Old Jul 11, 2012, 06:51 PM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Averan, its here on this thread
http://www.rcgroups.com/forums/showthread.php?t=1107825
G-LO is offline Find More Posts by G-LO
Old Jul 11, 2012, 07:56 PM
kompmen is offline
Find More Posts by kompmen
kompmen's Avatar
Russia, Sverdlovskaya oblast', Kamyshlov
Joined Sep 2011
Originally Posted by Averan View Post
@kompmen - do you have any photos of your bird? it looks like it flies really well! =)
motor 2205C 1400Kv
ESC: 10- Amp
Battery: 2S or 3s , 460mah
kompmen is offline Find More Posts by kompmen
Old Jul 12, 2012, 09:11 PM
Averan is offline
Find More Posts by Averan
United States, CA, San Rafael
Joined Mar 2012
Thanks Kompmen.
Robert, can you explain how Kompmen's hawk can fly without the front flap things, but your seagull cannot? What is the critical difference between the two designs?
Averan is offline Find More Posts by Averan
Old Jul 13, 2012, 01:34 AM
alldn is offline
Find More Posts by alldn
alldn's Avatar
Russian Federation, Tambovskaya oblast, Tambov
Joined Oct 2011
This is my Eagle:
wingspan - 760 mm
weight - 122 g
motor - TURNIGY 2204-14T 19g Outrunner
battery - ZIPPY Flightmax 350mAh 2S 20C
prop - 7х6SF
A very good Eagle, can fly fast and slow. I made it for my grandchildren, they like how it flies.
Орленок. (1 min 45 sec)
alldn is offline Find More Posts by alldn
Old Jul 13, 2012, 02:33 PM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Lovely bird! I'll have to add that to my must have list.
Why not make the vertical surface out of transparent plastic material? Just to make it a little bit more realistic.
nickchud is offline Find More Posts by nickchud
Old Jul 14, 2012, 01:07 AM
alldn is offline
alldn's Avatar
Joined Oct 2011
I think the transparent plastic would be more heavy. In addition, from the land model looks very realistic with a white vertical tail surfaces.
Old Jul 15, 2012, 10:19 PM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
Share some of my Birds Pics
sometimes you dont need to be to realistic at all just go sci-fi all the way
The Inspiration
My planes
if its gonna be a bird or a plane mind as well do both
PX25 glider RC (0 min 57 sec)
px22 RC pusher Jet (philippines) (2 min 42 sec)
speedactyl is offline Find More Posts by speedactyl
Old Jul 16, 2012, 12:07 AM
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
That's actually very nice! I would like very much to see the "original design" one-fuse bird that was in the beginning of the video.
Old Jul 16, 2012, 12:48 AM
speedactyl's Avatar
Joined Jun 2012
thats the only pics taken
most of my builds are as I go along.
sorry no vids of the flight when it was squish under the car seat
also about the Twin Boom design, the reason is smacking the engine down the center of the plane for safety reasons, that leave some structural issues so I've decided to split it and go around it like the S-39 layout , the downside is it makes the plane more noisy . expect a screaming Bird
Vista Verde Ground Pass (2 min 58 sec)
another view of PX22 twin boom bird at 0:20 from a Friend's FPV Plane (Just a quick overhead pass)
Old Jul 17, 2012, 07:45 AM
Pickle72 is online now
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Hey guys, I am building the 56" version of the FFF Eagle. I actually am using 5mm Cellfoam 88 and 3mm cellfoam (plus some 2" foam in the nose I carved.
I have been searching through this huge thread for numbers and I just want to double check with you guys if I have them right.
I should be shooting for an AUW of 20-27 oz?
CG should be from 2.25" -3" from LE.
And how are you bending the wing tips? Just carefully heating and bending up or rolling over a tube? I saw that someone just cut them off, sanded an angel into it and glued them back on. Sounds easy enough.
Matt
Pickle72 is online now Find More Posts by Pickle72
Old Jul 17, 2012, 09:44 AM
SebastianG. is offline
Find More Posts by SebastianG.
SebastianG.'s Avatar
Deutschland, HE, Schlangenbad
Joined Sep 2010
like the pic nr.6 is there any plan ?
i would like to build that one
SebastianG. is offline Find More Posts by SebastianG.
Old Jul 17, 2012, 01:19 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Matt
I used a hair dryer and a muffin tin, with VERY SLOW CAREFUL application of force. That Cell foam is brittle and can suddenly snap. A cut, angle tip can be easier, but if you want a more realistic look in flight, go for the curved tips. You could also use a different foam board for the wing tips, like dollar tree foam or Elmers foam board. These have paper clad surfaces, but it can be removed by soaking in water and rolling/rubbing it off. The foan dos not have that hard burnished surface finish like the Cellfoam, but so it's not as rigid and more compliant with heated bending.
Tom Frank is online now Find More Posts by Tom Frank
Old Jul 17, 2012, 08:49 PM
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Thanks for the tip on bending the tips! Shouldn't be to difficult.
I've got loads of that DollarTree foam board but haven't used any in awhile. I prefer the CellFoam though if I have a choice but I have never bent it like I am going to this time.
I just put what I have on the scale, fuse/wings/motor/esc and all ply pieces comes in at 10.5 oz so I think I am on the right track. I'll set my goal at 20 oz I think. Or should I shoot for a bit less?
Matt
Old Jul 18, 2012, 04:08 AM
highviz is online now
Find More Posts by highviz
Joined Mar 2009
+1 on the heat and carefully bend method. However, if left like this, they can tend to flatten out again over time, especially if left somewhere hot. (if your model lasts that long). They are also quite easy to break on landings. I have two methods to help here:-
1)Cut a vertical slot in the tip feather and insert a thin (1mm) ply spar, which is shaped to the right bend radius.
or
2) Having bent the cell foam, cover top and bottom with paper, applied with wallpaper paste or similar.
Images attached show the ply inserts on some larger tips, that were then covered over with 3mm depron (cell foam) on top, but the principle works just as well on single thickness foam, if the ply is cut flush with the surfaces.
Malcolm
highviz is online now Find More Posts by highviz
Old Jul 18, 2012, 02:07 PM
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Nicely done! I might try that if I decide to do a built up wing next.
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 09:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
