Old Oct 19, 2012, 04:10 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
A couple of photos of the Peregine in the air. This bird is not easy to fly.
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Oct 19, 2012, 07:43 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Does it keep changing direction?
olmod is offline Find More Posts by olmod
Old Oct 19, 2012, 10:44 PM
nickchud is online now
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
fine paint job, Joel!
How did yo do that?
Nick
nickchud is online now Find More Posts by nickchud
Old Oct 19, 2012, 10:56 PM
Joined Aug 2000
The paints are inexpensive hobby acylics applied with paintbrushes. The bird has a number of issues that make it a handful, although I added about an oz odf lead to the nose that has calmed it somewhat. It is not that responsive to the ailerons. The v tail is much more effective. . I am not used to having to fly rudder and aileron at the same time. It wants to pitch up under power or in a turn and full down elevator must be used to prevent a pitch up and stall even with substantial down thrust. This is accentuated when to flaperons are set for optimum glide. The plane is stable in a glide but great care must be taken when flying under power or a stall is easily induced. It recovers relatively quickly if one does not overcontrol it.
Old Oct 20, 2012, 02:33 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
Would some alleron differental help and a more forward cg ?
Old Oct 20, 2012, 02:55 AM
Joined Aug 2000
I already have aileron differential programmed, and a 45 degree dive test would seem to indicate that the bird is already nose heavy. I will probably try to figure out how to get more downthrust.
Old Oct 20, 2012, 04:52 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
A 45 degree dive test? not sure if you mean it does not recover by itself or it does.
Old Oct 20, 2012, 10:10 AM
Joined Aug 2000
Olmod, one way to determine if a model is properly balanced, is to put it into an unpowered 45 degree dive. If the plane pitches downward to a steeper than 45 degree angle, it may be an indication the plane is tailheavy. Conversely if the plane pitches up, it indicates the plane may be noseheavy. In the Peregrines case, it pitches up.
Old Oct 20, 2012, 11:05 AM
nickchud's Avatar
Market Harborough
Joined Apr 2006
Dive tests..
When I recently proposed a dive test on the Canard forum, in more or less the same terms as Joel, above, this is the advice I got - from Don Stackhouse, who definitely knows what he's talking about.
Old Oct 20, 2012, 05:48 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Thanks Joel ,that clears things up a bit in my days of rudder only towline A1 & A2s the deepening dive was a well known problem ,
shallow dives have always been my personal use, and power off to trim for best glide then apply power to observe what power thrustline trim is needed, but I have always found the more power/speed the more adjustment needed.
I have also had two aircraft that flew best with the cg right on the leading edge
and that confused the heck out of me.
Old Oct 21, 2012, 05:23 PM
bluefalconhollan is offline
Find More Posts by bluefalconhollan
Blue Falcon
bluefalconhollan's Avatar
the Netherlands
Joined Jan 2007
Pusing FPV to the limit, Flying with Wild Birds. (5 min 45 sec)
bluefalconhollan is offline Find More Posts by bluefalconhollan
Old Oct 22, 2012, 12:26 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Great vid,great control skill,heard the bird's sound when vid started
thanks for sharing
regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Oct 22, 2012, 03:21 AM
Taiwan
Joined Aug 2011
Put a reversed "V" tail on my gull and testing flight this morning,it flew very well as normal "V" tail gull bird,but I can felt some improvement on the gliding capability as you can see from the vid.
did a couple loops because it's quite a fun in the nice autumn day here in Taiwan
cheers
Sam
PICT1594
PICT1608 (1 min 59 sec)
PICT1594
Old Oct 22, 2012, 08:54 AM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
The glide IS good* It looks like a pleasure to fly.
Sam, I know I ask this question last year sometime but, can you please take a few pictures of the way you setup your motor in your fuse? You are the ONLY person I know with that setup. The seagull has a very fast climbing rate! I would love to have a bird that flies like yours....
G-LO is offline Find More Posts by G-LO
Old Oct 22, 2012, 11:11 AM
Joined Aug 2000
Sam, what control surfaces are you using on your Gull. It appears to be elevons only?
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 10:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 08:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 02:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 06:41 PM
