:10 AM
Joined Jan 2009
Aha! I had not considered keeping the tail as an H stab.
Mine was H-stab-less.
That should make it much more stable, but yes, a bit less aerobatic.
Awesome Lee! jp
Old May 28, 2009, 11:58 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
JP - A comment you made a long time ago was the motivation for trying the elevons.
The plane still needs to look like a bird. The tail helps.
This video was shot a couple of months ago with the old Peregrine set up on the thin wing. I fly these planes a lot. My brain likes to see them in the air.
EPP Peregrine at the Practice Field. (3 min 23 sec)
Old May 28, 2009, 12:15 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Neat! Now who wants to try elevon-only flying with the FFF eagle? If I had a bashed-up one I would do it.
I have done some flaperon testing with my eagle, and dropping both warperons (ailerons with outer end fixed at neutral) 30% with no elevator correction results in a sharp dive. 20% up correction on the V-tail surfaces is needed to fly level with that flaperon setting. I'd assume it would be similar in reverse. And seeing how well the eagle turns with warperons alone and how nasty rudder action is with the V-tail (more roll and dive than skid turn), maybe an elevon-only eagle is viable.
Gain: Perhaps none if your eagle has no dual-servo ailerons , but if it does, you can eliminating two servos, simplify the build, and drop back to a less expensive 4CH RX.
Loss: Perhaps little or none. Although an aileron eagle with V-tail is capable of some simple aerobatics, that certainly is not it's primary flight envelope. It may do just as well with elevons only.
Tom Frank is offline Find More Posts by Tom Frank
Old May 28, 2009, 12:24 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
They are flying a lot of flying wings with the KF airfoil. It should work fine if you get the CG right.
I like the variety of this thread!!!!
Old May 28, 2009, 02:50 PM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Another EPP Peregrine Falcon about to fly.
Just finished this up and I am looking forward to a maiden flight. My build details are on my blog (you may have to scroll down a little).
I think that I would like to try the elevon version. A fixed tail would simplify things.
The graphic design was done by a local artist, she used water-color paints, and markers. It added no weight at all.
Mattie showing off the falcon.
nioa is offline Find More Posts by nioa
Old May 28, 2009, 04:08 PM
Joined Jan 2009
You have a good memory Lee. I did get my falcon Wing to fly until a motor issue forced me to make a change causing the CG to shift. I lost patience before I found the new CG. Mine had very little tail, static of course. She looked and flew great. I just grew tired of the R&D which was depleting my motor supply. I lost patience with the tractor prop, I wonder if a push confg. is possible?
Here is a shot of her from last Fall. jp
BTW; Judy rocks IS She available for other work?
Old May 28, 2009, 11:59 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Here is something TJ and I have been working on. I keep trying to get a bird look on one of my flying wings.
http://www.rcgroups.com/forums/showthread.php?t=1052384
Old May 29, 2009, 12:09 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The plane looks great!!!!
The videos I just posted are stock kits checking out the kits.
Old Jun 02, 2009, 01:00 PM
nioa is offline
nioa's Avatar
Phoenix, AZ
EPP Peregrine Falcon with Elevons
I reconfigured the EPP Peregrine Falcon with elevons.
The maiden flight was good, in fact, very enjoyable. The plane tracked well. The hardest thing (which was really not that hard) was to figure out the best position for the now fixed tail (because of the complex shape of the tail, it is hard to tell if the tail is "level" with the fuselage).
Before I flew her with the new elevons, I balanced the bird from the ceiling (I used about 2 feet of string attached to the bird and the ceiling) on her CG and powered her up slightly. This allowed me to roughly set the angle of the tail by observing how the fuselage would deflect up or down. This got me into the "ballpark" enough so that I felt confident that the bird wouldn't tip up or down excessively on her first actual flight.
Initially, I set the angle of the tail at what I thought was "in line" with the fuselage, then I used the method above; it turned out that the tail angle pitched the fuselage up excessively. Lowering the tail resulted in a "straighter" thrust vector (naturally, the bird is going to try to pivot around the hanging point, so this method has its limitations, but it does seem to get you into the "ballpark").
My "guess-ta-mate" was close enough;, the bird did pitch up slightly even though the tail "looked" like it was slightly in "down" elevator position (better to pitch up, then pitch down ). I will fine-tune it later.
A great bird, now even better!
See my RCGroups blog for more pics and details.
Disadvantages ???
Old Jun 02, 2009, 01:38 PM
Joined Jan 2009
[QUOTE=nioa]I reconfigured the EPP Peregrine Falcon with elevons.
....Lowering the tail resulted in a "straighter" thrust vector ....I will fine-tune it later.....A great bird, now even better!
Great work, nioa!
The more you can fine tune the angle of incidence the faster and more efficiently She will fly. You might find the Dive Test helpful, I certainly do.
I'm sure you are familiar with it but here it is anyway...
Get Her trimmed so She will fly level with 50% or less throttle.
Cut throttle and put Her into @45 deg dive.
If you have the CG and trims right She should not change attitude and remain at the same angle She started the dive at. If She noses up you have the CG forward and/or the angel of incidence to high.
The perfect CG with the perfect Angle of Incidence will hold the same dive angle during the test. This will give you; less drag, more speed, better efficiency.
Great work! It appears I could have used a bigger H-stab in my efforts with the "Flying Wing Falcon". Probably looks better too!
jp
Old Jun 02, 2009, 04:51 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
persubscibed
Manta1 is offline Find More Posts by Manta1
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 09:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
