Old Sep 25, 2012, 01:45 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
Nick Bo you have anything that shows controls used on these birds.
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Sep 25, 2012, 03:16 PM
bat is offline
bat
Find More Posts by bat
bat
bat's Avatar
cincinnati
Joined Jun 2003
I am really interested in the prospect of an rc condor. In doing research I discovered the king vulture while only having a 6 foot wingspan is closely related to condors in body and wing shape. The broad wings and short tail make for an intimidating design.
bat is offline Find More Posts by bat
Old Sep 27, 2012, 10:09 AM
acreative is offline
Find More Posts by acreative
Joined Aug 2012
Hi all,
relative newbuilder here needing some advice
Am building the FFF eagle (46") and was wondering what people were using as a wing-brace? I've build wings before with a wooden dowel etc. to strengthen but can't see how i could do it with this wing without the top 2 layers sticking up!
Are you all using flat carbon strips?
Also... how do you get a decent dihedral on the wings whilst still keeping them strong?
The next step is to somehow glue the V-shaped tail feathers?? That's another mystery lol
Thanks for any advice... i'll get there in the end!
Tim
acreative is offline Find More Posts by acreative
Old Sep 27, 2012, 02:18 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by acreative View Post
Hi all,
Tim
I used my dremel tool to create two span-wise very shallow trenches (e.g. 1mm) in the top and bottom wing surfaces opposite each other. The I used epoxy to glue the wings together with my desired dihedral. Once that was firmly set, I laid a thin layer of 1 hour epoxy in the upper wing trenches, and laid 12K CF ribbon tow strips in the still liquid epoxy, then laid down another thin layer of the same epoxy on the top surface of the CF tow strip, and worked it down into the tow weaving with a flat wood stick so it was essentially flush with the wing surface. Once the CF tow was fully impregnated with epoxy, I let it cure, then repeated the process on the underside of the wings. Once painted, the strips are invisible for all practical purposes.
The eagle flies very slow, so the wing loading is not very severe and the tow strips provide more than adequate strength unless you have more power than needed. The wings have easily survived both slow inside and outside loops, but I seldom do that since it's not meant to be an aerobatic plane. Here's some pics:
Tom Frank is offline Find More Posts by Tom Frank
Old Sep 27, 2012, 02:48 PM
Joined Aug 2012
Thanks very much for the advice (great looking bird!).
That CF Tow looks very useful (hadn't even heard of it! Might have to order some.
Presumably, because yo have it top and bottom the wing won't collapse/unfold once it's all set?
What servos are everyone using? I have some spare 9g servos about, but can get some 5g if necessary?
Is a standard setup ailerons and elevator? Or is there a way to mix in a rudder too? I'm using the V-tail setup.
Thanks again for any help
Tim
Old Sep 27, 2012, 03:01 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Comments in green below in your post:
Yes, that's correct. The CF tow is very strong in tension, and the foam of the wing keeps the opposite top/bottom strips separated so they act like the flanges on an I-beam.
9 gm servos are just right, given the size of the ailerons. I did not cut the tip end of my ailerons free! The ailerons actually twist rather than uniformly deflect (I call them "warperons"). The inner end near the body deflects the most, with less and less deflection towards the tip, where they don't deflect at all since the aileron foam is still attached there. It sounds strange, but that's the way the real birds wings shape themselves in flight if you look at pictures, and I wanted to emulate that. I did not use Depron (or similar) stiff foam sheet, but rather the paper-clad foam board you can buy with the paper removed (after soaking in water). This leaves very flexible foam sheet, perfect for this application.
The eagle turns very flat with just aileron action alone, though I also used the V-tail mix in my TX for both rudder and elevator action. Rudder is seldom used because the eagle will yaw, then roll and dive when the tip dihedral turns into the on-coming airstream.
Tim
Old Sep 27, 2012, 04:04 PM
Joined Aug 2012
Brilliant! Thanks so much for your help... i've got a very clear plan of what to do now (i've had the parts taped up for a few days wondering what to do!!). Time to get started
You've already helped enough... but if you or anyone else has a good photo of the tail servo setup that would be most useful as I know i'll have to deal with that soon!
All the best
Tim
Old Sep 27, 2012, 04:27 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
All the best
Tim
The attached pic shows how I set my V-tail servos (with pushrods crossing to opposite tail surface -not necessary... just easier). And as soon as the video is done being prepared on Vimeo in about 30 minutes, the following will show all the control action:
C:UsersTomDesktopRC StuffEagleEagleControlCheckout (1 min 51 sec)
I show flaperons in the video, but with the bird basically being a flying wing, they have the reverse action of what's expected...plane will dive with flaperons down. I don't use that function now... the bird flies in slow enough without them.
Old Sep 27, 2012, 04:38 PM
Joined Aug 2012
You're a real credit to this forum Tom, I can't thank you enough
It makes it so much easier for a complete newbie to get first hand advice!
I've built one plane before (the BB J3 Cub) and am totally hooked on building and flying them!
Here's a quick vid on this post of my maiden flight (second takeoff I think) if anyone's interested:
http://www.rcgroups.com/forums/showp...&postcount=270
Cheers
Tim
Old Sep 27, 2012, 06:37 PM
coa106 is offline
Find More Posts by coa106
United States, DE, Wilmington
Joined Apr 2010
I am also making an eagle and thank you Tom Frank for making this very helpful video. awesome community. I will post vids of maiden or first flights when finished. looking forward in flying the eagle...
https://vimeo.com/50330729
coa106 is offline Find More Posts by coa106
Old Sep 28, 2012, 09:02 PM
Joined Aug 2000
Kestrel flew for the first time today.
Utube Power Kestrel (14 min 0 sec)
Old Sep 28, 2012, 10:50 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I have several flyers asking about Peregrine kits. At this time we are not cutting the kits but having a good flying bird plane is on my bucket list.
Here is an idea I haven't tried and are untested.
I actually think a peregrine shaped flat foam plane like the FFF Eagle that has plans that are on the Peregrine thread may work if kept light. You could use any silhouette of any bird regardless of the shape of the wing and not have the stall problems that we have with the more complex airfoils and strange angles we have to cut.
Lee
Lee is offline Find More Posts by Lee
Old Sep 29, 2012, 01:43 AM
highviz is offline
Find More Posts by highviz
Joined Mar 2009
Nice one! Looking pretty good now.
Malcolm
highviz is offline Find More Posts by highviz
Old Oct 01, 2012, 09:57 AM
Joined Aug 2000
Lee, I certainly cannot claim to be an expert in bird plane design, but I have an idea as to why you might be having tip stall problems. I think it is because you are devoting far too much wing surface area to the ailerons. High deflection rates will stall the wingtip and when 30 % or more of the wing is stalled you will tipstall. While the Kestrel is my first devoted bird plane , it does not have a tipstall problem and its wing structure is far less sophisticated than yours. The v-tail is more effective in controlling the kestrel and ailerons are not even really needed. Why not try greatly reducing your aileron size and fly them with significant differential. I hope you do not mind this suggestion, I realize you have far more experience with this type of design than I do. I might add I have found your thread very inspirational and have already begun designing my next attempt. An 82" Osprey.
Old Oct 01, 2012, 10:44 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7 N 8.9 W
Joined Jul 2007
Lee
Lee, are you talking about somethink like Nick's Bluebird style of aircraft ? ......
I could easily see some effort in making the model more bird like, would be relatively easy, and lots of shapes (bird types) could probably be created without too much effort .... even 'as is' it looks great in the air with the profile looking very Hawk'ish .....
Nick's design is based on a Kfm2 wing and I have to say my 20 or so flights on the version I've recently built has really impressed me ..... I must get a video for it ....
Here's a link to Nick's design .... http://www.rcgroups.com/forums/showp...postcount=4638
hobie14 is offline Find More Posts by hobie14
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 09:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
