Old Nov 20, 2008, 06:50 PM
nyc863 is offline
Find More Posts by nyc863
Joined Nov 2008
now that's the ticket!
nyc863 is offline Find More Posts by nyc863
Old Nov 21, 2008, 03:45 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I installed an XMSeller G401B hh gyro because I wanted to test it out for budget-minded people (who is not?). Surprise surprise! I like this gyro. Read my review to find out how much
Gino CP is offline Find More Posts by Gino CP
Old Nov 21, 2008, 11:10 PM
Nitrosharkiii is offline
Find More Posts by Nitrosharkiii
Joined Oct 2008
I am just sticking with my old GY240, Life has got in the way of my building latley but I will do some more tonight
Nitrosharkiii is offline Find More Posts by Nitrosharkiii
Joined Oct 2008
be nice to see parts for sale soon
Old Nov 21, 2008, 11:46 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I flew the heli at the field first time. The boys were impressed by the heli. All amazed at how much punch is available with the 430L motor. My electronics were all spot on. Fusonic digital servos were quick and very accurate. Tail was very good with GY401-like hold. Distinguishable from the Spartan hold but nonetheless enjoyable. I really like the overall setup.
http://www.vimeo.com/2311986
Old Nov 22, 2008, 04:47 AM
Joined Oct 2008
well thats good to hear Gino, carried on with my build.... faults if any so far would be cutting out the bottom of the canopy, not really a big deal but still needs doing, also even though I love the ball links with the hex hole, make the threads at least 2mm longer! they are very hard to fit a locknut on the back of a servo arm, hs65hb for me
Old Nov 22, 2008, 05:17 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
No need for nuts. Just make a tap using a spare screw. Then tap threads into the servo arm. Mine are screwed in tight. I did the same thing with my SE and the balls and arms are a year old.
Old Nov 22, 2008, 05:23 AM
nyc863 is offline
Joined Nov 2008
I also didn't use a nut on the servo arms - I bored out the hole using an allen key slightly smaller than the thread, then screwed in the ball using a lot of weight on it to get it to bite, it was a very tight fit they aren't coming out unless I unscrew them..
Old Nov 22, 2008, 05:46 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
This is the tap I made using a 1.5 hex screw. I cut two edges using a Dremel cutting wheel. Then I tapered the tip to help drive it. Using locking pliers, making threads is easy on the servo horns. Driving the balls is easy too but it has very good grip.
Old Nov 22, 2008, 01:27 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
You have a great learning curve!! I still remember your first videos of just hovering. Or maybe I just need a lot more stick time . Probably a little of both.
mhills51 is offline Find More Posts by mhills51
Old Nov 22, 2008, 03:58 PM
Joined Oct 2008
I did this Gino when I installed the balls, undersized them so they cut a thread but I just like the security of a nut
Old Nov 22, 2008, 06:25 PM
Wolfpackin is offline
Find More Posts by Wolfpackin
Colorado
Joined Jul 2007
A drop of CA on the threads will also help.
Wolfpackin is offline Find More Posts by Wolfpackin
Old Nov 23, 2008, 04:36 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Flew the SE for a change. Boy, what a difference. The BA pop wasn't there. It's surprising because the SE had the stronger AKE 480R motor. The cyclic was a bit delayed. Plus the noise was relatively unbearable LOL. The tail was slower compared to the BA. But that could just be setup. I don't know. But my SE is really efficient averaging 1100mah compared to 1600mah for the Black Angel on a CopterX 430L motor (old one).
Old Nov 23, 2008, 09:39 AM
lyclyc is offline
Find More Posts by lyclyc
Pirouetting flip master
Malaysia
Joined Jul 2007
1100 and 1600 over how many minutes?
roughly 40% longer flight time on the SE?
lyclyc is offline Find More Posts by lyclyc
Old Nov 23, 2008, 10:00 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
5 min for both. I can't say longer (or shorter) since I have two different setups with different motors and pinion. I have yet to swap motors and confirm efficiency.
At the moment, based on my experience with the 430L on the SE, I can say there is more punch now on the BA. It's practically bog free. This puzzles me because the same motor was bogging like crazy on the SE.
Discussion New Copterx range.. Black Angel / 480 /500 Myk-e-b Mini Helis 32 Jul 08, 2009 07:21 PM
Sold New Hummingbird 3d pro/Black hawk helicopter and other stuff!!! HyperHelis Aircraft - Electric - Helis (FS/W) 3 Jan 23, 2008 07:27 AM
For Sale Black Horse ARF new, Arrow 3D, $135 shipped krosypal Aircraft - Fuel - Airplanes (FS/W) 0 Nov 15, 2007 01:29 AM
New Switchback 3D MAH42 Parkflyers 4 Mar 08, 2003 07:14 AM
FS-New Zc-400, yellow/black Gonflyin01 Aircraft - Electric - Airplanes (FS/W) 0 Nov 13, 2002 04:30 PM
