Old Nov 08, 2008, 06:40 AM
thunderbird3 is offline
Find More Posts by thunderbird3
thunderbird3's Avatar
Joined Oct 2008
Question
will it fly
Is it worth putting electronics in this plane?
wingspan 36cm
length 28cm
weight 15g
thunderbird3 is offline Find More Posts by thunderbird3
Old Nov 08, 2008, 07:25 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
I don`t think its worth it, at least as it is right now.
With no dihedral you must use ailerons, and i don`t see any in the pic.
One moore thing is that the horisontal stab seems to be too small.
I think it`s too heavy also, but with the right gear you might be flying,... fast, maybe too fast..
Magnus
MagnusEl is offline Find More Posts by MagnusEl
Old Nov 08, 2008, 10:09 AM
jingjingjing is offline
Find More Posts by jingjingjing
I love my ID.
Fairfax VA
Joined Aug 2004
It will fly. If you give it a dihedral and larger stab.
I don't think it is too heavy though. With all the electronics it will end up around 25g. It is not too heavy for 14" wingspan.
Finish it and prove that I am wrong.
You will need a 7mm motor or better.
jingjingjing is offline Find More Posts by jingjingjing
Old Nov 08, 2008, 12:10 PM
marksherlock is offline
Find More Posts by marksherlock
marksherlock's Avatar
United Kingdom, England, Essex
Joined Oct 2006
Is the model your own design? As 'Jing says, with some mods to the tail & dihedral - give it a try If it doesn't fly well, you can still put the gear into your next plane - if you do like it and it flys well - you'll be addicted to micro models by then anyway!!!!
Let us know how you get on. Good Luck
Mark
marksherlock is offline Find More Posts by marksherlock
Old Nov 10, 2008, 11:10 PM
Joined Oct 2008
What is a dihedral?
Old Nov 11, 2008, 12:57 AM
Joined Oct 2008
Will it work with a micro brushless motor
Joined Oct 2008
Will it work with a micro brushless motor?
Old Nov 11, 2008, 02:22 AM
b36roxs is offline
Find More Posts by b36roxs
Joined Sep 2006
edit
b36roxs is offline Find More Posts by b36roxs
Old Nov 11, 2008, 03:04 AM
ghostmechanic is offline
Find More Posts by ghostmechanic
1 paycheck away from homeless
ghostmechanic's Avatar
United States, KS
Joined Mar 2006
Originally Posted by thunderbird3
Question - will it fly
You can fly a brick with a big enough motor
ghostmechanic is offline Find More Posts by ghostmechanic
Old Nov 11, 2008, 04:09 AM
Joined Oct 2008
Thanks for your help everyone.
I will try putting electronics in it. If it dosn't work i will put them in different plane.
Is this what you mean by dihedral?
Old Nov 11, 2008, 09:05 AM
irish_lord99 is offline
Find More Posts by irish_lord99
Balsa for me, thanks.
irish_lord99's Avatar
Yalova, Turkey
Joined May 2007
yep, that's dihedral . Do you know what angle that is? You don't want too much or it'll get difficult to steer.
~jake
irish_lord99 is offline Find More Posts by irish_lord99
Old Nov 11, 2008, 12:37 PM
Joined Oct 2006
That dihedral looks about right. Copy that!!!
Mark
Scratch Built Project - Will it fly??? Model Aero Sport Planes 20 Mar 07, 2002 07:48 PM
Will this fly? nolasco Parkflyers 10 Dec 21, 2001 04:13 PM
will it fly? Shawn Palmer Electric Plane Talk 2 Dec 17, 2001 01:06 PM
will this fly??? singlespeed7 Parkflyers 1 Nov 30, 2001 02:27 AM
Eagle II, MM or EP, 6:1, 10-2400mah cells, big prop, will it fly???? mrtim Power Systems 0 Sep 07, 2001 07:49 AM
