Old Nov 19, 2008, 03:14 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I'm keeping mine in the box :-) Boy watch out for that Scorpion motor. Mine is way too powerful for what I am used too and it is just the CopterX 430L.
Gino CP is offline Find More Posts by Gino CP
Old Nov 19, 2008, 03:43 AM
Nitrosharkiii is offline
Find More Posts by Nitrosharkiii
Joined Oct 2008
Gino whats up with that bracket for your tail servo?
Nitrosharkiii is offline Find More Posts by Nitrosharkiii
Old Nov 19, 2008, 03:56 AM
LaurenceGough is offline
Find More Posts by LaurenceGough
LaurenceGough's Avatar
Reading, UK
Joined Sep 2007
http://www.rcgroups.com/forums/showthread.php?t=955672
LaurenceGough is offline Find More Posts by LaurenceGough
Old Nov 19, 2008, 12:24 PM
Joined Oct 2008
oh ok thanks,,,, thought it was for some wild new design lol
Old Nov 19, 2008, 04:18 PM
nyc863 is offline
Find More Posts by nyc863
Joined Nov 2008
yeah I put a 430X on it instead.
In doing so i discovered a possible problem with the motor mount. The align motor has a circular island around the spindle that fits exactly into the space in the motor mount, which means the motor is not adjustable. I could move the scorpion to get the right distance from the drive cog.. but not the Align motor. When you screw it in, it is only in one position?
nyc863 is offline Find More Posts by nyc863
Old Nov 19, 2008, 05:23 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
You can look for spacers/washers and Loctite them over the screw holes on the motor. The spacers should line up with the shaft ring. Then use longer motor screws.If you can fin aluminum spacers that would be better for heat transfer. Hopefully when you adjust the pinion height, it will still have enough shaft to grip on.
Old Nov 19, 2008, 05:24 PM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
They ruined it with that direct driven pully setup. Take off the tail idler then add 2 more up front?
I hated the design of the king V2 so much i told myself ide never again get a direct driven tail.
It looks neat though, the dragonous looks neat too but i cant get past that pully sitting there.
BowerR64 is offline Find More Posts by BowerR64
Old Nov 19, 2008, 05:35 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Puzzled over why this heli is more powerful than the SE despite its weight, I can only think of the direct belt drive as responsible. The heli's tail response is great and it is very quiet. Punch is ridiculous compared to the SE ,everything being equal. Despite my earlier hesitation about a direct belt drive, I am now a believer.
I know you love low head speed. But there is a lot going here despite power. Handling is very locked on. You have a more direct feel. Cyclic response is quicker without being unstable. This will be a very nice heli number, how many is it now, 14?
Old Nov 19, 2008, 07:05 PM
nyc863 is offline
Joined Nov 2008
Hey Gino, what is the right belt tension for this thing.. and the best
way to check it is roughly right, with a prod of an allen key or something?
Old Nov 19, 2008, 07:07 PM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
What about that motor? Could that be the power increase?
mhmm
Old Nov 19, 2008, 07:39 PM
Joined Oct 2008
you seriously own that many helis bower?
Old Nov 19, 2008, 07:49 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
The motor is a 430L. It was bogging on the SE. On the SE my AKE motor easily smokes it. Now the 430L on the BA smokes the AKE on the SE. I have so much power for my flying style, I am actually afraid I wouldn't be able to handle the AKE on the BA.
It is hard to describe belt tension. I set it so that I can move the belt 2-3mm with medium effort. I want it as loose as possible without the belt skipping teeth, slapping together, and dislodging from the guide pulleys.
Old Nov 20, 2008, 02:51 AM
lyclyc is offline
Find More Posts by lyclyc
Pirouetting flip master
Malaysia
Joined Jul 2007
what is the other 450 out there that is using direct belt drive?
beam
dragonus
lyclyc is offline Find More Posts by lyclyc
Old Nov 20, 2008, 03:45 AM
nyc863 is offline
Joined Nov 2008
I took mine out again and decided I don't like the tail support,
it is sharp as hell so it digs in on grass.. turning your tail into a
grass cutter or digging machine .. and provides so little stand-off
for the tip of the tail rotor that on concrete the tail blades scraped
easily if the heli had a tilt, or there was any ground not perfectly
flat. And if they scrape, they are toast.
I think I may glue about 1cm of hard foam as an extension.. as
ugly as that would look..
Old Nov 20, 2008, 03:12 PM
Wolfpackin is offline
Find More Posts by Wolfpackin
Colorado
Joined Jul 2007
You could do this...works for me and not too ugly.
Wolfpackin is offline Find More Posts by Wolfpackin
Discussion New Copterx range.. Black Angel / 480 /500 Myk-e-b Mini Helis 32 Jul 08, 2009 06:21 PM
Sold New Hummingbird 3d pro/Black hawk helicopter and other stuff!!! HyperHelis Aircraft - Electric - Helis (FS/W) 3 Jan 23, 2008 06:27 AM
For Sale Black Horse ARF new, Arrow 3D, $135 shipped krosypal Aircraft - Fuel - Airplanes (FS/W) 0 Nov 15, 2007 12:29 AM
New Switchback 3D MAH42 Parkflyers 4 Mar 08, 2003 06:14 AM
FS-New Zc-400, yellow/black Gonflyin01 Aircraft - Electric - Airplanes (FS/W) 0 Nov 13, 2002 03:30 PM
