Old Nov 07, 2008, 07:26 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Mini-HowTo
$3 Wattmeter
Those who browse the RCG threads are probably convinced as I am that #1 cause of motor/ESC failure is lack of wattmeter. Here's a solution that is so inexpensive there's no excuse anymore for not checking run current. Also good for seeing how much juice that charger's putting back in your battery or watching voltage creep up to the magic 3.8v/cell for storage.
It is based on the Harbor Freight multimeter that is always on sale for $2.99 in at least one of the active catalogs. Any low cost meter will do. Only other component is any size resistor from 1k-10k or thereabouts. Here's wiring diagram and pics. Takes about 1 minute to build.
Switch to 20v to read volts and 10a to read amps (label says 10a but actually it reads up to 20a). Using calibrated laboratory references I've noticed this meter is considerably more accurate than commercial wattmeters and dataloggers costing much more.
update:
It's good up to 20a using the regular banana plugs and no modifications to meter. Much higher current can be monitored if you open the meter and wire directly to the shunt instead. See 3rd pic below. Before doing this measure a reference load (car lamp w/12v supply). After the mod adjust position of wires on the shunt until it reads 1/10th as much. They are about 1/16" (1.5mm) apart. Now full scale will be 200a instead of 20a.
Below is a pic of the bulb I used to calibrate. Handy for discharging batteries for storage or disposal too. It's got a JST connector because my motors are small. A constant DC supply like an extra drive cable from your PC is best but a battery will work too.
Remember, you need heavier connectors and wire to handle higher current. Note that the meter still works with original probes and scales yet does up to 200a if the new ESC/Batt connectors are used.
Like Curtis says you can add solder to the shunt between the wires to reduce readings for fine tuning. The extra solder allows it to handle a bit more current too.
More update:
Jackerbes and Critterhunter in post 75 and 295 respectively have put together much more detailed how-to with better pictures and diagrams. Thanks guys!
rich smith is offline Find More Posts by rich smith
Old Nov 07, 2008, 09:43 PM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
I have that exact meter and never even thought of that. Locally only $2.79 this week.
It's that simple? Jeese, off to make some test leads for JST and micro Deans. Will make a connector and hard wire into the board with better (thicker) wires.
Where do I get the resistor needed? Exactly what do I ask for? 1K what?
hpiguy is offline Find More Posts by hpiguy
Old Nov 07, 2008, 10:20 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Or just make a very simple,inexpensive shunt.
http://www.rcgroups.com/forums/showp...05&postcount=7
Charles
Old Nov 08, 2008, 05:01 AM
rich smith's Avatar
Joined Dec 2006
HP,
Ask for cheepest 1k resistor. Wattage, type, etc. don't matter.
PS You can also dig just about any resistor out of an old piece of junk electronic gear kickin' around the house. Or go dumpster diving. Value is non-critical.
Old Nov 08, 2008, 05:07 AM
rich smith's Avatar
Joined Dec 2006
http://www.rcgroups.com/forums/showp...05&postcount=7 Charles
Yes, Charles, I built many shunts using numbers from your excellent thread. Thanks. However this is even simpler and inexpensiver because no shunt required. With added feature of voltage at flick of a switch.
-Rich
PS another even simpler shunt implementation in my Poor Mans Datalogger thread:
http://www.rcgroups.com/forums/showthread.php?t=921407
Old Nov 08, 2008, 05:23 AM
charlie hepler is offline
Find More Posts by charlie hepler
Newbie but not too new!!
Lexington NC
Joined Dec 2004
Switch to 20v to read volts and 10a to read amps. Using calibrated laboratory references I've noticed this meter is considerably more accurate than most commercial wattmeters and dataloggers costing much more.
It's good up to 10a using the regular banana plugs. Much higher current can be monitored if you open the meter and wire directly to the jacks and add solder to the shunt to recallibrate. Also remember to use heavier wire and better connectors if you go over 10a.
Hey I like both of these setups and will try them both as I have several of the cheap meters from Harbor Freight Co.
Can you show what you mean by "add solder to the shunt to recallibrate"?
I am not sure I get that part. I see the solid wire inside the meter and am guessing that is the shunt?
On Charles' "Shunt" setup... If I am reading the MilliVolts at 28 on my setup with the shunt but both my watt meters show 26amps what needs to be done to the shunt setup to get that more accurate?
charlie hepler is offline Find More Posts by charlie hepler
Old Nov 08, 2008, 11:36 AM
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
HP,
Thank you, that will be easy to find then.
Old Nov 08, 2008, 12:00 PM
rich smith's Avatar
Joined Dec 2006
Charlie,
You guessed right. Wire the battery and motor leads to the middle of the shunt and range will be increased. Make sure you have a reference like 12v bulb hooked up before you recalibrate or won't know how much to change. I.E. if was 2a before recal and .2a after then you know range has been increased 10x (200a full scale).
PS I tested half dozen different makes of wattmeters and none of them very accurate. Not even in the same ballpark as el cheapo multimeters.
Old Nov 11, 2008, 08:33 AM
rich smith's Avatar
Joined Dec 2006
Note that the original banana jacks were used in my case. Old leads were cut off right at the end of the connectors and new JST cables soldered on. It is important that a physical strain relief be used for the new wires. A glob of epoxy or silicone around the end of the banana jacks where they attach will do. Another way is to zip tie the wires to the body of the connectors.
In case of extended current versions a notch is cut in each half of the case and small rubber grommet protects wires coming out. Don't forget to put the grommet on BEFORE you solder wires on.
Old Nov 11, 2008, 09:10 AM
Lexington NC
Joined Dec 2004
Man I must be sleepy my 1st day back on day shift! LOL
What does this part mean?
" In case of extended current versions a notch is cut in each half of the case and small rubber grommet protects wires coming out. Don't forget to put the grommet on BEFORE you solder wires on."
I plan to remove the old wires and use heavy 12G noodle wire and solder them to the inside of the meter and add the resistor as you have shown.
If I chose to read Volts and then also read Amps what proceedures will need to be done? Will it need to be unhooked and hooked back up before switching them or turn the meter off and switch from V to amps?
Old Nov 12, 2008, 07:54 AM
rich smith's Avatar
Joined Dec 2006
I found that instead of drilling a hole it's quicker to cut a notch or half circle in each case half to bring the wires out. Also makes it easier to remove them.
A rubber grommet (Lowes, HomeDepot, RS, etc. ) keeps the wire from being cut by sharp edges. Couple layers of shrink also works. Or if you're really lazy like me just bevel the plastic and no grommet.
To read volts just twist the dial. No need to disconnect. That's what the resistor is for.
Old Nov 12, 2008, 01:40 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Why is the 1k resistor needed?
jrb is offline Find More Posts by jrb
Old Nov 12, 2008, 01:45 PM
rich smith's Avatar
Joined Dec 2006
It is a current limiter. Without it damage to the meter and battery can occur when changing settings. I.E. dead short while in ma ranges. Not good for ohms range either. This way it's %100 safe.
Old Nov 12, 2008, 02:03 PM
Sir Raleigh is offline
Find More Posts by Sir Raleigh
Raleigh, NC
Joined Apr 2007
Rich, I have the DVM pictured below. This meter will go up to 20 Amps. Can I use this meter with your circuit using the 20 Amp input?
Bill
Sir Raleigh is offline Find More Posts by Sir Raleigh
Old Nov 13, 2008, 12:11 PM
rich smith's Avatar
Joined Dec 2006
Originally Posted by BloomingtonFPV
Hi Rich,
I appreciate you making the instructions for the wattmeter available. I made the $3 wattmeter using the 200a modification by soldering the two black wires along the shunt. However, my escs on several planes won't arm when the meter is in series with the battery. I know it is working correctly when I test it on another load. Is it possible that the ESC doesn't like the shunt on the ground? My red wires are tied together and go to the solder point of the fuse using a 1k resistor.
Thanks, Tom
I hope you don't mind posting instead of PM because of limited space there.
If the ESC fails with meter inline it's probably due to wires being too thin or too long, bad connectors, or a wiring error. Properly executed the meter should look like a very short extension and never interfere with normal operation. If you still have trouble clear photos might help us diagnose your problem. Keep us posted.
