Nov 06, 2008, 11:05 PM
New CopterX 3D CX450 Black Angel
CopterX been around for few years and best know for their 200 to 480 range helicopters. After years of development the latest model to join the family is the CX450 Black Angel. With it’s innovative design it will sure meet the needs for most advance pilots. As the Black Angel come 90% per assembled from the factory and the quality for the parts the assembly is a quick and enjoyable experience
As a completely new helicopter designed from ground up.* A lot of unique features are brand new or only available for larger helicopters.* Things like +/- 15 degree patch range, carbon fiber main, tail blade, fly paddle, one piece carbon fiber main frame, CNC main rotor and tail drive assembly, oversize bearing and feathering shaft, pre painted fiber glass streamline canopy, etc.* With it’s wide range of adjustability make the Black Angel suitable for all pilots.
No need to upgrade as Black Angel comes standard with full CNC aluminum rotor head and carbon fiber main blade and fly paddle. All parts are ball raced and aluminum parts were finished with a beautiful grey anodized. As a carbon blade manufacture the carbon blade comes with the kit are top of the line products and can really perform during all kind of heavy load conditions
Lot of parts on the rotor head are over sized or hardened. 4mm feathering shaft, hardened aluminum alloy washout, oversize main shaft lock collar, one piece swashplate, etc. All these design aim toward the high loading for extreme 3D maneuvers and durability.
As with the rest of the helicopter. The tail drive system feature CNC and carbon fiber constructions for light weight and rigid design. Carbon fiber tail blade are standard equipments. Extra wide long life drive belt to ensure positive rudder control during 3D maneuver. And It drive directly off the main gear, with the larger drive pulley and eliminate the gear box assembly makes it much lighter and durable. Belt tensioners on both end to reduce the change of skipping and derailing
One piece carbon fiber frame reduces number of aluminum parts necessary for the frame construction. Result in a light weight and rigid frame. All mounts were made by aluminum alloys. With the adjustable battery mount you may dial in the CG for personal reference. Special composite canopy mount to reduce vibration as much as possible. Streamline glass fiber canopy come prepainted to reduce construction time
CopterX had out done themselves this time. With all these innovative designs Black Angel is a true winner out of the box. For the materials used in this kit, the price tag is defiantly a bargain. The wide range of adjustment make this model suits the needs for all pilots from beginner to the most advance 3D master
