Old Sep 18, 2012, 04:57 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
One of scaled bird lovers like you guys,built a kestrel some time last year
wingspan 75" with simple 3 servos,1500kv 480 grade motor with cheap 4 channel Futaba Tx.
stable,fast and easy glide
just love the scaled bird,could'nt help it
cheers
Sam
PICT0970
PICT0995 (1 min 37 sec)
samwei1950 is offline Find More Posts by samwei1950
Old Sep 18, 2012, 08:57 AM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
You can follow the kestrel build here.
http://www.rcgroups.com/forums/showthread.php?t=1727632
How did you ever get a tame kestrel?
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Sep 18, 2012, 08:59 AM
Joined Aug 2000
Sam, do you have a link for the kestrel build?
Old Sep 18, 2012, 10:57 AM
Taiwan
Joined Aug 2011
No,Joel it's first time to post my kestrel
regards
Sam
Old Sep 20, 2012, 01:49 PM
Joined Aug 2000
Here is a video of this mornings test flights. It did not go well. Any constructive input is appreciated. I plan on adding a vertical tail and carving out fuselage to allow weight to be shifeted further forward. I am hoping those of you more familiar with this type of design may have suggestions.
Final Kestrel test flights (2 min 58 sec)
Old Sep 20, 2012, 04:41 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
https://vimeo.com/49854817
Where is your CG? Do you have any right/down thrust to counter torque roll. Are the wings warped or have equal incidence along their span? Is the tail incidence on the same plane as the wing? How much power were you applying during the launch? Lots of things could be affecting the stability and flight characteristics.
Tom Frank is offline Find More Posts by Tom Frank
Old Sep 20, 2012, 10:29 PM
Taiwan
Joined Aug 2011
Agreed with Tom's point of views,there are many causes against the issue.
my suggestions if you don't mind:
1. lower down the attack angle,max.0.25 degree for the bird,my kestrel is set on
0 degree.
2. move CG a bit forward between 25% to 30%
3. add a leg as fin below the fuselage instead of vertical fin,the pics below maybe
a good idea,it's not my bird.
regards
Sam
thumb-DSCF3253
Old Sep 21, 2012, 08:43 AM
HaoleboyRC is offline
Find More Posts by HaoleboyRC
HaoleboyRC
HaoleboyRC's Avatar
United States, CA, Auberry
Joined Apr 2009
Adjustments
In my experience with flying wings which is what you have the CG should be around 20% and even as little as 15% to start. Most of us flew at 21 or 22% when we got used to our wing. Further back and it is twittchy and needs very little input. How do you have it set up in your radio as a v-tail plane or rudder-vator? I would set it up so your turns are made with the ailerons and did not see them responding in conjunction with your elevator movements. It would be best to have all that working in conjunction with this kind of plane. It looks like you have some high grass to throw into so do some hand tosses until you can get it to glide. Usually a wing has a little reflex in the surface so not sure how you have it trimmed but tape weight to the nose outside the cockpit to get it to glide. I had one wing that would torque roll when power was applied too quickly but when up to speed power would then not make it roll. Hope this helps your beautiful bird to fly.
HaoleboyRC
HaoleboyRC is offline Find More Posts by HaoleboyRC
Old Sep 21, 2012, 11:31 AM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
As I´m a falcon and a hawk lover, I would like so much to build one for me. This thread from Lee has free plans? Could anyone post some free plans for me?
Thank you so much!
Luis
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Sep 21, 2012, 01:10 PM
bluefalconhollan is offline
Find More Posts by bluefalconhollan
Brazil, MT, Barão de Melgaço
Joined Jan 2007
Joel, just ad a transparant vertical fin and your falcon will fly properly. Your color sheme is awesome! Today I did fly with wild birds again:
Drone talking with Seagulls (4 min 18 sec)
Robert.
bluefalconhollan is offline Find More Posts by bluefalconhollan
Old Sep 21, 2012, 03:22 PM
Joined Aug 2000
Really cool Robert. I cannot balance my bird as is and have decided to cut the wing in 1/2 and sweep the wings to move CG point back. Grey area will be added midwing.
Old Sep 21, 2012, 10:14 PM
Taiwan
Joined Aug 2011
http://www.youtube.com/watch?v=79muQ4ETHJA
Robert.
Awesome vid
did not able to hear your "call" dued to the music
great device,wished I'd have one
btw,what is the wingspan of the bird
regards
Sam
Old Sep 22, 2012, 01:11 AM
Joined Jan 2007
Sam: the wing span is 1,9m.
Old Sep 23, 2012, 11:22 PM
Joined Aug 2000
I am posting this video here of an unsuccessful powered flight after glide test indicated adding weight to the nose stabilised it. Hoping someone in these forums will have a solution or at least pinpoint the cause of the problem.
Modified Kestrel powered test flight crash (2 min 42 sec)
Old Sep 24, 2012, 01:24 AM
Joined Jan 2007
Joel, you might need a leading edge-ron too.
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 09:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
