Old Nov 15, 2008, 02:29 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
The CopterX Black Angel Unboxed
Box is small. 1.5x a shoe box
Parts set are neatly bagged with pressed plastic corners for small parts. Hex keys included.
I just adore this frame. It is well-finished. And design is good. I am not sure if it is a clone of any heli out there. But I've seen this single piece sides before.
Sweet reinforcement ring. Gives a nice CopterX signature.
Boom block has seen some weight savings. A single bolt above and two screws below means no more free turning tubes inside.
Here's a frontal view to show its slim profile. Looks like some components need to be mounted outside.
Fit and finish of black cf against polished aluminum is just pure eye candy.
Here's the gyro mounting plate. Frame is upside down. Your gyro will be safe from now on. No more make-do mounting methods.
A view of the motor mount. First impression tells me I need to mount the motor and set the gear mesh before I mount the servos. I certainly hope I am wrong. That would be a b_tch.
The fabulous head with its short flybar cage and cantelever upper mixing arm. Measurements suggest a more aggressive response is possible.
The whole head with the gold swash. Perhaps for good luck!
Enjoy these for now. Build notes to follow.
Gino CP is offline Find More Posts by Gino CP
Old Nov 15, 2008, 03:45 PM
Nitrosharkiii is offline
Find More Posts by Nitrosharkiii
Joined Oct 2008
man I really cant wait for mine now Gino..... its left China and "flying" its way to me thanks for the eye candy
Nitrosharkiii is offline Find More Posts by Nitrosharkiii
Old Nov 15, 2008, 03:51 PM
Joined Oct 2008
Gino
there has been some talk that its a beam copy however comparing the two this does not seem to be the case they have some similar parts but are not a clone
Old Nov 15, 2008, 04:42 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
It looks really nice I wish there was more importers to the US.
mhills51 is offline Find More Posts by mhills51
Old Nov 15, 2008, 04:49 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
There are 3 retailers of the CopterX SE in the US. I'm sure if response is good they might just bring some kits over. But unlike the SE which shares parts with the Trex, this one doesn't. They might have to carry some parts. If you really like this heli, you can order parts stock in advance. Given our experience, we already know which parts we regularly consume. I am still keeping my SE for backup. That I will fly if and when I need to order parts for the Black Angel. I'll call it BA. Bad A_S LOL.
Old Nov 15, 2008, 05:12 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
What are the retailers? I will still have my Hoss and SA if anything breaks.
Old Nov 15, 2008, 05:22 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
www.electronhobby.com and http://heli-bros.mybisi.com/
Old Nov 15, 2008, 09:01 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
More pics
The sun was out and I was able to take more pictures.
Old Nov 15, 2008, 09:24 PM
Wolfpackin is offline
Find More Posts by Wolfpackin
Colorado
Joined Jul 2007
Nice pictures, thanks for sharing.
Wolfpackin is offline Find More Posts by Wolfpackin
Old Nov 15, 2008, 11:02 PM
Joined Oct 2008
dont forget Gino you can buy from ehirobo too
Old Nov 15, 2008, 11:50 PM
Joined Oct 2008
boy oh boy I really hope copterx comes out with a 50 size heli...... they would clean up the market
Old Nov 15, 2008, 11:53 PM
Slyster is offline
Find More Posts by Slyster
Google 'Blade 400 bible'
Slyster's Avatar
Joined Nov 2006
They did. The CopterX 500. That's the one I have my eye on for next year. http://www.copterx.com/kit_cx500se.html
Slyster is offline Find More Posts by Slyster
Old Nov 16, 2008, 12:01 AM
Joined Oct 2008
yeah but thats electric not glow! I would be keen on a nitro 50 from them, electrics of this size are too expensive battery wise
Old Nov 16, 2008, 12:03 AM
Joined Oct 2008
actually humour me on this, I have not got into the bigger electrics, what would a battery size be for this and cost? what flight times would you expect?
Old Nov 16, 2008, 12:29 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Build Log
Summary:
This is a well built kit. The screws were very tight and most had threadlock. I suggest testing each screw with a suitable allen driver. If it takes effort to crack it loose, leave it alone. If you can turn it then remove and reinstall with threadlock. Some screws are not 1.5mm. These strip easily. The heads have beveled sides compared to the rounded profile of most screws. If you see these, proceed with caution. Otherwise, if stripped, cut a slot and remove with a screwdriver. I found 1/16" hex for the lower mixing arms.
Personal Tools Used:
CopterX hex driver (highly recommended. Get the whole set.)
Dremel with cutting wheel
Long nose vise grip
Loctite 242 (blue compound)
Small flat screwdriver (width of dremel cutoff wheel)
Extra 1.5 head hex screws (various lengths to replace bad ones)
Homemade tap for ball screwing on servo horns. I just cut two notches with Dremel on a spare 1.5 hex bolt. Then I tapered the tip. Without this, it was impossible to drive the balls into the servo horns.
Not threadlocked screws found on:
folded anti rotation bracket (two missing screws in frame bag along with canopy mounts)
a screw on the head
screws for adjustable battery plate
screws for esc plate
screws used for attaching other component sets
Additional parts used (sold separately)
screw bags ( bolts and nuts for replacement of stripped screws and for servo mounting) .
Build notes:
Frame:
- Screws that strip have a different head profile. Cover with masking tape. Expose head. Cut with dremel. Remove with screw driver
- Install two bolts on each side of the anti rotation bracket. Extra screws are in the frame bag corner pouch.
- Loose screws on battery tray and esc tray
Head
- lower mixer arms are 1/16 hex.
- You must use a tap to lay threads into the servos horns. This makes installation of balls easier. I made one from a spare 1.5mm hex bolt.
*Final Build in the following days.
Discussion New Copterx range.. Black Angel / 480 /500 Myk-e-b Mini Helis 32 Jul 08, 2009 06:21 PM
Sold New Hummingbird 3d pro/Black hawk helicopter and other stuff!!! HyperHelis Aircraft - Electric - Helis (FS/W) 3 Jan 23, 2008 06:27 AM
For Sale Black Horse ARF new, Arrow 3D, $135 shipped krosypal Aircraft - Fuel - Airplanes (FS/W) 0 Nov 15, 2007 12:29 AM
New Switchback 3D MAH42 Parkflyers 4 Mar 08, 2003 06:14 AM
FS-New Zc-400, yellow/black Gonflyin01 Aircraft - Electric - Airplanes (FS/W) 0 Nov 13, 2002 03:30 PM
