Old Nov 23, 2012, 11:15 AM
Lee is online now
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I have a friend that sez I will never be able to fly plane like a bird because a bird has a brain the size of a walnut and I can't compete with that.
Lee is online now Find More Posts by Lee
Old Nov 23, 2012, 11:20 AM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Oh that's nice Highviz...
G-LO is offline Find More Posts by G-LO
Old Nov 23, 2012, 11:22 AM
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Ha, ha..that's funny, Lee.
Old Dec 01, 2012, 06:00 AM
MrGloriousfall is offline
Find More Posts by MrGloriousfall
France, IdF, La Roche-Guyon
Joined Oct 2011
flat tail without vertical rudder
hi everyone, here is my contribution to the thread; it fliesonly in slope soaring, it's near 1m30 wingspan , weight is 270g and it flies great in 15 to 25km/h of wind. eppler186 airfoil, 2 new wings are going to be built with eppler184 and eppler182 to try to fly in stronger wind. hope you'll enjoy!
the commands in action:
prototype d'oiseau rc: commandes de roulis, tangage et lacet (1 min 13 sec)
a flight in approximately 10km/h wind:
proto d'oiseau-rc, 2nde seance de vols tests, BEYNE CAB, faible vent (environ 10km/h) (2 min 31 sec)
a flight in approximately 30km/h wind:
proto oiseau BEYNE CAB 011112 30kmh ailes modifiées (5 min 21 sec)
MrGloriousfall is offline Find More Posts by MrGloriousfall
Old Dec 01, 2012, 06:20 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Nice work on the control surfaces , but it needs to penetrate a lot better ,cuttting bevel edges on all the feathers helped mine but I needed thinner wing section also,cutting down the surface area by using rounded body would help also.
good luck on the next one .
olmod is offline Find More Posts by olmod
Old Dec 01, 2012, 10:08 AM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Interesting variation on the tail feather hinge orientation. Does this give some banking about the roll axis in addition to elevator pitch control? And the "crow" control surfaces on the wings (up aileron with down flap)... is this used to lateral control in lieu of a rudder?
https://www.youtube.com/watch?v=5lT5...=results_video
http://www.youtube.com/watch?v=KNs72nc2f2Q
https://www.youtube.com/watch?v=Ch202fXRViU
Tom Frank is online now Find More Posts by Tom Frank
Old Dec 01, 2012, 10:43 AM
Joined Oct 2011
hi tom,
i builded this like the inakakoubou condor (look at his youtube channel, i saw some of his vids earlier in the thread).
this kind of control on the wing has the same effects that classicals ailerons, inakakoubou says its the only way to make it turn because there s no vertical fin.
its mix with the tail to be more efficient: for a left turn, on the left wing aileron gets up while flap gets down, nothing happen on the right wing but the left elvator get up while the right elevator gets down.
it works pretty well, u can make complete circles easily, i v got a real control of the flight
Old Dec 01, 2012, 10:46 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
hi tom,
this kind of control on the wing has the same effect that classical ailerons, some say its the only to make it turn because there s no vertical fin.
its mix with the tail to be more efficiency: for a left turn, on the left wing outside aileron gets up while inside aileron get down, nothing happen on the right wing but the left elvator get up while the right elevator gets down.
Thanks... just as I thought! It flies very stable!
Old Dec 01, 2012, 11:40 AM
Averan is offline
Find More Posts by Averan
United States, CA, San Rafael
Joined Mar 2012
Tres cool Mr Gloriousfall!
Averan is offline Find More Posts by Averan
Old Dec 01, 2012, 12:12 PM
Averan is offline
Joined Mar 2012
Here's my latest bird-like plank wing:
Flying The Petrel (5 min 22 sec)
It's more like a powered moth slope glider than a realistic bird, but I took inspiration from gulls and hawks when designing it. It flies great!
Old Dec 01, 2012, 10:51 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Averan:
Would like to see a plan for the Petral if you are so inclined.
Thank you;
Dave-
foamdave is offline Find More Posts by foamdave
Old Dec 02, 2012, 11:03 AM
Averan is offline
Joined Mar 2012
Originally Posted by foamdave View Post
Averan:
Thank you;
Dave-
I'll give it a go. Will take me a few days.
I've got a few different ways to make the fuse, but carved this one out of EPP. It can easily be done with flat foam.
Old Dec 04, 2012, 12:50 AM
Averan is offline
Joined Mar 2012
Petrel plans
Hey Dave,
Here's what I've sketched up so far for a cut EPP fuse. Its not an exact science of course, but there are a few details I should probably point out in a video. I'll start a separate thread for all that and post the link here when I have more to share. A lot of tricks come from the 'scratchbuild university' thread, including the use of plastic credit/gift cards for motor mount and strengthening weak joints or sections. I cut one up and lined four pieces inside the square spar hole through the fuselage so that taking the wings on and off would not tear away the foam. I also bent one into three sections and taped it over the nose to create a motor mount.
Note the square balsa wood main wing spar; much stronger than round and easier to secure inside the wing. Of course feel free to adapt to carbon spars or whatever you prefer! =)
I'll continue working to make a flat foam fuse version too.
Thanks for your interest! =)
Old Dec 04, 2012, 04:39 AM
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Excellent! That was very inspiring I'm glad someone else tried that technique.
Question: Will this technique do well with a motor in it? And how with the plane behave with less polyhedral?
Again, excellent video.
Old Dec 04, 2012, 11:24 AM
foamdave is offline
skumgummi dave
Gresham, OR.
Joined Mar 2004
Averan:
Thank you. The plans look good... Looking forward to more info.
Regards;
Dave-
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 09:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
