Old Nov 13, 2008, 12:17 PM
Sir Raleigh is offline
Find More Posts by Sir Raleigh
Raleigh, NC
Joined Apr 2007
Thanks Rich. Heading for the workshop now.
BTW, the only resistor close to 1K I can find in my parts box is 2.2K. I'm going to use that one. If you know of any reason it won't work, please post back.
Thanks again,
Bill
Sir Raleigh is offline Find More Posts by Sir Raleigh
Old Mar 02, 2009, 06:46 PM
Magnumpi is offline
Find More Posts by Magnumpi
Magnumpi's Avatar
Joined Nov 2007
OK what did i do wrong??? Heres the way it went together, the 2 negative wires soldered together, then a 1k Resistor soldered on the ends of the negative wires, then i soldered the end of the resistor to the middle hole. then one red wire to the 10ADC, and the other red wire to the COM or bottom hole. I think i did it right , but when i check AMPS at WOT it says 8.32 i know that is not right. Can someone tell me from the pictures what i did wrong??
Magnumpi is offline Find More Posts by Magnumpi
Old Mar 02, 2009, 07:15 PM
Raleigh, NC
Joined Apr 2007
Here's how I have mine wired and it works just fine.
Maybe you should check your DMM current with a known source.
EDIT: While looking at your pictures in more detail it seems you may have the two outer bananna plugs plugged in reverse order.
Bill
Old Mar 02, 2009, 08:03 PM
Magnumpi is offline
Magnumpi's Avatar
Joined Nov 2007
OK i switched the plugs to look like yours, it still shows 8.83 WOT as before, except before it was a negative number. I soldered the 1k resistor straight to the middle hole is that OK? I check for the amp draw with the meter set on 10A is that right?
Old Mar 02, 2009, 08:10 PM
Magnumpi is offline
Magnumpi's Avatar
Joined Nov 2007
BTW it tested a 9v battery ok.
Old Mar 02, 2009, 08:31 PM
Raleigh, NC
Joined Apr 2007
It seems to be wired right.
Why do you think the reading of 8.34 amps is incorrect?
Bill
Old Mar 02, 2009, 08:58 PM
Magnumpi is offline
Magnumpi's Avatar
Joined Nov 2007
Well im testing my Typhoon 3d with a 3700k motor running on a 2200 15c lipo. With a 13.5 7 prop. I would think it would be at around 15 to 20 amps draw at WOT. Am i wrong?
Old Mar 02, 2009, 09:11 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
CAUTION
Most DVM's have a limited time spec for current measurements on the high range.
Be sure to limit the time you use the meter for current measurements to the limits of the meter. Some are as short as a couple of minutes.....others 10 min..etc.
hoppy is offline Find More Posts by hoppy
Old Mar 02, 2009, 09:14 PM
Magnumpi is offline
Magnumpi's Avatar
Joined Nov 2007
It starts at 0.04 ( Need to recalibrate) and stays at around 8.49 but below 9.00
Old Mar 03, 2009, 10:58 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Magnumpi,
It looks correct to me. To double check just forget my adapter and use the unmodified meter inline between battery and ESC. I suspect the read will be the same. These meters are cheap but usually dead on.
0.04 means nothing. I don't think you need to recalibrate unless you go over 10a. In that case add heavy wire in parallel to the shunt inside the case until it reads exactly half what it did w/o the wire. Max scale will then be 20a instead of 10a or add more for even higher current. One guy has set his up to read 100a!
Keep in mind the higher the scale the less accurate it will be though.
rich smith is offline Find More Posts by rich smith
Old Mar 03, 2009, 11:03 AM
Magnumpi is offline
Magnumpi's Avatar
Joined Nov 2007
I think it is right, i just tested my FW F-35 with a 3s 1500 25c and it showed
16.87 so i thank its working OK...Is there a way to convert the AMPs to tell how much Watts your getting???
Old Mar 03, 2009, 11:12 AM
Raleigh, NC
Joined Apr 2007
Watts = Amps x Volts
It's going to be difficult getting both those figures at the same time without using a wattmeter. If you have 2 meters you can set one to amps and the other to volts.
Bill
Old Mar 03, 2009, 11:13 AM
Magnumpi is offline
Magnumpi's Avatar
Joined Nov 2007
Thanks for the info, i love this site.
Old Mar 03, 2009, 11:18 AM
Raleigh, NC
Joined Apr 2007
If there's other equipment connected to the meter, ie, ESC, receiver, servos, etc., that could be where the 0.04 amps is coming from.
BTW, 0.04 amps is 40 milliamps which is just about right for the idle current for those items I mentioned above.
Bill
Old Mar 03, 2009, 09:58 PM
earlcbrown is offline
Find More Posts by earlcbrown
United States, CA, Stockton
Joined Jan 2006
Rich
I just saw your post on setting up a harbor fright multimeter to check your amps and volts. Great Idea
the multimeter from Harbor Fright show the amp range from 20 ma to 200 ma
is this the same one you used?
I would like to use two multimeter's so I could check the watts I guess I would
use one meter to check the voltage and one to check the amps.
I would not have to use The 1 k resistor with this set up right. what would the wiring diagram look like. Thanks for any help ahead of time
Earl
earlcbrown is offline Find More Posts by earlcbrown
