Clever. But the rotor is normally fixed to the shaft and supported by the shaft bearings, so you must have a hollow motor shaft with a non-rotating center shaft (like the reversible pitch prop motors for 3D) to anchor the head? Is that a custom machined folding prop adaptor? Very nice adaptation!
Great design and video of the feathers. I lived in Nederland back in the 70s for a couple of years. Nice to see how green it is there. Sure beats the desert here. I would love to see some camera video though the windmills and over the tulip farms.
I have been thinking that the square wing has some possibilities. Some of the spin off designs that are inspired in part by the old peregrine is our slow flyers. http://www.rcgroups.com/forums/showthread.php?t=1538751. I have had the desire to get a bird look to these planes without messing up the aerodynamics. These planes will level themselves and put their nose on the horizon without pilot input. It would be great to have a bird plane that did that. Your square wing gives a little inspiration that the polyhedral design may not be so noticeable in the air if the fuse, tail, TE of the wing and tips have the right look. Any ideas???? |
United States, CA, San Rafael
Joined Mar 2012
Made some progress on my flat foam seagull; mainly cut the ailerons, added servos and attached the motor mount.
Motor is mounted at a slight downward angle so that the angle of attack of the wings is tilted up a bit. Next step is figuring out how to fit all the components into the fuselage. I'll attach a 3-sided body/fuselage to the underside, connecting to the central profile fuse and the wings, to protect everything and reduce drag. I'm hoping the dihedral and simple v-tail will make this a fairly stable flying wing. |
| Thread Tools | |
| Discussion Why aren`t most foam planes made with EPP or equivalent. | Scarey | Foamy EDFs | 1 | Jul 24, 2007 10:20 PM |
| Planes Built With EPP And Depron. What Would Be Your Favorite. | jbj620 | 3D Flying | 10 | Dec 05, 2004 07:06 AM |
| Rave Before n After My new war bird P-51 Mustang(EPP) | powder | Slope | 22 | Aug 22, 2003 01:27 PM |
| hey guys if yous are looking for arf war bird planes | seafire | Foamies (Kits) | 5 | Mar 10, 2002 05:41 PM |
