Old Aug 26, 2012, 11:31 AM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
building a successor to my old Bird more than a year and its really bang-up
Speedactyl PX22 & Speedactyl PX22-A
Successor to Speedactyl PX22 meet PX22-A
an more streamline plane a more hot rod looks improve materials and construction
hopefully modernize electronics
Succesor To Speedactyl Jet
update :
Changes:
EPP Material
an more sweptback wings may give a WS of 36inch
Addition of Ailerons
minor changes to the nose section
better structural materials
move back the motor Aft of the Main Wing to reduce noise and turbulence unless you want to grab attention
Lighter electronics
may try a different color scheme
speedactyl is offline Find More Posts by speedactyl
Old Aug 26, 2012, 11:36 AM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
I Like that!
G-LO is offline Find More Posts by G-LO
Old Aug 28, 2012, 01:52 AM
bluefalconhollan is offline
Find More Posts by bluefalconhollan
Blue Falcon
bluefalconhollan's Avatar
the Netherlands
Joined Jan 2007
How to become a cyborg
FPV Mechanical Headtracker (2 min 30 sec)
bluefalconhollan is offline Find More Posts by bluefalconhollan
Old Aug 29, 2012, 12:35 PM
AC5FF is offline
Find More Posts by AC5FF
Where'd The Wise Men Go?!?
AC5FF's Avatar
United States, NE, Bellevue
Joined Sep 2007
Speedactyl
I've watched this thread for ages and I gotta say I absolutely LOVE this design!
I don't remember seeing it before though. Any chance you have plans anywhere???
AC5FF is offline Find More Posts by AC5FF
Old Aug 29, 2012, 07:58 PM
speedactyl's Avatar
Joined Jun 2012
Will try to make one. Kinda challenge because when i build these there weren't any. I just base it on natural dimension, golden ratios, & a few scifi ships for inspiration. and did my cutting like an artist painting on blank canvas.
dint realize it came out beautifully
its like this an Pterodactyl is already cool but add warp engines on it and you spells trouble
if there are any additional design features to add, maybe you can suggest
Old Sep 03, 2012, 04:44 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
subscribed
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Sep 04, 2012, 01:53 PM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
Reverse it, make it a canard?
1967250s is offline Find More Posts by 1967250s
Old Sep 05, 2012, 12:21 AM
speedactyl's Avatar
Joined Jun 2012
possible in some way
BTW would the turnigy 2211-2300 hold an 6x4 prop on an 3s battery? with an 10 A esc frear of overloadin things
Old Sep 10, 2012, 12:17 PM
xardinen is offline
Find More Posts by xardinen
Joined Aug 2011
So I built a 42" FFF eagle with a BW 1300 motor and went out testing it today. For the wing I used 2 sheets of EPP, 10mm thick each. I made the KF airfoil with one step on top at around 50%. The AUW ended up around 340g. The problem is that when I cut the throttle the bird sinks very fast and doesnt glide very well, sloping is probably impossible. The wind was blowing around 3-4m/s. Is the wing too thick or doesnt this airfoil cut it?
xardinen is offline Find More Posts by xardinen
Old Sep 11, 2012, 12:11 PM
Joined Aug 2000
As this thread is what has inspired me to try my hand at a bird plane, I am attaching a link to my build thread. http://www.rcgroups.com/forums/showthread.php?t=1727632
Old Sep 13, 2012, 11:46 PM
speedactyl's Avatar
Joined Jun 2012
Just an Update and as requested some too.
http://www.rcgroups.com/forums/showthread.php?t=1731975
sorry theres no videographer during its maiden but its stable
Old Sep 14, 2012, 06:05 PM
AC5FF is offline
AC5FF's Avatar
Joined Sep 2007
speedactyl
Congrats on the successful maiden flight!! Hopefully you can get someone out with you to get a video of it in the air!
Can you post a frontal view of your creation?
In the earlier posts, expecially with the blue one, the wings have a gull look to them. Kind of hard (for me) to tell if this is an optical illusion or if the wings are actually gull shaped.
What's the wingspan?
The nose looks really sleek, but fragile; any worries on it snapping free during a rough landing?
Old Sep 14, 2012, 08:38 PM
speedactyl's Avatar
Joined Jun 2012
The links are posted To the pdf
Btw this recent plane has the epp wrap in tape then reinforce with BBQ sticks on the inside the 5mm epp is use as skin to produce the nose cone proven to survive a head on only if you keep the AUW lighter then 300g
WS 36 inch
AUW 280g
Note lesson learn from the blue model is to add internal support structure from the neck to the nose
To reduce the chance of snapping on hard landings
My early model the blue one has a dihedral of 10 degrees from the sweep part (inverted gull) some times in the air the whole thing can get to 15 degrees
The recent one the unpainted one is full straight like a plank but the spar only reaches one haft of the sweep and epp foam naturally bends creating the dihedral effect
will find it I know I had it some where (pictures)
Old Sep 18, 2012, 12:00 AM
Joined Aug 2000
Kestrel progress.
Old Sep 18, 2012, 04:57 AM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
Amazing project I would like so much to scratchbuild one for me,
once I love this bird and have a real one here a couple of months!
Could you post details about the building progress and share the plans?
Here some pictures from Eros, our Kestrel, Falco Sparverius!
Originally Posted by Joel K. Scholz View Post
Kestrel progress.
Luis_Claudio is offline Find More Posts by Luis_Claudio
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 10:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 08:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 02:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 06:41 PM
