Old Jun 04, 2012, 12:12 PM
discus.fly is offline
Find More Posts by discus.fly
discus.fly's Avatar
United Kingdom, Central Bedfordshire
Joined Jul 2008
Tuck Effect
Ok so moved the cog further forward, flying great hit a large thermal and then found at 1000ft I had no control!
After a few seconds regained control and started a turn to the left but then she then put her nose down and dissapeared at a great turn of speed.
Found her after an extended search. Nose was a right off, interestingly one aerial wire on the Rx was detached and the depron had fractured arround one of the tailerons.
So was this the dreaded tuck effect or not. Not sure if I had control during the dive as could not hear the motor but suspect it was a combination of Rx, Ae wire and the dreaded tuck.
discus.fly is offline Find More Posts by discus.fly
Old Jun 04, 2012, 08:41 PM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
Hope its repairable.
Hard to say what may have been going on at 1k' or whether the tail fracture took place at height or because of the crash. I had a scratch built sailplane fold up flying level into a thermal/mini wind shear once. You should have dive tested for tuck lower down where you could see what was going on. Several dive tests each time picking up more speed and checking how well it responded to up elevator.
Here is something else to confuse the issue. A flat bottomed airfoil when sitting flat will have a degree or 2 of positive angle of attack. After looking at the picture of your plane [nice looking btw] I noticed that the reflex might be enough to give it a negative AoA. The motor in its current location could give it just enough pitch up to compensate for this while under power. Draw an imaginary line through the nose of the foil to the highest part of the reflexed TE and see if it is so. The decalage of the tail should be the same or up a degree.
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old Jun 05, 2012, 06:29 AM
discus.fly's Avatar
Joined Jul 2008
Damage
Had expected to find a pile of Depron but was very surprised to find an more or less intact structure with the wings still intact given that the impact was near vertical.
Wings are repairable but probably best to construct a new fueselarge using the old tail.
Old Jun 05, 2012, 07:18 AM
bluefalconhollan is offline
Find More Posts by bluefalconhollan
Brazil, MT, Barão de Melgaço
Joined Jan 2007
Today I did maiden my EPP seagull. She flies wonderful and gentle. Span 1,75m. I just have to finish some paint.
bluefalconhollan is offline Find More Posts by bluefalconhollan
Old Jun 05, 2012, 10:30 AM
discus.fly's Avatar
Joined Jul 2008
Very nice.
Looks like you have a complex aerofoil. Would be interested to know the design
Old Jun 05, 2012, 10:36 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
What a wonderful-looking scratch-build! The spinner emulation of the beak is very clever. I'd like to see some flight video, please, as well as build details.
Tom Frank is offline Find More Posts by Tom Frank
Old Jun 05, 2012, 11:49 AM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Hi Robert. That looks a lot like Lee's gull wing falcon. Very nice!
Can you take some close up pictures of the wings, servo placement, and the way the wings are mounted. I've emailed you pictures of my bird but I'm still at a stand still of what I should do next. I would love more help from you if you don't mind. Thanks*
G-LO is offline Find More Posts by G-LO
Old Jun 06, 2012, 03:05 PM
Joined Jan 2007
I will ad more details later. Today I did the maiden and film the gull.
https://www.youtube.com/watch?v=WOn3Z4Ax9d4
Old Jun 06, 2012, 03:10 PM
Averan is offline
Find More Posts by Averan
United States, CA, San Rafael
Joined Mar 2012
I can't compete with that level of quality!
Where is the CG on yours?
What is your power setup?
Averan is offline Find More Posts by Averan
Old Jun 06, 2012, 03:15 PM
Averan is offline
Joined Mar 2012
split-tail elevons? i'm so jealous it makes me mad! hahaha! dang i gotta redo mine and get it flying.
Old Jun 06, 2012, 07:16 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
bluefalconhollan:
WOW!
foamdave is offline Find More Posts by foamdave
Old Jun 07, 2012, 03:41 AM
discus.fly's Avatar
Joined Jul 2008
New 160% Eagle
Made a start cutting out a new fuselage for my 160% EPP Eagle. Any advice as to changes to make to avoid the tuck problem I have.
Currently the wing and tail are set at the same angle.
Old Jun 07, 2012, 04:47 AM
Joined Jan 2007
Just finished painting. The wings are fixed to the fuselage. The camera part can come off from the fuselage so there is space for the battery. I use a wing aileron and a leading edge-ron, differential controlled.
Old Jun 07, 2012, 08:24 AM
nickchud is online now
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Leading edge-ron? That's a new one for me. Very interesting!
Do you mean a single servo droops the leading edge at the same time as raising the aileron panel and vice versa? What's the benefit?
Whatever it is, it obviously works beautifully.
Cheers
Nick
nickchud is online now Find More Posts by nickchud
Old Jun 07, 2012, 08:42 AM
G-LO is offline
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Thank you very much Robert. Is there a reason why you glued the wings to the fuse as appose to making it detachable? Sorry for the questions. I'm trying move forward with my falcon. I interested in trying something new this go around.
Lastly. Do you have any suggestions based on the pictures I sent you?
Thank you.
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 2 Aug 31, 2015 09:02 AM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
